Question about HP Photosmart C7180 All-In-One InkJet Printer
Just trying to print 2181 Avery Laser Labels - "Paper Size or type is incorrect"
I have tried the Avery Wizard and have gone through Word to choose 2181. Should be no big deal - but get Paper Size message. This has happened before. I am using regular tray (not photo tray)
Thought this would be my one great (not cheap) printer for photos and everything! Sob! Thanks for any help! Patty
  • Anonymous May 20, 2009
    same problem. after 2 hours of just simply trying to print 12 file labels I am planning to take the printer back to the store. Just on principle. If I want to stick a 4x10 sheet of paper in the damn thing and print then let me. I can print out on plain white paper but the minute I stick the label in, notta, nothing, error message.
I have had this same problem trying to print DVD lable sheets.
I spent hours trying to work it out, HP support said it was the software(hmmm)
The answer to the problem is, the printer senses the printed block colour band on the preprinted lable sheet. I am using Fellowes - Neato DVD tempate sheets which have a black, block of colour on the leading edge, I'm not sure about Avery.
I found the quick fix is, turn the sheet around end for end against the manufacturers instructions. The opposite end is plain and goes through OK. You may have to calibrate the software to compensate if the printing starts in a different position this end, my sheets are the same within about 1mm.
You could also cut the block colour off the sheet if the direction was critical, and make allowance for the starting position.
I find the printer is good apart from this problem.
I hope this helps, it worked for me.
Regards, Rob.
Posted on Mar 17, 2008
  • dougandanne Aug 12, 2011
    I couldn't believe that just turning the labels around would work but it did!!!! Had I not read this, I would have spent even more time trying to figure out why the printer was reading the labels as a photo. Thanks for the help!!!
How do I center the label on my printer so it prints in the middle
there should be a setting in the printer setup that gives you options on how you want the printing set up, such as maximum, border, no borders, and centered. Use the preview to be sure of it before printing.
Nov 03, 2014 | Avery Dennison Ave-2181 Filing Mini-sheet...
Avery labels set
try going to driver printing preferences /paper or paper/quality tab and set your size for custom and to the 4 x 6 specific size for that sheet and the type as labels for tray 1.
Oct 21, 2013 | HP LaserJet 1020 Printer
Im trying to print avery labels but my printer does not have a setting for it
Normally support for printing Avery Labels is found within the application you are using to create the labels to be printed, i.e. in Microsoft Office Word or similar publishing programs. . . .Avery provide a Wizard extension to use in Microsoft Word to help you to produce and print on their labels. . . .See http://www.avery.com/avery/en_us/Templates-&-Software/Software/Avery-Wizard-for-Microsoft-Office.htm for further details and to download the Wizard. . . .Note: You need to allow Macros to execute within Microsoft Word in order to use the Avery Wizard.
Sep 22, 2011 | Epson Stylus NX400 InkJet Printer
Which labels for 6310 HP pinter?windows viista progar? 8160labels do not fit 6310 priinter
Vista wouldn't be your problem as your Operating System is unimportant in choosing labels but the program you use to print your labels is very important.
If you Use Microsoft Word, for example, you will need to choose the template for your labels. That number is on the box of labels.
In Word (for Instance) you can do the following:
<File>, <New>, <Templates> (templates are on Left side).
Choose your Type of Label and the Label number from there.
Otherwise, some label companies offer free programs, specifically for printing their labels.
AVERY labels has a free program for printing their label numbers and the Program: AVERY Wizard For microsoft Word is free.
I hope this helps as you do not say which program you use to print Labels and you also do not say which label numbers and/or label type you wish to print.
Thank You For Choosing FixYa~!
Mar 24, 2011 | HP Officejet 6310 All-In-One InkJet...
Hi I am trying to print labels. Avery #05161 and business cards Avery8371TM or 5371TM. I am using Microsoft Office and there do not seem to be any relevant numbers. I have gone under labels. Help Thanks
You can use a different template for either the labels or the business cards, just make sure the labels you choose are the same size as the avery 05161 & the business cards are the same paper eg: glossy etc. The other thing you can do is go to avery.com & download the correct templates.
I hope this helps you
Jan 21, 2011 | Avery Address Labels AVE4151
How do you type and print Avery labels 74520? I have lost the instructions which came with the labels.
This can be done with settings through your word processing program. Assuming you are using Word:
Microsoft Word 2007
The newest version of Microsoft® Word now includes hundreds of Avery Templates for labels, business cards, dividers and more.
Find Avery Templates by selecting the Mailing tab at the top of the Microsoft® Office Word screen. Just choose Create > Labels > Options > Avery US Letter, then choose your template by selecting the correct Avery Product Code.
Access Pre-Designed Avery Templates that are available from Office Online by selecting the round Office button at the top left of the screen, selecting New and then choosing the Avery product type. Pre-designed templates for Avery business cards, greeting cards, dividers, labels, note cards and postcards are available.
Avery Wizard for Microsoft Office is a free download which inlcudes step-by-step instructions to format Avery labels. Trust this is helpful. :)
Dec 08, 2010 | HP Officejet 6310 All-In-One InkJet...
Problem printing labels
These labels are supposed to be for laser or inkjet . A inkjet basically sprays the ink to print. A laser deposits plastic powder and then uses heat to melt it or fuse it to the paper. To get a good inkjet print you need a softwaer paper, to get a good laser print you want a harder paper and a glue that can handle the heat. I had a quick look at customer complaints on that product and you are not alone. Either the printing is coming off (inkjet) or the label is coming off inside the printer.
One of the other problems with labels in lasers can also be how the paper is printed. The paper can be rolled around a few rollers and drums. This action can be pretty close to how you peel the labels off of the backer sheet. Add a bit of heat to make the glue loosen up a bit and you get your problem.
Setting to thicker paper should have helped but the best thing you could do is print it flat. Most laser printers have a back tray that is usually closed. When opened the tray lets the paper come out without having to go around rollers. If your model doesn't do that about the only thing I could suggest is to try to print the labels on a cold printer. So that would mean one page or so at a time with a wait for it to cool down. You could also try a differant brand or another avery type but you may end up with a label collection if they prove to have the same problem with your printer.
Apr 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
How do i transfer a list of name to #02180/02181 avery
Microsoft word has the avery stuff in it. This is from another site
Try this:
In Word versions prior to Word 2007 (Vista):
1. Click the Tools->Letters and Mailings->Envelopes and Labels menu item.
2. Click the Labels tab.
3. Click the Options button.
4. Find that label in the list box. Avery tends to use four-digit product numbers, so I'd take a look at the 2181 type and see if it fits the size and description of your labels.
5. If you find it, select it and click OK.
From there, you can make a full page of the labels by clicking New Document, or, if you want to print the same label a few times, you can print a short batch directly with the dialog box.
In Word 2007:
1. Click the Mailings tab on the Ribbon.
2. Click the Label icon.
3. Continue with Step 3, above.
Hope that helps.
Sep 15, 2009 | Microsoft Windows XP Home Edition
HP Photosmart C7180 All-In-One InkJet Printer Logo
1,004 people viewed this question
Seeker5211
Seeker5211
