Question about Bosch HBL 5052 Electric Double Oven
We have a neff double oven and the bottom oven wont heat up, the fan works ok but no heat???
  • Bosch Master
  • 3,463 Answers
If the fan is working o/k, then it it is likely to be the oven element that has failed.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thankyou.
Posted on Jan 30, 2010
Testimonial: "thanks"
My Neff U1421 bottom oven has failed.
Probably the ring element. If the clock is flashing zeros or 8's the bottom oven will not operate but the top will. Make sure the clock is set (doesn't have to be the correct time, just not flashing) If the fan and light then work but no heat, defo the element part no 499003
Mar 21, 2013 | Neff U1421 Double circotherm Electric Oven
Tip
Common heating faults with Neff U1421 Double oven,
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff U1421 Double circotherm Electric Oven
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
Neff u1421 bottom oven: Either fan works but no
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Thanks.
Oct 24, 2009 | Neff U1421 Double circotherm Electric Oven
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
Neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Aug 26, 2009 | Neff U1421 Double circotherm Electric Oven
No heat on bottom oven. fan running but not heating up
Neff fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
Jul 19, 2009 | Neff U1421 Double circotherm Electric Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Lower oven not heating up everything else is working fine
hi, we have had the same problem. You can order the element from many places online, the cheapest is about £25 ranging up to £60 from neff themselves. Fitting it is ok the hardest part is getting the fan off to change the actual element. However, be warned, we are now on our 4th element and it just went again last night. Neff deny that this is a known fault that the elements keep going. However, at least 10 of our neighbours have had the same problem with their oven too!
Jan 18, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1721 Double Oven - No Heat
If the fan is running then it is unlikely to be the clock/timer. Yopu need to check if there is voltage to the element but you MUST be careful to avoid an electric shock. There is sometimes a thermal cut out in line with the supply from the thermostat and that would need to be checked. If all OK the thermostat is the likely offender
Oct 13, 2008 | Neff U1721 Double circotherm Electric Oven
Bosch HBL 5052 Electric Double Oven Logo
127 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
