Question about Skull Candy Lowrider Headphones
The Right side does not work.
I have a SkullCandy headphone. The left side of the headphone works great, but the Right side does not work.
I just bought the turtle beach x1's and had the same problem only it was the left side not the right and i was pushing the green audio connector cable to close together with the av componet connector and just slightly removed the audio cable from the av connector cable basically just slightly remove the headphones from the connection port on whatever you are connecting it to if that dosent work then most likely you have a lose connetion port on your device and will need to replace it or replace the device alltogether if the port can not be replaced.
Posted on Jan 30, 2010
Loose parts inside one headphone....?
The solution may be to open up the headphones and find out exactly what went wrong inside. It could be simply a loose or broken connection or something more serious related to that rattle.
Jan 14, 2015 | Skullcandy Skull Candy Hesh 2.0 Headphones...
Skullcandy repair centre
restore using the utility system restore go to control panel, and put the last day that you know was working good.
However you can use cleaner contacts solvent and fix it. Open in control panel the icon sound and use the tabs for headphone, and test the troubleshooting.
You mus sure that you headphone is good, try to test in another computer or CD, DVD. etc
God bless you
Jul 17, 2013 | Computers & Internet
Skullcandy
Could be your plug, try it on several devices, if it works, something is probably wrong with the device it doesn't work with, if it still doesn't work, it's something with your headphones, try replacing the plug.
Jun 19, 2013 | Audio Players & Recorders
I have a pair of skullcandy ind'd headphones and
don't feel alone this happens on lots of head phone set up. What happens sense the wire run through the top over to the other side and head phone are constantly put on , twisted, adjusted and so forth, the small little wires that are normally soldered to the two wires to each side get loose. Only thing you can do to attempt to fix it yourself, is to take off carefully the right side ear piece, and get to the exposed wires, you will then notice most likely it will be smashed or loose. If you or if you have a friend that knows how to solder, than, you would make sure wire is cleaned, stripped and re- solder it. Than problem will work. I am sure that is the problem, nothing else it could be. Thanks Mike ( premium expert from fixya)
Jul 10, 2011 | Audio Players & Recorders
My skullcandy agent headphones are only working on the left side,,,,,its blank on the left side
Sounds like there may be a problem with the cord.
Try plugging in your headphones and playing some music and moving the cord around. If the sound cuts in and out then you have a lose connection and will need to replace your headphones.
Mar 25, 2011 | Skull Candy Lowrider Headphones
My skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Feb 25, 2010 | Skull Candy Ink'd Stereo Ear Bud...
Replacing headphone connector
The impedance or resistance of the two different sets of wires might be different. The higher the impedance the less signal. If your cable is long enough you are better off spending the five or so dollars for a new plug. Red is right, green or blue is left and copper is ground.( Usually) Unfortunately not all manufacturers agree. Also what could have happened is a short between the wires that you soldered.Make sure they are physically separated from each other and insulated.
May 14, 2009 | Sennheiser PX 100 Consumer Headphones
One side does not work
What happens with these things is it dont take much to pull the wires out off the speakers inside the housing..Try pushing the wire in slowly to the side that doesnt work and rotating it a little each way..If you hear it come on then the wires have puuled out,You'll need to try and pop the casing apart and there you will see the problem..Have a great day
Apr 02, 2009 | Skull Candy Ink'd Stereo Ear Bud...
Skull Candy Lowrider Headphones Logo
1,229 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Owen Barnes
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
