Question about Sony PlayStation® 3 (60 GB) Console
Ps3 connection error 80710704 how do i fix this
What means 80710092 error code?
hi there,
not sure if you have solved this problem already, but the error code is related to the playstation network and not been able to connect to it for whatever reason(there could be many). I've attached a link below to try and solve the problem for you(if you already have not done so. Thanks.
Tutorial on How to Fix PS3 Error 80710092 eHow
Aug 24, 2014 | Sony Playstation 3 (PS3) Console
Tip
Check Your Playstation 3 Error Code
<span style="font-weight: bold;">Error Code - Meaning/Suggestion/Possible Fix:<br /><br /><span>0710102 - DNS Error: No DNS server available.</span><br /><br />80010001 - Major Error, Game ability stopped.<br /><br /><span>80010006 - An error occurred during the start operation. - Corrupted folding install.</span><br /><br />80010007 - An error occurred during the start operation. - During the (internal) hard drive disk swap tests. suggests a failure with the hard drive.<br /><br /><span>80010017 - Can't start Blu-ray Game</span><br /><br />8001050B - Will not play demo game from the hard drive. When a Blu-ray disc is inserted. - Cause unknown".<br /><span><br />8001050D - An error occurred during the start operation; PS3 game swapped using the eject function and then play pressed quickly. - Insert PS3 game again.<br /></span><br />80010510 - Will not play games installed on the hard drive. - Cause unknown.<br /><br /><span>80010516 - An error occurred during the start operation: PS1 game swapped using the eject function and then play pressed quickly. - Insert PS1 game again.</span><br /><br />80028EA5 - Unknown. User cannot connect to Playstation Network ("PSN"). Contact Sony for resolution.<br /><br /><span>80028EA6 - Connection Error: Turn off PS3, unplug router and modem. Turn on modem and allow it completely boot-up and synchronize. After the modem shows that it is "online", then plug in the router and allow it to completely boot. Lastly, plug-in and turn on the PS3.</span><br /><br />80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic.<br /><br /><span>80028F17- PS2 Disc Boot Error. An error occurred during the start operation: PS2 game swapped using the eject function and then play pressed quickly. - Insert PS2 game again.</span><br /><br />80028F18 - PS2 Disc Error. Unsupported disc: eg. Utility discs, BB discs, IQ Remix game etc.<br /><br /><span>80028F19 - PS2 Disc Error. Fsck: the internal PS2 disk was corrupted. You may be able to use the HDD utility disc to fix it (use with caution), otherwise, contact Sony.</span><br /><br />80028F1A - PS2 Disc Error. invalbnnetcfg: network config error.<br /><br /><span>80029023 - Exchanging Key Information: exchange has timed out.</span><br /><br />80029024 - Cannot obtain an IP address. DHCP failure. Check network connection, modem and/or router.<br /><br /><span>80029301 - An error occurred during the delete operation: attempting to delete PS2 data from virtual memory card.</span><br /><br />80029513 - Copyright Violation when attempting to install game.<br /><span><br />80029516 - Sign in to PLAYSTATION-Network: needed for some games or PS3 processes. Sign-in is required for current operation/request.</span><br /><br />80029564 - Downloaded game will not install: Cause unknown.<br /><span><br />80029945 - Can't playback burned BDr movie: Error in picture.</span><br /><br />80029946 - Attempting to play burned Dual layer NTSC disc on a PAL PS3. The workaround is to transfer files to the PS3 via TVersity.<br /><br /><span>80029C68 - Corrupt data. Usually on an external device.</span><br /><br />8002A10D - Unable to Add friend in XMB. (Normally because you have reached the limit of (100 friends)<br /><br /><span>8002A4A6 - Cannot load game to play online.</span><br /><br />8002A515 - Error Signing in.<br /><span><br />8002A548 - Unable to remain logged in. Either due to game or server.</span><br /><br />8002A705 - Unable to connect to server/host. If you are using a router, check port/DMZ configuration.<br /><span><br />8002A71A - Possible NAT Error. Can log into Game Server but can't join game and can't host game. Turn off the PS3 and wait for 5 minutes.</span><br /><br />8002B241 - DVI has no audio.<br /><span><br />8002F994 - Too many people currently downloading the update. Server(s) at capacity. Wait and retry</span>.<br /><br />8002F997 - Trying to Update the XMB Firmware: Copying to a file and installing from a USB drive failed.<br /><span><br />8003041F - An error occurred during the copy operation. (Using media server)</span><br /><br />8003051E - Game will not Save.<br /><span><br />80030920 - An error occurred during the copy operation. The file may be corrupt or there isn't enough memory. Try copying data from original source.</span><br /><br />80031150 - System Settings Fail to Save. Possible Blue Screen Setting information is corrupted.<br /><br /><span>80031601 - Error Creating Account.</span><br /><br />8013013D - A connection error has occurred: Causes may include the actual SSID of the wireless access point/router or signal strength. If the connection drops, try enabling DMZ functionality on your router (if supported) for your PS3. Otherwise check WPA key. The PS3 wireless interface [currently] does not support WPA2 - only WPA, WEP or none.<br /><span><br />8013013E - WEP Key error: Change WEP key to *only* numbers and try again, or switch to WPA.</span><br /><br />80130203 - PS3 connects to the internet (you can go a website via the PS3's browser), but cannot connect to the Playstation-Network. Typically this means that the required ports are not open/accessible. Check your router's configuration.<br /><br /><span>8013030 - System Error: Due to failed update download.</span><br /><br />8013030F - Access Point was not detected. Check your router's configuration and make sure that SSID broadcast is enabled.<br /><span><br />80410418 - DNS Error.</span><br /><br />80410A0B - Internal error: "Hardware Fault". Send unit back to be replaced/fixed.<br /><span><br />80710016 - The Playstation Network is down.</span><br /><br />80710092 - "An error has occurred. you've been signed out from the Playstation-Network". Connection dropped? If your PS3 is wireless (least preferred), the association between the PS3 and the access point may have been dropped. You may need to "reboot" your PS3 if your PS3 and router are unable to establish an association.<br /><br /><span>80710101 - Connection error.</span><br /><br />80710102 - IP Address conflict. PS3 cannot connect to your router with it's current IP Address information. Try rebooting your router and PS3. Occurs when two devices on your network have the *same* IP Address.<br /><br /><span>807101FF - An error occurred during communication with the server. This is a DNS error. It occurs when your PS3 tries to perform a DNS lookup to connect to the server.</span><br /><br />8071053D - Hard boot the PS3. Turn off the PS3 via your controller (this is stand-by mode), Turn off the PS3 switch on the back of the PS3 and remove the power cord. Next, turn-off/unplug your modem (and router if applicable) for about 5 minutes. Then turn on the modem and wait for it go "online". If you have a router, turn it on and wait for it go "online". Then turn your PS3 back on and make a new network connection.<br /><br /><span>80710541 - The connection to the server timed out. This is usually due to: high traffic (between you and the server), high traffic at the server [itself] or you have a "poor path" to the server. Depending on result: Press the 'X' button to repair and restore default.</span><br /><br />80710723 - Possible Port Error: Try opening ports. Configure your router to pass the following ports to your PS3:<br />TCP ports: 80, 443, 5223<br />UDP ports: 3478, 3479, 3658<br />Another option is (if your router supports DMZ functionality) to configure your router's DMZ functionality to pass traffic to your PS3.<br /><br /><span>80710A06 - An error occurred during the install operation. Error when downloading game from the Playstation-Network. An error occurred.</span><br /><br />80710B23 - Playstation-Network is down or Playstation-Network is too busy to respond.<br /><span><br />80710D23 - Turn the PS3 off for a bit. For 30 minutes give or take. Make sure that you either unplug or actually turn off the switch (located on the back of the PS3). "Stand-by" mode is when you see the red LED on the front of the PS3. If you see the red LED on the front of the PS3, your PS3 is *NOT* off.</span><br /><br />81019002 - Error copying saves from location "A" to location "B" not open to connect to store but PS3 can connect to internet.</span>
on Feb 21, 2011 | Sony Playstation 3 (PS3) Console
Tip
Fix PS3 - PS3 Repair- PS3 Fix - PS3 Problems
Ok so I have written this tip from my experience of repairing playstation 3 consoles for the past 3 years.
I can tell you the best aid I ever had was a PLAYSTATION 3 EXPERT REPAIR GUIDE I believe in them so much I have even spent quite a bit of money to build a website dedicated to them.
http://www.ps3problemsgone.info
WHAT IS A PS3 REPAIR GUIDE?
Well to put it in the most simplest terms, the ps3 repair guide is an ebook written by expert ps3 repair men, The good thing is its written in such a way that the absolute beginner can do a successful fix. The guide has step by step instructions that are easy to follow and will have detailed pictures.
Also when you purchase the guide you get free instant access to a members website where you will find Video guides on all fixes and a dedicated 24/7 support team that will help with any repair you are doing.
WHERE TO FIND YOUR PS3 REPAIR GUIDES?
What I will do now is list what I feel to be the Top 3 ps3 repair guides online today
NUMBER 1: FIXES ALL ERRORS - YLOD REPAIR WIZARD Full Review -
YLOD REPAIR WIZARD - Official Site
NUMBER 2: FIXES THE MOST COMMON ERRORS - PS3 LIGHTS FIX Full Review -
PS3 LIGHTS FIX Official Site
NUMBER 3 FIXES THE MOST COMMON ERRORS - PS3 FIXER Full Review -
PS3 FIXER Official Site
1.Ylod (yellow light of death)
2.Red/blue/green flashing light error
3.Disk read error
4.Hard disk corruption
5.Sync errors
6.Blank/red screen error
7.over heating
8.Freeze ups
9.network connection errors
10.No display
MY WEBSITE WILL GIVE YOU FULL DETAILED REVIEWS ON EACH PS3 REPAIR GUIDES THAT I HAVE USED MYSELF SPREAD OVER THE PAST 3 YEARS.
AGAIN MY WEBSITE http://www.ps3problemsgone.info
on Aug 27, 2010 | Sony Playstation 3 (PS3) Console
The playstation 3 does not work with certain games saying there is an error on the router (error code: 80710723) How can we open more ports on the router? Thanks for your help
Generally what happens is that progress will stall whilst you are trying to update the firmware or software/games on your PS3, causing it to be corrupted. Your console is then unable to function properly, and you are left trying to "pick up the pieces" as it were. The PS3 error 80710723 is one of these system update errors, and is often experienced by gamers who use wireless connections to update their firmware or games.
So how can you fix PS3 system update error? Here are a few steps you can take to try and fix the 80710723 error code yourself.
  1. In your System Options/Network Settings you need to go and disable a setting called "media server". Doing this has been reported to fix the PS3 system update error in a number of different cases.
  2. If you are using a wireless network connection then switch to a wired connection and attempt to update your console. Wireless connections can have interference, or fail from time to time. Therefore it is better to use a wired Internet connection where possible.
  3. As a last ditch resort you can actually download the update from the Sony website onto your PC, then load that update onto a USB stick and plug it into your PS3 and carry out the update process from there. However, it is best to actually try and fix your connection problems first.
Jan 04, 2011 | Belkin N1 Vision Wireless-N Wireless...
What does it mean when the orange light on the ps3 flashes?
f there is an orange light on your PS3 then there are a few basic steps you need to take that stand a good chance at being able to fix your console. Firstly, check that all the cables and leads are correctly attached to your PS3. Sometimes a cable or lead may have become slightly unseated if you moved your PS3 or somebody/something bumped into it. Remove every lead and cable and then re-attach them, one by one.Next, power down your PS3 and leave it switched off for at least 30 minutes. From time to time the Playstation 3 orange light error can be caused by overheating, so by turning it off and leaving it you will give your console a chance to cool down. However, it is important to note that this is only a temporary fix to your problem, and the orange light error on your PS3 will come back.Finally, ensure that your PS3's network connection is working properly. If you connect your console to the Internet via a wireless connection then this connection can sometimes be interrupted, thus causing problems with your console. Turn off your Internet modem/router and then reboot it. Also, try using a wired Internet connection to your PS3, if this is possible.By following the above steps you may be able to fix the PS3 orange light error.
Jan 03, 2011 | Sony Playstation 3 (PS3) Console
What is a dns error and how do i fix it
DNS error occurs when your internet connection is fluctuating and your PS3 console was unable to detect an active internet connection. This is not a problem with the PS3 System as it much more of your ISP or internet service provider which is disconnecting.
May 10, 2010 | Sony Playstation 3 (PS3) Console
Error when connecting to the internet: error (80130804).
This means that your PS3 is not able to get an IP address from your wireless network/router. I would suggest set the IP address manually on your PS3 including the DNS IP address.
May 11, 2010 | Sony Playstation 3 (PS3) Console
Wot error is 80710723????
You have a network/router error. First go to settings, then Network settings, then internet connection settings. If you have a wired connection connection 1 - Custom, then manual settings, then auto detect, then automatic, then Do not set, then manual, DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220, then auto, then do not use, then enable.
If you are using a wireless connection 2 - WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X
and if neither of these works then try turning off your modem for a few minutes and restarting your ps3 =)
May 06, 2010 | Sony Playstation 3 (PS3) Console
Ps3 error 80010201
this error means that a cable is unplugged or some thing like that: last night, my ps3 got a YLOD and because of that i had to open my ps3 and fix it(using gilksy method(it really works!)), after i reassembled my ps3, I got a 80010201 error and realized that my ps3 doesn't recognize controllers at all(even after i connected them to ps3 using USB cable). anyway, i reopened my ps3 and check all the vires and connections and reasembled my ps3 again, the problem was solved. so if you got the same problem, just open the thing and check all connections and unplug and reinsert all the ribbons. it should fix 80010201 problem.
Oct 27, 2009 | Sony Playstation 3 (PS3) Console
80010201 Error message appears. Please help..
this error means that a cable is unplugged or some thing like that: my ps3 got a ylod and because of that i had to open my ps3 and fix it(using gilksy method(it really works!)), after i reassembled my ps3 and got a 80010201 error and realized that my ps3 doesn't recognize controllers at all(even after i connected them to ps3 using USB cable). anyway, i reopened my ps3 and check all the vires and connections and reasembled my ps3 again, the problem was solved. so if you got the same problem, just open the thing and check all connections and unplug and reinsert all the ribbons. it should fix 80010201 problem.
Sep 27, 2009 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
1,740 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
