Can't upload audio from my RCA RP5022B Digital Voice Recorder
I cannot figure out how to upload the audio from my recorder to my computer. I've already installed the SETUP, but I don't see the option to upload.
  • nataliel1984 Mar 22, 2009
    I'm having the same problem. Windows XP recognized the digital recorder, but Vista doesn't come up with anything, it's like nothing is plugged in.
    I've already downloaded the software, but none of the bottom left drivers work.
Do i need softwear for my rca digital recorder
model rca rp5022b i have the download jack it was a present but no manual or softwear
please contct TIMRL209S@AOL.COM
Posted on Jul 02, 2008
Simple, on windows just click 'recorded files', then click on the file you want aand either drag-n-drop to copy the file or click 'move file'. I use my t10 to tape uni lecutures so i figured out this method pretty quickly.
Posted on Mar 30, 2008
  • oohmie Mar 30, 2008
    sorry didn't read the model number!
    But i;m sure the method will still work.....
All you have to do is install the DVR manager program that comes with it in the setup file. then you go to the drive on the bottom left that your file is saved in. then click on the file you want to transfer. after you do that you go to FILE----->MAKE .WAV FILE and choose the save location and it will transfer it to your computer. then you can use a program like audacity to listen to the file.
Posted on Sep 28, 2008
Fix it!!isn't that your website so since that is the website just tell me how to fix it!!
Posted on Feb 18, 2008
I have a RCA VR5320R digital voice recorder. My voice recordings are stored on the recorder, under folder "A," but when I attach the recorder to my computer, eventhough the device shows up under...
Your best bet is to play the recordings through the headphone connector to a pc audio line-in connector and capture the audio using something like Audacity. Then output them using audacity to mp3 to play on your mp3 player.
These units are notorious for their failing USB feature.
Mar 09, 2011 | RCA VR5220 Digital Voice Recorder
Need Manual RCA RP5022B
Hi
Please click on below link to view/downloadf the user manual for RCA RP5022
RCA RP5022B User manual
Hope this helps...
Daniel
Oct 09, 2010 | RCA RP5022 Digital Voice Recorder
RCA RP5022B Instruction Manuals
I have exactly the same model here sat doing nothing. I too lost the manual and the CD after contacting RCA they say it is an older model and as such no longer supported and that I was welcom to search the internet.
As far as support from RCA goes you, just like me are out of luck
I did quite a bit of digging some tome back but could only find a link that wanted $10 for a photocopy emailing to me !
As far as the software I have yet to find that.
Aug 13, 2009 | RCA RP5020 Digital Voice Recorder
Help
I changed computers and cannot now download data from my panasonic rr-us470 voice recorder -how do I bypass the password
Aug 31, 2008 | Audio Players & Recorders
RCA RP5022B
The software you need is in a folder on the RCA recorder.
When you plug it up to the PC, let it autodetect and it will add a Thompson DV RCA device to your Drive list.
You should see four folders ABCD used for organizing the recordings internally. There is another folder at the bottom with the software install inside. Copy this SW to your pc and run the setup. It allows you to convert the .VOC files to a .WAV and manage the folders.
Jun 27, 2008 | RCA RP5013
Ddigital voice recorder rp5022b
The only way to unlock is to hold the menu button down for three seconds. This will lock or unlock the recorders functions.
Apr 25, 2008 | RCA RP5008 Handheld Digital Voice Recorder
on XP try the "<" circle on the system tray and look for the USB device manager, disconnect from there.
If it is not there, or older systems try Start, Control Panel, System icon, Hardware Tab, Device Manager button. Find the Universal Serial Bus controllers, right click on the Device and select disable in the floating menu. that should allow you to remove the device safley.
Feb 16, 2008 | Audio Players & Recorders
RCA Digital voice recorder model RP5022B
have you tried formatting it? press erase till it flashes delete, then press and hold record for 3 seconds till it says Format, then press and hold erase till it says wait..it should fix it if that's the problem
Dec 15, 2007 | RCA RP5008 Handheld Digital Voice Recorder
Digital voice recorder RP5022b
pc reads but does not respond do I need to somehow program revcorder
Dec 09, 2007 | Audio Players & Recorders
513 people viewed this question
 Grubhead
Grubhead
