Retrieve fax verification sent out on hp psc 950
Need to retrieve fax verification for faxes sent out on the hp psc 950. I have done this before but forgot the procedure.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
My fax will not send. the report says fax sent and the result is no answer
Sounds rather conflicted...any way, first step "send" a fax to a phone that rings (cell phone, phone near the fax). Make sure that the phone you are calling rings, if not plug a phone in to the fax line and make sure you have a dial tone. If you do try to change the phone line on the fax and repeat. Basicly this step is to ensure the fax is dialing out.
Next, dial the number you are faxing to with your cell phone or another phone. Does the fax machine at the other end answer (squaking noises). If not are you dialing the right number. If the fax machine at the other end does pick up, hang up and wait a few mins (so the line will clear) and try to send your fax again.
Try sending a test fax to a known good (have sent faxes to the number before with success) fax. If this works, its a communication hand shake error. You may need to power cycle both fax machines.
Last Test, plug a different fax machine in were this one is. Using the same phone line and such try to fax again. If this is the only thing that works, the fax machine may have a bad modem.
If further information on testing the modem on the HP fax is needed let me know.
I hope one of these step gives you the help and information you are looking for.
Jul 22, 2011 | HP PSC 950 All-In-One InkJet Printer
My problem is with the HP PSC 950 series printer, fax, scanner, copier. The fax and copier work sporatically, sometimes producing a copy or fax and most times not. Please help
faxing,scanning and copying use the same mechanism,thts the scanner,if its doing it intermittently you can try a reset on the printer.see if tht works.
Jun 24, 2009 | HP PSC 950 All-In-One InkJet Printer
Have no manual; need help using scanner and fax
Here is the link given to the user manual. that contains the optimum solution to your problem and maximum guidance.
http://www.devicemanuals.com/guide/All-in-One%20Products/HP/HP-PSC-950-All-in-One-Owners-Manual-==TVRFME56VTI=.html
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=34579
May 27, 2009 | HP PSC 950 All-In-One InkJet Printer
HP 950 fax will send but does not receive faxes
It could be that your machine has been set to "no answer" in the number of rings setup area. See page 46 on how to change the number of rings.
It could also be set for a "distinctive ring pattern". See page 51 on how to change that setting.
User manual is here:
http://h10032.www1.hp.com/ctg/Manual/bpu05029.pdf
Jan 21, 2009 | HP PSC 950 All-In-One InkJet Printer
Is wireless operation possible
hoow do i send a fax with an hp psc 950 combination printer, fax, scanner and copier machine?
Jan 13, 2009 | HP PSC 950 All-In-One InkJet Printer
Faxing
would like to set up faxing
Aug 04, 2008 | HP PSC 950 All-In-One InkJet Printer
Fax feature in HP PCS 950
Try switching the dialing mode to "Pulse" and lowering the baud rate for the printer.
May 02, 2008 | HP PSC 950 All-In-One InkJet Printer
HP PSC 950 and Vista
Unfortunately, no. The whole Vista migration issue is a raging debate. The only work around that might work, is to set up something like an E Fax account, and send it to yourself, and then print it from the web interface. Ugly, but might be the only way now. Got Backup?
Feb 10, 2008 | HP PSC 950 All-In-One InkJet Printer
Hp psc all in one faxing problem
Need more info.....
Plug in phone line.......
Feb 09, 2008 | HP PSC 950 All-In-One InkJet Printer
155 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
