Question about Frigidaire Affinity ATF7000E Front Load Washer
Washer will not spin was told to replace control board did this problem still exists
  • russ_smiley Jan 30, 2010
    Video shows a top loading machine obiously this will not work for a front loading machine water would spill out?
    When I mash the door button with my finger I hear it click also if I let go the dr lock led comes on only goes off when I close the door
  • 1,531 Answers
This could be a door lock issue. how ever the first thing to check is the drain pump for anykind of obstruction.there is a plastic coin trap in the boot that comes from the tub to the drain pump this could be clogged.
Posted on Jan 31, 2010
  • seth adams Jan 31, 2010
    you should not be able to mash the door lock with your hand.if it is not staying locked the you lock mechanism is broken and needs to be replaced.
    Brigadier General:
  • 3,513 Answers
Do you hear the lid switch click when you close the lid of the washer. The maximum times we have seen the reason of a washer not spinning is a bad lid switch. Please check out the bellow mentioned article how to go ahead and check it or get the part number to replace it.
http://repair2000.com/nospin.html
Thanks
Posted on Jan 30, 2010
Asked about a problem with the spin cycle. Was told the problem was in the control board. Could not find it in parts Would that be the same as the dial for selecting the wash cycle
The dial is rarely broken. The cycle and the times for each part of the cycle are control by the main control board. If your spin cycle isn't working it might be the control board depending on what exactly the spin cycle is doing. The boards are usually kind of expensive (about $150).
You can take the chance and buy a board from an online place like:
http://www.appliancepartspros.com/search.aspx?q=control%20board
(which gives returns if you have the wrong part).
First of all though, you should go to YouTube and type in "replacing a control board for a GE washer" and you will get plenty of troubleshooting and instructional videos to help determine which part actually is failing,and to get that repair done
Good luck
Nov 20, 2015 | GE WSM2420T Top Load Stacked Washer /...
My kenmore elite calypso will not do final spin.flashes LD. I replace the pump as was suggested,still did not fix froblem
Hello Alex;
My name is Peter. I am a retired field service appliance technician.
After review of your washer components, there is a strong possibility that you have a bad electronic control board. You have two control boards, one is for the motor and one for the other functions.
Washer electronic control board for Kenmore Elite Washer model #11021062001 Electronic control board 8571359 is the circuit board that manages the washer's functions, such as filling, washing, draining and spinning. It sends voltage to the drive motor and other electro-mechanical component.
Cost: $218.00
If you elect to replace the board make sure you ground yourself by rubbing your hands on something that is bare steel. Static electricity will knock a board out.
All appliances with electric control boards should have a surge protector. You can purchase a wall socket surge protector for $20-25.00. It is a good investment considering how expensive control boards are.
Rule of thumb; "If the unit is either 7 years old or the cost of repair is 1/3 or more of the original price, purchase a new unit.
Consider it purchasing a new unit, stripping your existing unit for parts to sell on e-bay. You will make a little money and save others expensive parts cost.
Dec 03, 2014 | Kenmore Washing Machines
DOES NOT SPIN DRY EACH TIME
HI. This will, normally, occur if there are serious issues that concern the integrity of your control sector. This sector can be a timer module, or a control board, as well.I would advise to force a control reset, by shutting down the appropriate circuit breaker for five minutes. You may, also, unplug the unit, as well. This procedure will initiate a control reset, and may correct this issue that exist within the control sector.
Once the five minutes have passed, simply re-introduce power to the unit, and try a normal washing cycle. Observe the units actions during the spin attempt. If it fails to spin on time, this will confirm that the control sector(timer, or control board), is damaged. It will need to be replaced, in this case.
Nov 21, 2009 | Maytag Atlantis MAV6451 Top Load Washer
My fridaire front load washer will not spin at high speed
HI. Your unit is equipped with a Motor Speed Control Board. This board regulates the spin speed, with the help of a tachometer, which, is located and mounted on the motor. When this Control board is experiencing issues, the spin will not preform at optimal performance. I recommend to replace this Motor Control Board asap. Once replaced, the unit will spin properly.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Is the washer worth fixing? My washer stopped
Without looking at unit would most likely be door latchlock or motor control board that is the board that is located at bottom of unit under tub/if someone told you it needed more than one board that is highly onlikely/don't think i every changed more than one board at a time. Questions czerney@msn.com
Oct 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Apr 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Stops during cycle. Door stays locked. Won't reset to restart.
Hi, here is a procedure that you can preform to reset the board(control). if the same problem exists after the reset, you may have to call he service tech.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press HOLD TO START. If the problem
remains, call for service.
Feb 20, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Wont spin at end of any cycle
I am a service technician in grants pass oregon and i had the same problem. It told me to replace the board too. I replaced the main boad, Motor control board, door switch and cleaned all the hoses and it still didnt fix it. I had 3 other service technicians look at it ( one from sears ) And nobody could figure it out.
Feb 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front load washer wont spin
yes. the solinoid or wax motor (depending on which switch you have) has fail and is not telling control that the door is locked. replacing the switch will fix it
Nov 20, 2007 | Kenmore 44102 Front Load Washer
Open the rear panel and look for a broken belt and does the motor spins. In case motor doesn't spin, check on its tags for 115/220V. Let me know with your results,for further assistance if will be needed. Good luck!
Aug 28, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
