Question about Coleman Sport & Outdoor - Others
Where can I get a replacement parts list for the Coleman 505 Pocket II Stove. Circa 1978 and made in Canada
5 Suggested Answers
SOURCE: Coleman stove, model 412-5621, will
disassemble the pump by removing the c-shaped ring aroudn the metal cap. a flathead screwdriver will work to pry off the ring.
pull out the pump assembly. The end is probably a old dried out leather ring. It needs oil (car motor oil shoudl be fine) and it needs to make a tight seal.
if it is too loose, it might be possible to press it out to make it wider. If not, it needs to be replaced. The pump assembly is about 8 dollars at many stores.
Posted on May 02, 2008
  • 1388 Answers
SOURCE: Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Posted on Apr 26, 2009
SOURCE: need owners manual w/parts list bissell #1630 circa 1970's
i found all the parts
Posted on Oct 13, 2009
  • 40 Answers
SOURCE: i need to replace the contacts and maybe the plunger
Pinball Resource and Marco Specialties sells complete flipper rebuild kits. Tell them the name of the machine and they will ship you the correct kit. One kit rebuilds two flippers (a left and a right flipper assembly).
Posted on Sep 24, 2015
Eaton viking imperial electric,stove oven door will not close completelty; circa 1996. are replacement hinges still availible?
To the owner of the Eaton Viking stove RS3028W-1, yes you CAN get replacement hinges!
I too, have this stove model (circa 1996) with exactly the same problem and I have spent the past 18 months looking for replacement oven hinges. I was very frustrated at the thought of having to throw out a stove that cooks and bakes wonderfully and has not needed any repairs till now and having to buy one of the new subpar ones that constantly need repairs. Plus you can't do canning on the new stoves and the few remaining coil models are extremely poorly made.
I have found 2 places that carry the hinges.
1. Reliable Parts, 1-800-663-6060. This company is located in Montrea (St. Leonard), Quebec.
2. Appliance Shark, 1-800-663-1176. This company is located in Barrie, Ontario.
The part number for the hinge is: 318-024-741
I hope this is helpful, and may you have many more years of happy cooking on this great stove.
Sep 17, 2014 | Eaton Computers & Internet
Coleman 5423b701
Try Coleman directly.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
Sep 01, 2013 | Coleman Camping Stove 2 Burner Propane W/...
Air pistols
you must search iN Internet use : google, altavista, lycos, yahoo,ask for the part from manufacturer list.
God bless you
Jul 25, 2013 | Computers & Internet
Parts for a coleman model 4136 stove
You could try Coleman directly if there is no repair depot near where you live.
Wichita, KS 67219
1-800-835-3278
Apr 14, 2013 | Coleman Vintage 4136 Camping Stove
How do you remove the burner part of a coleman grill/stove? I trying to give it a good clean. I got the 4 screws off and grill fuel bar, but for the of me, how do you remove the burner part. Kelly
The Coleman website has a pretty excellent list of owners manuals. (Here's the link for the 9921A700)
I believe that you unscrew the burner assembly on the right, which will then let you remove the cooktop to clean inside and re-assemble.
This procedure is not listed on the Coleman website or in the owners manual, however it appears to be fairly straightforward. I'd recommend using some teflon tape on the threads when screwing the burner assembly back on.
Aug 18, 2010 | Coleman Propane Grill Stove 9921-700
VALVE WHEEL LEAKS
Here is Coleman's repar part website.
You may want to replace the valve if it is leaking.
http://www.coleman.com/coleman/parts/product_category2.asp?category_id=210
Jul 21, 2009 | Coleman 2 Burner Dual Fuel 424-700G Grill
I need to replace the rubber gasket in my Coleman Peak 1 Backpacking stove. I bought a replacement pump which it is too long for my stove, but is the only thing I could find in Seattle. How do I get the...
Oven door will not close completely, therefore oven light is always on and the outside manual switch doesn't turn light off or on. The gasket around the window is brittle and coming away from its anchors in a number of places. I would think it needs to be replaced. Where is this part available? either on line or in Toronto, ON. M5R 3M6 Canada
Aug 13, 2008 | Kitchen Ranges
Coleman instastart propane stove regulator wanted
Check to see if Coleman has an attachment to replace the regulator, so that you can use a five gallon cylinder with your stove and your own regulator.
Jun 26, 2008 | Grilling
Sport & Outdoor - Others Logo
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
