Question about Dell Computers & Internet
I am trying to remove my Dell motherboard model DHM (Dimen. 8200)
I am trying to remove my motherboard Dell model DHM (old 486 CPU). I removed all the screws, heat sinks, CPU and the board seems hung up underneath. I tried sliding it forward but no luck. Any suggestions?
  • fwi3 Jan 30, 2010
    no, the d-shell connectors fit through the case without attaching to it. The motherboard seems to "bind" about half way from the edge. Is it possible that I have to take the plastic case away from the backside of the computer case? I tried to take a little plastic cover away from the back of the unit and got the edges free but the bottom locks into place and I don't want to break anything trying to get it off. Is it necessary to go underneath the motherboard to release some latches or restraining clips?
    Thanks
  • fwi3 Jan 31, 2010
    no it was not helpful. i went to a local Microcenter store and the techie there explained that Dell used some specialized mounting brackets in the older machines that basically prevented removal of the motherboard. plus, the integrated fan/plenum they used to cool the CPU would probably not fit in the right place on a new (different mfg) motherboard.
    Plus, in an unrated issue, the powersupply was only 180 watts and would probably not run a more powerful CPU with its associated RAM.
    So basically, I cannot upgrade the motherboard on this unit.
    I don't mind paying the money because I did get an answer, just not a helpful one.
  • Dell Master
  • 1,684 Answers
Most of the older Dell were also held in place by the screws on the VGA, Printer and serial ports. Remove the Hex head screws on all of the posrts and your board should release from the case.
I hope this helps.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 30, 2010
  • Buddy Mcsparrin Jan 30, 2010
    Which Dell model do you have? Desktop or tower?
How to remove hard drive from dell dhm computer?
switch off pc
remove sata cable and powercable of hard disk
remove the screws of harddisk
Jul 15, 2014 | Dell Computers & Internet
Dell dhm capacitors
There might be screws that hold the motherboard to the metal cover or there is a latch that you can press that will make it slide out.
It's easier to replace the motherboard than try to fix the capacitors.
May 13, 2012 | Dell Computers & Internet
Dell Dimension 8200 Desktop PC shuts off after it has been on for a long time. It shuts off like power has been removed from the CPU although I have an APC hooked up to it.
Sir you should check the power supply of your system.If its working properly then its because of the heat sink of your motherboard...Try to mother heat sink fans in the pc and your problem is solved......
Aug 02, 2010 | Dell Dimension 8200 PC Desktop
Need cmos jumper location on Dell Dimension 8200 to bypass bios password
From what I can gather, you just need to locate the jumper labeled PSWD and remove it. Turn computer back on, then back off. Replace jumper pin and turn computer back on. That should do it. Removing the jumper disables password. Turning on computer resets it. Replacing jumper re-enables password capability.
Jul 17, 2010 | Dell Dimension 8200 AUD System Board...
Trying to find the Jumper that controls FSB on a dell dimension 8200. Either that or some form of overclocking software that will allow me to get the full 2.8 out of my P4
modern Boards Auto-Detect FSB speeds, usually determined By CPU fsb And Memory/Ram speeds. It may be Wise to see if theres A user manual/guide for this board. or a possible bios update to support the CPU. also check the boards fsb speed ratings charts. overclocking is not recommended, as this can damage cpu/ram and motherboard.
Mike @ Compurepair.
Oct 29, 2009 | Dell Dimension 8200 PC Desktop
Getting my dell motherboards to start up.......
you might have fried the mobo when transferring it, and try it with a monitor see if anything comes up on the screen at startup
Oct 08, 2009 | Dell Dimension 2400 PC Desktop
I smelled smoke and turned computer off.
For sure, especially if you smelled smoke. Although it could b one of the cards or even power supply. You'll have to open it up to see for sure.
Feb 21, 2009 | Dell (E210882) Motherboard
Exact type and size of battery needed for dell 8200 pc desktop, how to remove the old one and put in new one
the motherboard battery is a standard 3v watch battery CR2032, available at any place you can get watch batteries (Walmart, KmArt etc)
It is held in the motherboard by a small clip. depress the retainer, and pop the battery out, snap the replacement in
Feb 02, 2009 | Dell Dimension 8200 PC Desktop
CPU fan died again
what's the output at the mobo connector?
Mar 02, 2008 | Dell Dimension 8200 PC Desktop
Computers & Internet Logo
306 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
