The DVD player on my Neon C1973F has stopped working. There is a dvd stuck in it, but I cannot even hear the dvd drive spinning.
silly girl
  • 513 Answers
SOURCE: reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
Posted on Jan 30, 2006
  • 163 Answers
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Posted on Aug 10, 2006
  • 12 Answers
SOURCE: Daewoo DVRS05 Recorded DVD won't play in OTHER DVD players
my suggestion from reading other forums is that these players sometimes have problems finalizing the disc.. you could try making a copy of the disc in a computer to see if this fixes the promlem or maybe media these use dvd+r and has a lot of compatibility issues with dvd players.
Posted on Feb 27, 2008
  • 236 Answers
SOURCE: DVP-NS50P will not load DVD
the lense could be only dirty, try cleaning it first. i suggest do a manual cleaning if you can. open the top cover of the unit, remove the disk retainer and you will find the lense somewhere in the middle. use a cotton bud, use a little of alcohol, dampen a little only and wipe the lense in circular motion. then use new dry bud to dry it.
Posted on May 04, 2008
  • 3 Answers
SOURCE: Stuck dvd in dvd player
This is what LG customer service will instruct you to do. I have a LG LDA-511:
1. Unplug your unit.
2. After unplugging, wait a few seconds then press and hold the power button (yes, while the unit is unplugged). This resets the unit.
3. Plug in your unit.
4. Press the eject button.
If the disc does not come out, then you need service from an authorized service representative.
Posted on Aug 11, 2008
DVD player doesn't work
you can open the top cover and take the cd out.
Jun 04, 2008 | Sony SLV-D350P DVD Player/VCR
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray, close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
"NO DVD" message after "LOADING".What can be the problem?
  • The DVD player might just be broken.
  • If the player is under warranty, contact the manufacturer or store and you may be able to get a replacement.
  • You might try unplugging the player, waiting a minute and plugging it back in.
  • If you don't hear the drive spin up at all, then the drive may be stuck. In the past I have had good luck slamming the player flat onto a carpeted floor to unstick the player. It will probably get stuck again eventually, though. Freedom's just another word for nothing left to lose :)
Feb 12, 2012 | Televison & Video
Panasonic ez27eb wont read disc
Here are some things to try:
  • Try a different DVD. The DVD might be an incompatible region for your player or the DVD might be dirty or if the DVD is burned, the DVD player might not be able to read that format.
  • If you don't hear the drive spin up at all, then the drive may be stuck. In the past I have had good luck slamming the player flat onto a carpeted floor to unstick the player. It will probably get stuck again eventually, though. Freedom's just another word for nothing left to loose :)
Feb 11, 2012 | Panasonic Televison & Video
When playing a DVD, we experience frequent stops and starts..
It may be a dirty lens, or perhaps the drive is getting stuck.
The first thing to try, if you feel up to it, is to clean the lens. First, you'll need rubbing alcohol (peroxide isn't the same thing) and a Q-tip. Add a tiny amount of alcohol to the Q-tip and gently rub it against the lens of the laser. After a few times around the lens, use the dry end of the Q-tip to pick up any excess alcohol lying around. Put the player back together and try playing a disc.
If it still doesn't fix the issue, then the following steps can be taken.
Have a disc in the drive and while it's off, open it up. Start the drive and see if it's spinning freely. If not, then onto the next part.
Use some WD40 on the shaft of the drive motor that makes the disc spin. Just use a little bit at a time and work it in by manually spinning the spindle (what the disc rests on). Once that's finished, put the disc back in and reassemble the drive, plug it in, turn it on, and see if it spins better.
Jun 05, 2010 | Zenith DVD2381 DVD Player
I have a HR 753 DVD player and recorder and all of sudden not reading a lot of disks. even new ones brought from shop. I have put them in my friends DVD which is exactly the same and they work. Any ideas?...
Barring lightning strikes and other electrical issues...
9 times out of 10 the issue is going to be one of the two motors that are in the player. Either the motor that moves the lens or the motor that spins the disc. You should be able to hear a difference in the sounds the two players make when you insert a disc. If it is the motors you will hear clicking noise, similar to a dying hard drive. If ther motors work, you will hear the whurring noise of a spinning disc.
Feb 25, 2010 | Samsung Televison & Video
My CD/DVD player on my laptop wont work???
go to my computer and right-click on your drive and say autoplay, does that work?
Feb 17, 2009 | Acer TravelMate 223X Notebook
Centrios 1611304 Can no longer finilizing DVD !!!
Before you attempt to finalize, press the stop button 3 times. This will stop the disc from spinning in the tray. Then attempt to finalize from the menu. Sometimes this will not work, depending on your chosen brand of media. Some media just won't finalize (even if they are from the same package of discs that do finalize properly). I don't know why this recorder is so fussy about the media - sorry!
Dec 21, 2007 | Centrios EDW8020 DVD Recorder
Disk is not spinning in emerson portable dvd
if the disc doesn't spin, it sounds like a bad motor. can you hear the laser adjust? if you do, then it's probably a dead motor, if you can't hear that laser adjust at all, and the motor doesn't spin at all, the connection might have come undone(they both share a connection)
Nov 12, 2007 | Zenith DVP615 Portable DVD Player
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
