Question about Proscan PS52800 52" Rear Projection Television
52" ProScan TV
I have a 14 year old tv, how do i adjust the screen to fit the picture?
  • Anonymous Sep 28, 2008
    proscan tv picture is far to the right and left side looks pinched
  • Proscan Master
  • 8,617 Answers
You would have to do that through the service menu. However I would not recommend doing that without the service manual. I can post a link to the service manual if you would like.
Posted on Feb 24, 2008
My 3 year old Proscan 42" LCD TV picture suddenly
On the far left and right inside the back on panel are inverter boards. Replace or look for capacitors buldged, swollen, or cracked on their tops. Replace defective caps with original value and make sure replacements are 105 degree for longevity. Common problem, let me know if this helped.
Sam Farrell
Feb 17, 2011 | Proscan 42LA45H 42 in. LCD TV
40 in LCD Proscan TV, Horizontal pic too wide, adj?
just look at the owners manual of how to adjust the picture
Jul 23, 2010 | Proscan 42LA45H 42 in. LCD TV
I have a 52" samsung that is 14 months old. for some reason it is out of sync. the picture is too wide and does not fit cable shows or dvd's properly onto the screen. tried different picture size settings...
FCC says it only has to display a picture, with 16 formats it tough to get it to ever fit right, use 16x9 or full on TV remote , then 16x9, stretch 1080i on cable box
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jul 27, 2009 | Samsung LN52A650A LCD TV
Picture Fades Away
honestly a tv that old, there probly wont be any parts to fix it. New tvs that size are about $999, go look at a new tv you will be suprised.
Jul 16, 2009 | Televison & Video
Distorted picture on my 32" Proscan TV...(about 15 years old)
The RCA GE sets have a problem with bad solder connections in the tuner unit which also causes numerous symptoms including poor regulation, no vertical deflection, low audio or dead set.
Pulling in from the sides is either poor regulation or a bad eeprom/solder join issue
Mar 13, 2009 | Proscan PS36123 TV
Picture Blown Up
Hello jasalf,
This problem is called blooming, and it is caused by poor High Voltage Regulation. It usually denotes a problem in the HV section of the TV. More then likely the problem is in the IHVT (Integrated High Voltage Transformer).
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Aug 21, 2008 | Proscan PS27123 TV
PICTURE TO LARGE FOR THE SCREEN AND ZOOM ISNT FIXING IT
Your TV set may have settings for picture size ratios but also if you have cable or sattelite service, they too may have these settings. Try both TV and cable remocons for proper adjustment
Jul 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Vertical line picture
problem is caused by the loss of horizontal deflection signal. It is quite surprising that the entire unit is still working, since usually, a loss of H-Out will disable the entire set. Problem can be as simple as loose solder connection to a more complicated defective horizontal circuit. I would suggest havint it checked by a professional TV tech.
Jul 16, 2008 | Proscan PS36500 36" TV
Proscan (RCA) PS52652
Also, the proscan ps52652 has the ctc-169 chassis. This set is a 52" manufactured in 93.
Mar 30, 2008 | RCA P52926 52" Rear Projection Television
Proscan PS52800 52" Rear Projection Television Logo
156 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
