Question about Delta & Single Handle Shower Faucet
Bathtub faucet leaking cant find water shutoff
  • 105 Answers
Sometimes you have to shut the whole house off to fix a faucet,..sounds like your in this situation,....no biggie, just shut off whole house and do your repair.
Posted on Jan 31, 2010
We have no hot water coming out of our bathtub faucet. We took it all apart and water is only coming our of the cold side of the pipe
there is probably a shutoff on the rough-in valve in the wall. Sometimes the seal in that comes apart and blocks the water. Get new stem for valve. Unscrew the nut, replace stem, tighten nut. Clean inside valve before u put new one in.
Oct 10, 2015 | Delta & Single Handle Shower Faucet
The water runs when I turn the main shutoff back on even though the faucet is off
A grommet seal has disolved. You need to turn off the water main and replace or rebuild the affected shut-off valve or faucet. Use a Monkey wrench. .
May 29, 2015 | Kohler Home
Tub faucet (hot side) won't turn off when tight and the shutoff valve won't stop the water either
sound like you need a new valve in the hot water Faucet the rubber washer or cartridge depending on what type of faucet you have
May 09, 2014 | Sunrise Specialty Cast Iron Claw Foot Tub...
Delta T2738 Deck Mount on Jacuzzi Tub. Hot Water side leaking.
With the detailed part number you have, I would just walk into stores like Home Depot or any plumbing store and they will give you the exact parts you need. They are not expensive and a lot of them are standard parts and come in kits.
Good luck.
Apr 08, 2013 | Delta T2738 Lahara Deck-Mount Two-Handle...
Delta foundations windemere roman tub faucet leaking out of spout
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 28, 2013 | Delta BT2796-SS Foundations Windemere...
New 352658 shower faucet drips
They are bad about leaking,you prob. need to replace the cartridge with new one. the seals in them get dry and shrink of they have been sitting in the box for a long time on the shelf or in a warehouse. you never know how long ago they were built and just sitting.
Nov 27, 2012 | American Standard 2083.102 Standard...
I have an Admiral washing machine...my problem is, is that it wont start...period. I have tried changing the water temperature to see if that effects it, with the door open and closed but it just wont...
What you need to do to solve the problem of your whirlpools is to trubleshoot it to resolve the problem your self.
Carefully apply the below instruction to solve the washer problem.
If your bathtub faucet leaks or performs poorly, there areways to troubleshoot the problem. A few common parts are most likely to wearout, so checking these reveals exactly what's wrong with the appliance. Thisrequires no specialized skill, and anyone who knows how to use a wrench willfind this project takes less than an hour. If you have no experience, giveyourself extra time.
1 Turn off the water to the faucet. Take offthe cap on top of the handle and remove the screw under the faucet cap with anAllen wrench. Take the handle off the faucet, pulling it away from the showerwall.
2 Remove the trim sleeve (also called a dome cap or bonnet). Simply turn itcounterclockwise and pull it off the faucet head.
3 Tighten the cartridge nut under the trim sleeve, replace the trim sleeve andhandle, and turn on the water. Test the faucet. Watch to see if the leak orproblem goes away. If not, remove the handle and trim sleeve.
4 Remove the retaining nut entirely. Turn it counterclockwise and pull it offthe faucet. Slide the cartridge out of the faucet and inspect the valve seals.If they're worn, replace the cartridge and reattach the retaining nut. Tightenwith a pliers or wrench.
5 Replace the trim sleeve and handle and turn on the water to test the faucet.
tools needed to carry out the work.
Thanks for uing fixya.
Jul 31, 2011 | Home
American Standard faucet 8125; when cold water is turned on more than a dribble the cold water slams off by itself. Seems to be getting worse. Used to be a medium flow that would shut itself off, now a...
This sounds like a foreign object in the water line. Suspect areas START at the shut off valve.
Turn off the house water and inspect the washer in BOTH shutoffs, I suspect that you may find a chunk missing. Not always so easy to get the broken piece out of the faucet, but keep after it until you get it out. Sometimes you have to totally take everything apart....
Jun 24, 2011 | Home
My water bill was very high this month. How do I check the toilets to see if that's the problem and where else can I check? My faucets aren't dripping and my outside faucets aren't leaking. ...
open the tank to your toilet, flush it, then mark the water line. if the water drops then replace your flapper. if you have a ballcock type float it would be good to replace that with a fluidmaster fill valve. if the toilets dont seem to leaking then locate the water meter outside. open the lid and look at it and locate the indicator needle. if there is water running you will see a needle moving and if that is the case than there is a leak. next turn the water shutoff in the house off. look at the meter again and see if there is movement. if it is than your leak is on your service line. if it stops moving than good news no leak on the service line. if you still cannot locate the leak then let me know and i will go on about how to locate a difficult to locate leak.
May 19, 2011 | Home
Bathroom sink pipes came apart and flooded our bathroom. cant find shut off valve to sink
Hi, W/D here.
Almost always, the shutoff valves are at the wall where water is supplied to the faucet. If the problem is with the drain piping, and the faucet valves don't leak, you don't have to shut off the water. Simply replace the drain piping and tighten it up. If you need any repair parts, you can get them from any hardware store. Please repost if there is anything else that I can help you with.
Good luck, and best regards,
--W/D--
Aug 13, 2009 | Delta Plumbing
Delta & Single Handle Shower Faucet  Logo
171 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
