Question about Kenmore Elite 45986 Front Load Washer
Dl Failure (Door Lock?) Can hear the Relay
Dl Failure (Door Lock?) Can hear the Relay energizing...but no locking. Why?
The door lock is like a comprussin fit it is to far spaced apart you need a new door lock
Posted on Jan 31, 2010
What does dl code indicate?
Hello. The error code means there is a problem with the door lock. The lock *may* be working correctly but the main board is not getting the indication of lock position(open/closed). Or, the lock may have failed completely--when you initiate a cycle, do you hear the lock engage? Is the door, in fact, truly locked? The lock is really just a simple electro-magnet. When energized, it magnetically pushes or pulls a lever so you can't open the door. Also, it contains the ability to let the main board know when it's safe to start the wash cycle. I hope I helped you!
Sep 04, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Rear doors will not unlock
Door Lock System Components
The power door lock system consists of the following components:
The driver door switch (DDS)
The passenger door switch (PDS)
The body control module (BCM)
The driver information center (DIC)
The rear door lock/unlock relay (LBEC)
The door lock actuators in each of the doors The rear passenger doors are controlled by the BCM through the rear door lock/unlock relay which is incorporated onto the printed circuit board in the LH BEC. The BCM controls the unlock relay by providing ground to energize the coil and controls the lock relay by providing battery voltage to energize the relay coil. The energized the relay and allows voltage to be applied to either the door lock motor lock or unlock circuits. Since the other side of the door lock actuator is connected to the normally closed contacts of the opposing relay to ground, the doors lock or unlock.
Do you know what the BCM is , body control module ! If you do not know about this stuff I strongly suggest you to it to a ASE certified repair facility ! Save yourself some money an aggravation !
Apr 17, 2015 | 2007 GMC Sierra 1500
Dl code
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
May 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F DL
https://secured.whirlpool.com/Service/...nsf/.../Duet%20Job%20Aid.pdf
I think Duets have a propensity to have door lock failures...Why removing the surge suppressor would make a difference I have no idea.
F/dL Door Lock Error
Door Lock Mechanism broken or removed from the Door
Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
http://elektrotanya.com/whirlpool_ghw9100l,9200l.pdf/download.html
service manual above/
Apr 10, 2010 | Whirlpool GHW9100L Front Load Washer
My Duet front load washer door will not lock. I
Sounds like you have a door lock failure due to the fault code you have or it could be a control brd failure. Sometimes if either fails it will blow the other aswell.
Mar 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet GHW9100L washer door will not unlock and code comes up F dl, any idea's?
Ff dl (failure fault door lock)
Door Lock Error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check the wire harness connections to the Door Lock/Switch Assembly and
The door lock may have to be removed and replaced to get past this failure.
Mar 18, 2010 | Washing Machines
Code dl-f machine will not start up, usually you hear the door lock and then water enters- but door does not lock which is why im thinking dl stands for door lock? i unpluged machine hoping it would reset...
Hello.
You are correct in that the fault code stands for door lock error. Here's the book answer:
Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Replace failed component.
Try pressing pause/cancel several times to reset it.
Best regards, --W/D--
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 417.44092500 front load washer I get a LOC Err
LOC stands for lock....door lock failure....check the door strike and make sure door is closed....if closed wil need to replace lock mechanism
Jun 30, 2009 | Kenmore HE2 Plus Front Load Washer
Washer DL error
F/DL is indeed a door lock error. I had this on my machine, did a lot of research and getting some idea of how it works. The code is generated when the CCU can't lock the door. Possible causes are door latch mechanism, connecting wiring, or the CCU. I could hear clicking from the CCU on my machine which indicated to me the CCU was trying to lock the door. It tries 6 times before setting the F/DL code. I tested the latch and wiring from the CCU - OK. The clicking I heard had to be relay(s) so I figured the problem was relay contact failure. I removed the CCU board, determined which relays were suspect (there are two for lock & unlock). I changed them both and saved myself spending $300 CA on a new CCU. The relays cost just over $2 each. I found replacement relays @ Electro Sonic (www.e-sonic.com; minimum $25 order plus shipping $7.50). Relay made by OMRON part # G5LE-14-DC12 replacment for original G5LE-1-VD 12VDC. I'm not impressed to have to change a $300 CCU because of a $2 relay failure. For me this was worth the try as I have some experience working with circuit boards. The relays would be a quick repair for anyone with similar experience. Hope this helps someone.
Mar 11, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
174 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
