Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
FUEL LINE ROUTEING ON A POULAN 3300 SAW - Poulan Pro 42CC 2 Cycle Chainsaw, 18"
    President:
  • 2,220 Answers
Typical fuel system and a couple of suggestions:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
IPL for 3300 Gas Saw
http://www.ordertree.com/modelinfo/PWE/3300-Gas-Saw/75.3300-Gas-Saw.1.59.1.html
I did not see a primer, that makes it even easier. Take a small sample of hose to your local chainsaw outlet. 12" is probably ample but ask them.
If I can be of more help you can reply below. I hope you found thisd most helpful.
Lou
Posted on Jan 30, 2010
Replaceing fuel line in polan 3300 chain saw
Hi owjbhend...
Use a piece of wire and insert it into the fuel line, then bend a hook in the end and hook it over the end of the fuel line...lubricate the fuel line with some vaseoline very lightly...about the first one inch of the fuel line and then use your fingers to start the fuel line into the tank, once you have the fuel line in the tank give enough to hook the fuel filter to and so it can be dropped back into the tank.
Below is a drawing of how to route the fuel lines.
Please take time to rate me thumbs up
Sep 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
May 07, 2010 | Poulan ES350 16" Chain Saw
How do I hook up a fuel line to a carbuertor on a Poulan 18 inch?
Typical Fuel System (Primer Bulb and fuel lines may not apply)
http://www.img4free.com/thumbs/Lou98321/fuelsystem.jpg
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Dec 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a Poulan 2450 thats not getting any fuel, I drained the fuel tank. When I looked inside and the fuel line,the white filter and the gromet which goes from the inside to the outside of the tank was...
Typical fuel system:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best.
Poulan.com
2450 Gas Saw Type# - # is the dash number of your serial number.
HTH
Lou
No one illustration shows all fuel system components.
Nov 28, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Fuel line crack dry out, in pieces
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Find your saw here:
Poulan.com
SmallEng.com
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
I think the second line on the carburetor is an impulse line and connects to the crank case. HTH
Lou
Oct 08, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do you get the fuel line from the carb to the piston?
Your saw is made by Poulan
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Until 09/24/09 you could go find an IPL here:
Poulan.com
Now you must be a dealer to utilize the only known source of parts for your saw. Please register your displeasure with this arrangement here:
http://www.poulanpro.com/node4033.aspx
They should also provide a link to the correct IPL for your saw. HTH
Lou
Sep 27, 2009 | Poulan Garden
How do you get new fuel line into the gas tank of poulan chain saw?
FIrst off be sure you have the correct size line. Poulan uses several sizes of fuel line. If you got the wrong one, you won't get it to go in. The best way is to cut the tip of the fuel line at an angle. If you warm the fuel line before inserting it, it will go in easier. Once you get it forced in a little ways, you can reach in with a pair of needle nose pliers and pull on the fuel line while pushing it in from the outside. If you bought the line from a Poulan dealer, then instructions would be included along with the end being precut at a long angle to assist with installation.
Feb 22, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
1,358 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
