All of my voltage come up (110,210,17,-24,+24v)but they shutdown in seconds.self dianois give me error 23.please help. thanks
  • tvman1241 Jan 30, 2010
    this tv is a mitsubishi tv (ws55613) i think my problem may be on the main bd.i replaced the signal bd. also the power bd.what on the main bd.could be causing this shutdown?
  • 19,396 Answers
Hi.
They get shut down by the protection circuit, after a fault gets detected. Only the low (+5V usually) stays on.
Error and details depend on TV make and model. Tell me the model, possibly details on fault and diagnostic used, and I'll see if I can tell you something more on er.23.
Posted on Jan 30, 2010
Mitsubishi projection tv
GOOD DAY; THE VS-45607 Model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. GOOD LUCK, big IRISH.
Aug 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
UNIT WON'T TURN ON
Good Day, pcarangelo;
TRY THIS:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Jul 07, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Help please
Good Day, dez;
Try this to start:
Jan 31, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Big Screen TV
Good day, glojoe;
CHECK IC700 PIN 20 (AC-OFF) FOR 0 VOLTS DC. IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB.
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. I hope this information was helpful, good luck, big IRISH.
Sep 16, 2007 | Mitsubishi VS-70707 70" Rear Projection...
TV went off!!!
Sep 13, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Power problem
Sep 10, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Power issue
Aug 25, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Snapping or Popping Sound
Jul 25, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs50605 turn on and dhuts down and light flashes 3 time
Mar 29, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-45607 picture goes out intermittently
Dec 13, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
