Question about Rival Patton Electric-A Company Power Heater, 1000 + 1500 Watts, 2 Settings, Handle, Gray
I have a Rival Patton heater IH268. One of the "bolts" that supplies power to the heating element is burned. The element connects directly to this bolt.. It appears to be stainless steel. Is there a replacement or a way to make something else work.. This is a 240 heater, 4000watt.
  • wigjimmy Jan 30, 2010
    Actually part of the bolt has burned off on the threaded portion. I managed to get the heater working but that bolt needs replacing because It's not long enough now & I am afraid it will give problems.. It isn't a common bolt by any means.. . The head is made up of 2 "discs" with the end of the heating element sandwiched between them & it appears the discs are squeezed onto the end of the element.. I checked Lowes here & they have stainless bolts , etc but I didn't find anything that looked like I could make it work. It is a very good heater other than that one problem..
  • 291 Answers
The bolt is there to hold the element in contact with the wire that connects the electricity to it. If the connection is not good, it will get hot there instead of in the element, and eventually the connection will get even worse and get hot enough to discolor it.
You could try to take it apart, (make sure you unplug it!!!!) clean off the burned parts, and then connect it back together tightly. If you have an ohmmeter, you can check the element easily. It should be around 14 or 15 ohms. Once you get it cleaned and back together, you should be able to check the resistance between the two hot wires on the plug and get a reading thats not too much higher than what you read on the element itself. Shouldn't be more than an ohm or so more. When you do that, you should also check the metal parts of the heater (not the element, the case or frame) to the ground wire on the plug. The resistance here must be less than one ohm.
Posted on Jan 30, 2010
  • San Juan Vet Jan 30, 2010
    If it's held together tightly and the resistance from the plug to the element is less than about a half ohm, it'll work okay. The possible problem is that the connection either has a high resistance and will overheat, or that it is not strong mechanically and will come loose. As long as it's tight and strong mechanically and the resistance is low (should be less than 0.5 ohms), you'll be fine. If you can't measure directly on the connection, look for the resistance from hot to hot on the plug to be less than an ohm higher than the element resistance as measured directly on the ends of the element. This can be higher since you'll have to go through the thermostat and switch.
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Fan cuts off, but still feel heat
I have had a element brake or burn in too and one of the strands falls and touches the side of the case which then acts as a ground and since there is power on one side of the circuit it will still produce heat and won't shut off. It won't trip the breaker because it is not a direct short because of the resistance of the heating element. To check this.... turn off all of the power to the heater and pull the heater out of the heater or if you can open up the duct work to see the heating element to see if that is what has happened.... Also a contactor could of welded shut and is supplying power to the elements. Hope this helps....
Jan 30, 2014 | Heating & Cooling
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Dec 23, 2012 | Patton Electric Patton PUH680-U Electric...
Patton MH761 coil wire can these be replaced? The wire only heat about an 1/8 of the total length and does not produce much heat. I asked about it at the local hardware store and they indicated that the...
Nickel Chrome hard wire in coils for heater element are not worth stocking as new complete heaters are very inexpensive and as a qualified electrician must fit it, to replace the heater element is not cost effective.
Jul 15, 2017 | Patton MH761 Utility Heater
This water heater has two elements, correct?? Well how do you get them out?
The first thing to do is shut off power supply to the heater. Then while water is still on hook up garden hose to drain valve on bottom of heater. Place hose to floor drain or some other location for safe drainage. Open drain valve and if it starts draining at a good rate then shut water supply valve off to heater. You will want to open hot side of closest faucet to prevent vacumn which will slow or stop draining. After heater is done draining shut off drain valve and faucet . Remove the cover plates on top and bottpm of heater. Usually four small screws. Locate heating elements and disconnect wiring,label if you need to for reinstallation. There are two kinds of heating elements,one is held in place with 4 hex head bolts,and the other is screwed in. If yours has the bolts carefully remove to avoid breaking bolts.Then just pull out to remove To reinstall there will be a new rubber gasket with element, fit it in place and insert element back in heater. Reconnect wires. If there are no bolts apparent then the element screws into heater. You will need a pipe wrench or large wrench to remove the element. The same thing with this element is that it should have a new rubber gasket. Put gasket in place and wrap threads with 5 to 6 wraps of teflon tape. Install element and tighten snugly. Connect wires,refill with water and check for leaks. If no leaks then turn power back on. Put cover plates back on and you're done. I hope this helps you. Thanks
Nov 19, 2010 | Audiovox Richmond 6EM30-2 30-Gallon 6-Year...
Heating element
There should be a fuse located on the back towards the bottom. It should have a screw in cap holding fuse in plase.Remove fuse and see if you can tell if its blown. If your not sure you can try new fuse of right size and amp rating.Amp rating should be stamped on end or around base of fuse. If this helps thats great. If not and you think heating element is burned you probably better off to just get new one as the price of new element and possible other parts will cost you as much or more than buying new. Hope this helps. Thanks
Nov 08, 2010 | Patton PUH680-U Utility Heater
Model PT 268 heater doesn't work at all but seems to have voltage
Yes it would seem that the thermostat or the knob would be the problem...when checking for voltage you need to check for 220v across the two terminals for the heating element. You will have 120 feeding back and forth all over the place but the fan and element will only work if they have 220... so you can have voltage and it still not work...
heatman101
Apr 23, 2010 | Patton Electric Patton PUH680-U Electric...
How do you wire a thermostat to the heating element and then to power . it is for a water tank in a truck that plugs into 110.
you have to put the thermostat in line with the hot side of power supply then to heating element nuetral connects to element directly
Apr 11, 2009 | Water Heaters
When the alarm on the Patton Electric Heater sounds, whay does one do to fix that?
This heater was the determined cause of my total loss house fire. I thought the company would atleast help me find some where else to live, they seem to care. But, as of lately they are doing nothing.
I am told this heater-(prh11- 2008 model- purchased at walmart for about $27.00)
- Had wiring that wasn't up to standards
-1/10,000 units cause fires
-something wrong with the heating element-stops working
- wouldn't stand level
-heating coils
-fires like mine have happened to a few other people
This came directly from a person at Jarden corporation(aka patton-sunbeam)
Jan 05, 2008 | Patton Electric Patton PUH680-U Electric...
Rival Patton Electric-A Company Power Heater, 1000 + 1500 Watts, 2 Settings, Handle, Gray Logo
42 people viewed this question
Top Rival Heating & Cooling Experts
t-stat
Level 1 Expert
Are you a Rival Heating and Cooling Expert? Answer questions, earn points and help others
