Question about RIM BlackBerry 7100G Smartphone
Bluetooth connect option is'nt available in option window
    Sniper:
  • 55 Answers
You need to pair the device first. If you have already paired the device then blackberries soltion is not very happy see below:
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB03393&sliceId=SAL_Public&dialogID=129220212&stateId=0%200%2058063448
If you need help pairing your device, post a comment and I'll walk you through that.
Good luck
Posted on May 03, 2008
How to activate bluetooth on asus k55a
Asus manufactures computers, notebooks, motherboards and other PC components. Some of their machines have Bluetooth capability. You can use prompts in Windows to make sure that your Asus's Bluetooth capability is up and running.
Open Bluetooth Settings
In the task bar, right-click the Bluetooth symbol, then select "Open Bluetooth Settings." If there is no Bluetooth icon in the task bar, go to "Start," then "Run" and type in "bthprops.cpl." Click "OK" to open the Bluetooth Settings window. b> View Options b> Click on the "Options" tab, and select the "Turn discovery on" check box. Click "Apply." b> Allow Devices b> In the "Connections" section, select the check box for "Allow Bluetooth devices to connect to this computer" so that Bluetooth devices can connect to your Asus. Click "OK." b> Testing for Bluetooth b> If you are unsure whether your Asus is Bluetooth capable, try typing in the "bthprops.cpl" command in the "Run" box. If it's unsuccessful, your machine isn't Bluetooth capable. Hope this helps.
Dec 08, 2012 | Computers & Internet
How is a using a smart blutoothe
Sony Ericsson phones have built-in Bluetooth capabilities which allow them to be connected to a computer or a Bluetooth-enabled accessory such as a headset or speakerphone without using wires. Since Bluetooth does take some power to operate, most Sony phones default to having the Bluetooth powered off to conserve battery power. You can power on the Bluetooth on your phone fairly quickly.
Step 1
Press the "Menu" button on your phone and then select "Settings" from the available options.
Step 2
Select "Connectivity" from the Settings menu, and then select "Bluetooth" from the available options.
Step 3
Select "Turn On" from the Bluetooth menu to power on the Bluetooth on your phone. If you only have a "Power Off" option, then your Bluetooth is already powered on.
Dec 04, 2011 | Sony Ericsson Cell Phones
How do i connect the bluetooth?
depending on your device usually there will be a bluetooth connection on the device which plugs into a usb port on your computer
you will have to make both your computer and the device enable bluetooth connection(make it discoverable) you might need to download some bluetooth drivers or software to activate your blutooth device
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetooth-driver-ver-5/3000-2110_4-149801.html
to suit multiple usb devices
· Operating system: Windows 95/98/2000/XP/2003/NT/XP 32-bit/AMD 64-bit/2003 32-bit/AMD 64-bit
hope this helps
Aug 24, 2011 | ASUS Computers & Internet
Tell me how to connect internet from mobile i009 to bluetooth?
At first call to your customer care executive to send you for internet settings for your mobile. When you recive the settings then do the following things-
  • Install the settings first.-go to your message inbox and find the settings message when you open it then get the install option. Just click on install option.
  • Select your internet profile-just go to your internet menu and select settings. After that select Internet Profile and select GPRS option like Airtel Gprs/ Mobile Office if you are Airtel user.
After that Install Pc-Suite and
  1. Activate Bluetooth on your mobile phone (usually found under the Settings menu) and set it to be discoverable or visible.
  2. On the PC, find your Bluetooth program manager (in Windows XP and Windows 7, look under My Computer > My Bluetooth Connections; in Vista, look for Bluetooth devices in the Control Panel; on a Mac, go to System Settings > Bluetooth).
  3. In the Bluetooth program, select the option to add a new connection or device, which will make the computer search for available Bluetooth devices and find your phone.
  4. When your mobile phone appears, select it to connect/pair it to your laptop.
  5. If prompted for a PIN code, try 0000 or 1234 and enter it on both the mobile device when prompted and your laptop.
  6. When the phone has been added, you will be asked what service to use. Choose PAN (Personal Area Network). You should then have a working Internet connection.
May 18, 2011 | Computers & Internet
The computer comes with bluetooth but there is no icon in controll panel
By typing fsquirt in run command,a bluetooth file transfer wizard opens.
But before that you should check the following.
When you install a supported Bluetooth adapter in Windows XP SP2 or any Windows OS, the adapter becomes active together with the following Microsoft components:
  • Microsoft Bluetooth Enumerator This component enumerates Bluetooth devices and capabilities.
  • Bluetooth Device (Personal Area Network) This driver supports Personal Area Network (PAN) connections between devices.
  • Bluetooth Device (RFCOMM Protocol Transport Driver Interface [TDI]) This component supports dial-up networking (DUN). It also supports other types of connections between devices.
  • Bluetooth Support Service (BthServ) This service maintains and updates device pairing information. It also performs other functions that are related to Bluetooth features.
These components are available in Device Manager after you install a Bluetooth adapter. Other drivers and components are also installed.
The Options tab in Bluetooth Devices provides options that control how devices discover and connect to your computer. The main option is Turn discovery on. This option lets devices discover your computer so that you can make a connection.
Other options on this tab include the following:
  • Allow Bluetooth devices to connect to this computer This check box controls whether any devices can connect to your computer. If this check box is cleared, no devices can connect to your computer.
  • Alert me when a new Bluetooth device wants to connect This option controls whether you receive notification when a device tries to connect to your computer. If this check box is cleared, you do not receive notification.
Other options on the Options tab let you turn on or turn off the Bluetooth icon in the notification area and restore default settings.
Sep 05, 2010 | Dell Latitude D410 Notebook
Could not found the bluetooth connection or device
Make sure you have every driver for your laptop loaded. Then let's suppose you want to connect your phone to the laptop bluetooth: Turn on the bluetooth in your mobile and make it visible to the other bluetooth device then only your handphone will detect the other bluetooth device and viceversa. Most of the recent notebooks are having bluetooth enabled but in some notebooks we need to turn on the bluetooth by using the buttons which indicated as bluetooth. Once you turn on then get into your computer running windows vista type this following command in the search box or in the run box "ncpa.cpl" it will take you to the network connection window [you can even use control panel option to reach the network options]. In that window where you find the bluetooth connection.Click the icon first and look it on the top of the window where you can see an option "Connect the the bluetooth"click it then you need to add the bluetooth device click add. It will find your hand phone then it will ask the passpharse key you can create one and then your handphone alert you to type the same key that u given in the notebook.Once it matched it will connect automatically. Later type bluetooth in the search option where you will get an option as Bluetooth(Transfer files wizard) . Click it then you receive or send the file via bluetooth between your notebook and handphone. Hope it helped.
Aug 05, 2009 | Lenovo 3000 N100 Notebook
SAMSUNG SH L700
It depends upon the connection you have on your phone. To acess internet from your mobile go to the homepage of the company's connection and follow the instructions one by one.
Jun 26, 2009 | Samsung SGH-L700 Cell Phone
I cant see a bluetooth device option in my control panel of windows vista
To see the bluetooth option be available on the control panel
u have to install the bluetooth driver for windows vista,
that depends upon ur motherboard configuration.
thank u..
Feb 01, 2009 | Microsoft Windows Vista Ultimate Edition
Considerations for Windows 2000 - WorkPad c500/505
The WorkPad c500 and c505 can be used only with PCs running Microsoft Windows 98 or Microsoft Windows 2000 operating systems. NOTE: Microsoft Windows 95 and Microsoft NT 4.0, or serial connectivity, require a serial HotSync cradle or cable, available separately from Palm, Inc. The WorkPad HotSync utility will not sync via IR when the host PC is running Windows 2000.
Sep 14, 2005 | IBM WorkPad c505
Sep 14, 2005 | IBM WorkPad c500
RIM BlackBerry 7100G Smartphone Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
