I need to know exactly what voltage of power
I need to know what exact voltage of power supply i need for my protron 32 in lcd tv
    Genius:
  • 1,011 Answers
Dear,
Power Supply 100–240VAC, 50–60Hz
Power Consumption 232W max.
Its mean its a switching supply that can support as low as 100 and more as 240VAC
If there is a problem with supply and you want to attach a fix one then Check the MAINS at your area. If it is 110VAC then get it and if its 220VAC then use the supply for this kind of support
good luck..........
Posted on Jan 30, 2010
Can I use other power supply adapters?
Not unless the plugs are identical AND the + and - (polarity of voltage) and the voltage and amperage rating of the adapters are the same--
HINT: test the voltage of the bad one at the point where it connects to the set and also do not forget that the socket it plugs into could be broken loose.
Apr 26, 2012 | Protron PLTV-32 Television
Were can i purchase protron ac/dc power supply for protron pltv-32 pltv32 lcd tv
Check this link below:
http://www.lcdpayless.com/productpage.php?productId=5441
Specification of Protron pltv-32 lcd ac adapter:
Output Voltage: 24V and 12V Volts DC
Amperage: 6 A and 3 A Amps
May 15, 2011 | Protron Ac / Dc Power Supply For Protron...
Need a ac adaptor for a Protron PLTV-32. MODEL LU32A1A3. INPUT 100-240V 50-60Hz 3.0A MAX.Output +24V-6A +12V-3A
I found one through Powerpayless.com at http://www.powerpayless.com/ac-dc-power-adapter-for-protron-pltv-32-pltv32-lcd-tv.html. It works great!
Mar 01, 2011 | Protron Ac / Dc Power Supply For Protron...
Protron 32" lcd tv
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Jun 30, 2010 | Protron PLTV3250 32 in. LCD Television
No power I need an ac adaptor for my 32 in protron Lcd TV
you can get ac adaptor for your TV at Shopjimmy.com,Ebay.com
Good luck
Jun 25, 2010 | Protron PLTV-32 Television
I have a protron pltv3250 32 in lcd television and i need to know were i can get a power supply for it the help would be greatfull thanks
Very common problem with this TV for the power supply module to go out.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 21, 2010 | Protron PLTV3250 32 in. LCD Television
Protron lcd tv will not turn on at all
power supply has failed good luck on this one try ramplus.com you need to get the FSP number off the supply
Sep 20, 2009 | Protron PLTV3250 32 in. LCD Television
Protron 32
It looks like the power supply failed on your TV. The failure rate is about 95% in the power module.
There aren't service parts available to swap the entire assembly, the only option now will be to fix the power supply to the component level.
Let me know if you need more assistance. You can write to my email address jah2mil@hotmail.com
May 08, 2008 | Protron PLTV-32 Television
Protron PLTV-32 32" LCD TV - AC Power Adapter
mine doing the same thang....what do we do
Mar 23, 2008 | Protron PLTV-32 Television
Protron pltv 32 tv
funny that no one's been able to help you, because I accidentally discovered that the power supply cord for my computer worked for my Protron PLTV-32C lcd...  not sure if your model is different in someway, but you may want to try the cord from your own PC first,
and if it works.
Jan 25, 2008 | Protron PLTV-32 Television
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
