Question about Dryers
What is the problem if it smells like kerosene inside the dryer while in operation? Clothes smell like it when removed also,
  • Dryers Master
  • 2,180 Answers
Did you just paint or stain anywhere in your home?all the dryer does is move air and the stain smell gets sucked into the dryer,when it heats the smell gets into the clothing,if that's not the case,the motor can smell like this if it's overheating,check the dryer to see if it needs a clean out,clean out the duct that the lint filter slides into,has to be removed to do this,vac out the inside of dryer where the motor is,and make sure the vent line isn't blocked up,if it is you can blow it out with a leaf blower or a shop vac that blows on the other end
Posted on Jan 30, 2010
Dryer makes a funny smell in the house and makes the cloths smell a lil funny as well???
I would need to smell the odor but a couple things will cause this. One being built up lint that is smoldering so I would definitely investigate inside for this. Also (more common with gas dryers) is when customers are painting or staining and varnishing in the house. This will give clothes a kerosene type odor. Try to think back to when it started and see if anything was changed in the household routine at that time. Good luck, Eric
Aug 17, 2010 | Amana NDE2330AY Electric Dryer
My monitor 41 smells like kerosene when it sits idle, repair man came out and told me he fixed it, but it still smells
Does it smell like raw kerosene or exhaust. If it smells like kerosene it sounds like you may have a fuel leak. If you can remove the grill, look inside and check for any kerosene in the bottom and in the tray under the heater. You should also check your fuel line for leaks. If it smells like exhaust look inside and on back of the heater for any black soot marks. There are a couple of o-rings, 1 in the exhaust connection in back of the heater and 1 in the flue pipe where the exhaust from the heater connects. There's also several gaskets in the combustion chamber that could be leaking. Hope this helps. If you need any more info, you can send me an email (nitensheaterservice@embarqmail.com).
Jan 20, 2010 | Heating & Cooling
SMELLS LIKE ITW BURNING
I highly recommend opening the dryer by removing the front panel.
Unplug the machine, remove the front cover and be prepared to vacuum out the lint build-up inside the housing of the dryer.
Also clean the exhaust duct of lint buildup too.
Sep 12, 2009 | Whirlpool Dryers
After drying, clothes have a soured smell. I really don't think its the washer because there is not a smell there. However, I have run just bleach several times through the washer and have tried candles...
Questions
Gas or Electric dryer?
Is the odor there even when not running?
Have you recently done any painting or stain/shellac in the house recently? Home perms?
Gas dryers will often give clothing a kerosene like odor if the above conditions have occurred. Any sprays or aerosols can have the same effect. Unfortunately only removal of the culprits and time will alleviate this.
Jun 08, 2009 | Whirlpool Dryers
Kerosene smell from the dryer
I have read other places that if you have recently painted, stained, varnished or used something in your house that has some sort of oil base it can make you dryer make your clothes smell like Kerosene. My dryer started doing the same thing and it was at the same time that a contractor was staining some trim in our basement. Good luck.
Mar 22, 2009 | Kenmore 73952 Gas Dryer
Bad smell inside dryer
that's because it's brand new. See if it goes away in a month. After a load has dried leave the door open for a bit. What does it smell like?
Feb 27, 2009 | Kenmore Dryers
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Nov 11, 2008 | Maytag MDG2706A Gas Dryer
GE profile prodigy - dyer
hi. the vent inside the dryer needs to be cleaned.you must live in a warm climate. clean all air vents inside the dryer, and out. thanks the appliance doc
Oct 04, 2008 | GE Profile Prodigy WPSE4200A
Dryers Logo
257 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
