Question about AEG D2100-4 Electric Double Oven
Oven not warming up
We had a power cut 2 days ago and the over cut out whilst in operation, since then the oven never warms up, the fan is going round but the oven remains stone-cold
  • AEG Master
  • 3,463 Answers
The first thing to check is the oven element, this is located at the rear of the oven compartment behind a removeable cover.
Although it may look o/k, the only way to be certain is to test it with a meter.
Hope this helps.
Posted on Jan 30, 2010
Trying to cook prime rib that needs to rest in hot oven for 2 hours. How do I turn off cooling fan
that fan is a cooling fan but not for the food,it's to cool down the electronics in the oven like the clock assy. so it's doing it's job,that's why i tell people not to use the self clean feature on stoves or ovens,the temp. gets up to 1000 degrees and it will sooner or later damage the electronics in the machine,so if you're gonna use it use it after the holidays,i see people use it the day before thanksgiving,the oven stops working and parts have to be ordered or if it's an older oven you can't get parts anymore and they can't cook so that fan is a good thing.happy holidays.you have to set the oven on a low setting just to keep the oven warm.like 200 or 225,also some ovens have a warming draw under the oven door,if you have this make sure you clean it first,i've seen them filled with dust because nobody ever uses it.here i googled this for you
https://www.chowhound.com/post/meat-warm-360832
Dec 23, 2017 | Ovens
I used the self cleaner 2 days ago and now the oven will not heat. It warms only to 80-90?
Rhonda, its possible the heat sensor / probe may need to be changed, it is a small copper or brass wire with a small probe, that hangs on the upper portion of back wall in oven.
Mar 11, 2016 | Ovens
Baumattic Bt2760ss oven trips power
Check fan to see that it spins freely. Look for any evidence of rodent nests or damage( chewed wires ) check breakers and wiring to make sure they are properly sized for the oven. Hope this helps.
Jan 18, 2014 | Ovens
Oven problem
Check the heating element, it might be loose or burnt out, it should pull out of its socket.
Jul 17, 2012 | Ovens
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 | Smeg Ovens
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
DeLonghi ESS601 electric oven
We just moved in to a place that has this oven, if you use the setting with the fan with a circle round it, seems to get hot! Don't know what the other is for though!
Hope it helps!
Pete
Jun 20, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
AEGB1180-4 overheating/cutting out
It is not the control unit. Remove oven from housing, switch power off and remove either the top panel or the back of the oven You will see two wires going to a thermal overload cut out, looks likse a round thermostat. Join the 2 wires togther bypassing the toc, it will now work okay
Jul 09, 2007 | AEG B1180-4 Electric Single Oven
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
AEG D2100-4 Electric Double Oven Logo
211 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
