Question about Singer CE-100 Futura Computerized Sewing Machine
Need Help putting the bobbin case back in the futura ce 100?????
Help!!!! I cannot figure out the correct way to put the bobbin case back in the machine....I have broken 3 needles!!!
  • Singer Master
  • 1,388 Answers
With the needleplate removed, locate the black plastic bobbin case in horizontal and level position with the "bull horn" facing the rear, so the needle has space to move....
Gently place finger on top edge and move bobbin case, there ought to be a small amount of movement (1 or 2 mm slack) to allow passage of thread past the stopper spring (at front right)
If there is no slack at this position, have you adjusted anything to "tighten it up a bit", if so, relax the stopper spring by an "almost nothing" amount (again, 1 - 2 mm) to allow the thread to form the stitch.
....if you have had some needle strikes and damaged the surface, fine emery paper may be used to smooth the damage, if significantly scored, replace the bobbin case.
Posted on Feb 24, 2008
My singer futura ce100 bobbin case (the metal part that actually holds the bobbin) keeps popping out. I do not know how to put it back in correctly in the seat. There is no diagram anywhere for that. It...
It may be that the silver square object in front of it is to tight. I had this happen and I loosened that up with small screwdriver and put bobbin case back in and it helped. Had to play with it for a while. Or It may be that the bobbin case has chip out and need to replace that.
Aug 12, 2011 | Singer CE-100 Futura Computerized Sewing...
Bobbin case keeps popping out of my CE-100 Futura. Not sure whether or not the case is in there correctly.
Raise the needle to it's highest position and the case should go right into the shuttle.
Refer to the maintenance section of the manual for your machine.
If you do not have a manual, you can get one at the Brother website.
Apr 01, 2010 | Singer CE-100 Futura Computerized Sewing...
Bobbin is tangeling thread and my singer futura machine stops and beeps. I have tried to clean the bobbin area and replace the bobbin. I think it is not in correctly because it appears to move around and i...
You're best bet is probably to buy a new bobbin casing. They're usually about $25 or so and you should be able to find one on eBay by searching for Singer (your machine name and model) under the Crafts category. The silver plate on top of the area covering where you place your bobbin into has screws you need to carefully remove (careful not to loose them!). If you need to, take pictures with your cellphone or digital camera as you remove the old bobbin casing so you can see how to put the new one in.
Jan 24, 2010 | Singer CE-100 Futura Computerized Sewing...
Bobbin case futura singer sewing machine came out
The opening fits on the right side, toward back. There is the silver ring with the slot in it for the bobbin. That slot is facing the sewer.
Jul 19, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer ce 250 says safety device activated cant find the problemThere is no thread tangled in bobbin case
I just realized my problem... the little thing to put the bobbin on to refill it wasn't quite all the way back to the left. I can't believe it! I'm so glad that I figured out what it was though. Hopefully this information will help someone else!
Mar 29, 2009 | Singer CE-200 Quantum Futura Computerized...
Needle hitting metal casing .. Singer Futura CE 200
It happend to me aswell , not getting the source of the problem!
Then I noticed that the bobbin casing was out of the original position, take the whole casing out and make sure that when you put it back that the small metal tension loop at the front side on the right is correct, this image you can see in your handbook, (placement of the bobbin casing)
Feb 22, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura ce-100(Singer)
Sounds like a tension problem. Email the singer company at talktous@singerco.com They should be able to help!
They responded back to me the same day.
Nov 17, 2008 | Singer CE-100 Futura Computerized Sewing...
Bobbin Casing - CE150
There is a website for support (http://futura-support.com/futuraMachine/manuals.htm), but together with your software you should already have that manual and other help materials, check under menu section Help.
Aug 31, 2008 | Singer CE-100 Futura Computerized Sewing...
Problem with bobbin case - new machine Singer CE 100
My problem is solved (I think...that is a knock on wood kind of thing). Upon recommendation from another Futura user, I remove and clean my bobbin case and I put a drop of oil in the little hole under my bobbin case about every 5th or 6th monogram use. AND, I pitched all of my bobbins that were 15 and not 15J (I had some that were 15 and they were the culprit as well.) I have had no more problem. It seemed the least bit of lint caused me a lot of birdnesting. I also stopped using rayon thread and use only polyester and bobbin fill in the bobbin. I have got to say I am thoroughly enjoying my machine these days. Please try these things before giving up on this so user friendly machine.
Nov 22, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer ce-100 futura
Hi justmewynn, The url I am adding to this post may be of help. It is a pdf file from Singer contain many diagrams of the CE-100. Maybe you cqan page through it and find what your looking for. Hope this helps you. http://www.futura-support.com/files/CE100-Eng_Fre_Spa-77153.pdf
Sep 27, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
198 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
