Question about Intellinet Active Networking Intellinet 802.11g 4 Port Broadband Router
Wireless issue with router
One day when the internet was not working very well, i was trying to reestablish the wireless signal and the routers wireless disconnected. How do i get the router to give me a wireless signal again?
  • 2,260 Answers
Wireless connection issue
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Jan 30, 2010
What would cause my wireless router to stop working?
recheck your connection from your router to your modem. Make sure your wireless button is turned on the computer. If all else fails reinstall your router with a data cable attached to reestablish the wireless connectivity.
Aug 11, 2014 | NetGear WNR2000 Wireless Router
Poor signal with WiFi on my zeepad
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
Restar
If by resetting you mean the wireless connection keeps dropping and reestablishing then you must likely have poor signal strength to the wireless router. The strength of the wireless signal can be greatly diminished by walls and other objects in the way of the wireless router. Best advice if your fairly close (less than 20 ft) from the router would be to invest in a wireless N router, you will get a much better signal.
Feb 03, 2012 | Computers & Internet
Just out of the blue my linksys wrt54g just quit working yesterday - have reset it several times with no change andeven did hard reset on the back of the router for 30 sec. I have both my laptop and...
A subscribed internet connnection would likely have been the providers responsibility. Once, the devices appear to be in functioning conditions as usual only has a remote signal compromise, contacting the service internet provider should resolve the issue. Also, the provider of the signals usually a remote computer would require to reconnect to your computer in processes discussed. Once informing the admistrator of the remote computer, your systems would require powering of completely, thereafter, the remote server computer searches to acquire the devices requiring reestablishement. Shortly thereafter your systems of computers modems are powered back on to ascertain the new settings of signals. The condition would have been caused by the remote computers replacement of devices where their disconnection causes yours to disconnect. However, the subscriber has to reach to the provider for reestablsiment unless notification of the shortage is being communicated with an alternate arrangement least yet arrived. Contact the internet provider. Goodluck
Jan 14, 2011 | Linksys Wireless-G WRT54G Router
I have a wna1100v1 usb wireless adapter that is on my home pc and i need to access the internet via the belkin router my comp shows a possitive connection with signal strength of 75%. But i can't connect...
It could be a number of things. Most of them would be very hard to explain on this website. I will try to explain though.
*Make sure you installed the wna1100v1 drivers and software.
*Try restarting everything. Computer and router.
*Unplug router, wait a minute. Plug back in. Allow time for router to reestablish internet connection.
Hmm...there are a few others but they are a bit harder to explain.
Thanks.
Computer Rescue of West Georgia.
Jun 16, 2010 | Computers & Internet
My Netgear WNDR3300 just quit putting out a wireless signal. I just bought a new Compaq notebook and the wireless internet was working for like three days and now nothing. And it is running windows 7 and...
It seems that router wireless setting need to reconfigure,please follow steps to resolved issue
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. If WPA is selected in Security mode, then check the Password that show up in the passphrase box.
now try to reconnect wireless
Thanks for using Fixya
May 14, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
All cables are connected ...just lost wireless internet connection what's the problem it was working fine
Turn the router off.
Wait 10 seconds.
Turn the router on.
Wait 60 seconds for it to reestablish its connection to your ISP.
Restart your computer.
On your computer, click "View Available Wireless Networks".
It should show your private wireless network.
Jan 01, 2010 | NetGear WGR614 Router
Internet drops over wireless router
Check to see what wireless mode you are using between the router and airport card. They are up to the "N" version now and if your router doesn't support and the airport is set to "auto" it could cause the issue. Try and match the settings with the router and see if that helps with dropping the signal.
Also are you using security with you wireless?
And how strong of a signal is it?
Apr 27, 2009 | Apple AirPort Extreme Router
My linksys wrt54g v8 will not recognize the internet
Try to do a hard reset on the router. Hold down the button on the back of the router for 10 seconds. This will clear all of the settings out of its memory. Then try to connect again. If this doesnt work power down both your router and your cable modem. Let them sit for a minute and then plug in the modem and wait 30 seconds. THen plug in the Wireless router. The issue should resolve itself.
Gary
Jan 24, 2009 | Linksys Wireless-G WRT54G Router
Can't connect to internet
just try to power down your router for a minute or two then fire it back up again...9times out of 10 this resolves the issue...failing that try re-installing the wireless adapter.... hope this helps
Dec 11, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
Intellinet Active Networking Intellinet 802.11g 4 Port Broadband Router Logo
106 people viewed this question
Top Intellinet Active Networking Computers & Internet Experts
Prashant M
Prashant M
John Hong
John Hong
Are you an Intellinet Active Networking Computer and Internet Expert? Answer questions, earn points and help others
