Question about Nextar X3-03 Car GPS Receiver
Sound problems My GPS is not giving verbal commands. It does beep so there is sound. Any ideas?
  • 518 Answers
You will have to enter the menu and tick a box, but cannot help you any further as i do not have any dealings with this unit sorry
Posted on Jan 31, 2010
No picture but at bottom of screen problem reads "Resolve bootstrap. failed". what does this mean?
*NOTES:(Commands input not executed by audio or verbal recognition unless spoken by *CREATOR using the *wake-up_command) rundle_32 is a windows extentionsion for windows PowerShell.
Distro is a linux Platform OS and the sandbox is a alt tool used to make source forges online also a tool in standard linux directory like example |:$BASH su -man cn- o- force t- all-do commands run commands execute commands write commands read commands `su launch GENOME shell l- sh bb args name shell $BUSYBOX or $busybox /sys/root/xbin sh- busybox l- GENOME terminal Alias root n-admini
Feb 12, 2016 | Panasonic Viera Tc-p65st30 65" Full 3d...
Bmw x5 cd changer no disc
absolutely no idea ,do you have anything else plugged in that could cause the sound cut off although you say the radio works?or has a plug come loose in the back of the radio ,you could try one of them radio fitting centres as you never know some young lad comes out presses a button and it all works as you had the mute on or something but the radio works ,is it a built in cd player or a remote unit ? in my time a 8 track was the in thing these modern things are welll beyond your ancient dinasaur here .
Jan 30, 2014 | Cars & Trucks
Hi I no longer hear the voice sound
Go to Tools.... Settings... Language
Make sure the Language is set to something with ( TTS )
those are the audio voice files. at times the units will revert back to regular settings
Love my Nuvi760
May 30, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 265 wt...how to get voice command to work?
this may require two sessions but - here goes:
1- turn the unit on - select the VOICE icon on the opening screen - triple check it isn't muted and change it to 90% voice volume.
If this doesn't give you sound WHILE DRIVING - it won't give you voice unless you're moving or driving.
Then - turn the unit off - Turn it back on- - as it is starting up - and blank- place your thumb in the LOWER RIGHT CORNER of the blank Screen.
this will open this window:
SELECT - YES - it will reboot and your minor settings will be lost - like saved address and favorites - not your updated maps.
This will reset you to default NEW -
When done - sound will be as it was when new if no sound - return for repair.
May 06, 2010 | Garmin n?vi 265WT Car GPS Receiver
I have a nuvi 205 and it has quit giving voice commands. The volume is at 100% but there is no sound
Hello :
You have a software problem with your NUVI . I recommend you to reset [ restoring default factory settings ] your NUVI . That should fix the problem .
good luck .
please rate !
Apr 14, 2010 | Garmin nuvi 205 GPS Receiver
4 beep alarm - Mercury 150 efi outboard
hi,
when the engine is running there is a repeated 4 beep alarm every 5 to 10 min. i have talked to several repair shops and they are unsure of the problem. what is the proper solution to fixing this alarm?
Feb 10, 2010 | Boatmates products are the final word...
Installation of audiophile 192
Here is a list computer beeps and what they mean.
  • No Beeps: Short, No power, Bad CPU/MB, Loose Peripherals
  • One Beep: Everything is normal and Computer POSTed fine
  • Two Beeps: POST/CMOS Error
  • One Long Beep, One Short Beep: Motherboard Problem
  • One Long Beep, Two Short Beeps: Video Problem
  • One Long Beep, Three Short Beeps: Video Problem
  • Three Long Beeps: Keyboard Error
  • Repeated Long Beeps: Memory Error
  • Continuous Hi-Lo Beeps: CPU Overheating
Most times the beeping is caused by a bad/loose connection somewhere or card not seated properly.
Try disconnecting and reconnecting everything again. Make sure that all the power plugs are connected properly even if you didn't mess with them. Moving things around can sometimes be enough to give you the "BEEPS". ";-}
If you are still having much beeping and no computing you can try my personal favorite.
Start first with verbal threats. Next move to a second floor window and, while you explain whats going to happen if it doesn't knock it off, open the window.
If that fails give it the pitch.
Believe it or not I have used this technique and after reassembly and repair.....No more beep.
I hope this helps but if not let me know and we will try something else.
Dec 02, 2009 | M-Audio Audiophile 192 Sound Card
Navi/Voice command problem
I have the exact same problem. If you have a solution can you please email kfillebay@shaw.ca. Thanks!!!
Aug 01, 2009 | 2004 Acura TL
Everything works but the sound.
Mine does the same thing. You may need to do the 'reset GPS' trick. (hold down the - key and the repeat command key, then choose reset GPS.
For temporary, you can do the diagnostics>sounds (I think).
Mar 08, 2009 | Magellan RoadMate 700 GPS Receiver
No more voice commands
Is it still under warranty
if so take it back to the store
Feb 05, 2009 | Garmin nuvi 200W GPS Receiver
Nextar X3-03 Car GPS Receiver Logo
52 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
