Question about Toshiba CZ32V51 32" TV
Toshiba CZ32V51 no vertical scan
Sound good but pic is one line in the middle of the screen
  • 3 more comments
  • web4profit Feb 18, 2008
    which board to be replaced?
    How much does it cost?
    I have an electronics background , is it hard to change the board?
    This problem have been on and off for about two months now..could it be just a chip or loose connection?
    Thanks
    yes...give me the link please
    lots of parts here..what is the name of part or board?
    sound good but pic is one line in the middle of the screen. This has been on and off for a few months now.Could it be a loose compenent or baortd? Which part or board controls vert scan on this TV?
  • 72 Answers
If I were you, I just buy a new one, its to expensive to replace the chip and after replacing theres another problem popping up. In my own experience that is the most frustrating. a new one would be better than wasting your money and time and another problems came up after repairing it.
Posted on Feb 18, 2008
    Brigadier General:
  • 6,966 Answers
If I may add to IB4G2008's posting.
Your post/description is indicative of a vertical failure. More often this is just a single power pack IC with a heatsinked normally located near the very center of the main board. Often, due to high power dissipation, the solder joints of its pins gets cooked and therefore develop loosed connection. Generally, this is termed as a cold solder. Solution would be to re-apply heat with a low wattage soldering iron.
in some cases, the IC itself would be defective and a straight forward replacement is all that is needed.
At other times it may be the capacitor very near the same IC that would be defective.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 18, 2008
    Sorry Jaime867, looks like we're on to the same conclusion. Guess you posted while I was still composing. Cheers.
  • 2,336 Answers
Try to locate an IC that is mounted on a heatsink with markings LA7838 or something similar to that IC.
    Genius:
  • 3,587 Answers
That is a truly unhappy video controller. happen recently? looks like you're in for a new board replacement scenario.
vertical deflection amp is not getting the job done.
  • 3 more comments
  • Patrick Michaels
    Patrick Michaels Feb 18, 2008
    most likely the main controller board..they run from 125 to 250 bucks, refurbished. you up to speed on that?
  • Patrick Michaels
    good..yes..it could..you can open that up, mighty easily..just be careful with the screws..they are soft, and strip easily..
    look for something loose..but a chip is usually on board, not in socket, for reliability.
    hope that's enough for you to close this one. do you need a link to the board sales folks online?
  • Patrick Michaels
  • Patrick Michaels
    video control board, or system control board..only way to know that is with the hard to find service manual.
  • Patrick Michaels
    This is all fine, of course. Yet you may be complicating your life, by attempting component level analysis, without the proper investigative tools. Do you have a set of lab tools, including analyzers, to make this sort of determination? Thanks to the other Team of Experts for bringing this value to your analysis. Be mindful, after this session, to award the Best Solution to whomever you believe was most assistive.
Whtie line in middle of toshiba tv cx32h60
The vertical sweep output has failed. Check the vertical output section circuits for any loose solder terminals. Check all the solder terminals of the vertical output IC. Resolder all the suspected solder terminals by applying a little more solder. If these do not help you, replace the vertical output IC.
Jul 07, 2012 | Televison & Video
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
Toshiba 32sl410u have 2 vertical lines on screen
Likely a shop repair but:
Either a bad board (main, or power or even a inverter board)
Worst case if Black line and thick would be the panel (screen unit) which would be fatal but is not likely if lines not black.
Apr 05, 2012 | Toshiba 32SL410U 32 LCD TV
Toshiba TV (about 7 years old)
You had parts in the vertical deflection circuit failing, most common are the vertical output IC and possibly several capacitors also in the same circuit.
Sep 11, 2009 | Toshiba 36A50 36" TV
Toshiba 32" cz32v51
is the 4" strip horizotal or vertical. Possible vertical i.c bad.
Feb 27, 2008 | Toshiba CZ32V51 32" TV
Toshiba 32 SDTV
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 23, 2008 | Philips 25PS40S 25" TV
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
Sound but no picture
A white like across the screen means that the vertical circuit has stopped working. Look for a small fuse that looks like a resistor near the vertical output IC, replace that fuse if open and resolder the pins on the vertical output IC.
Jul 08, 2007 | Toshiba CZ32V51 32" TV
No picture, only sound
The set has a shorted vertical output IC, probably a TA8427k. The capacitors around the heat sink of this IC dry out and cause the IC to run hot. The correct repair is to replace the vertical output and the electrolytic capacitors near it. Also use 105 centig instead of the original 85 centigrade. The is some time a pico fuse or current limittng resistor which must also be replaced. This a common problem with Toshiba and is not a bad picture tube. The usual cost of this repair is around $120-150 depending on the integrity of the technician. Scrivitron
Jun 18, 2007 | Toshiba 27DF46 27" TV
No pic, no sound
Hey Wilt: We had the same problem, for the same model of Toshiba TV. Had it repaired yesterday. Turns out the problem was the power supply (P.C.B). The total cost was $192.66 Canadian funds (taxes and labour all in). Our model was 6 years old, buts its playing like a brand new unit now. Hope this helped ...... Good luck
Oct 26, 2006 | Toshiba CZ32V51 32" TV
Toshiba CZ32V51 32" TV Logo
110 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
