Question about Microwave Ovens
11-30-2010 I need the user manual of Amana Mictowave model RS560W . Kindly assist. Thanks. Rgds Alon Felz The real problem: After heating the food (in a certain time selected), a beep sound should be heard to know the heating time selected is over. what button I should press to bring alive this function (there was an electric power failure and all power went off. The beep which was presented is not heard anymore after the electric power failure. How do I bring it alive again ?
In order to solve the problem this is what I did (with a help of Mr. Hilik
@ www.microgal.co.il)
1. Unplug the power cable 220Vac from the wall outlet.
2. Make sure or the clock led is "off" and screen is dark
3. Plug again the power cable 220Vac
4. Nothing comes "on" on the led screen
5. press on the digit "zero" (0) and you hear a beep signal
6. Take a glass filled with water press on the digits "1" and then "0" and
then "start"
7. After 10 seconds the beep signal will come on again.
8. Note: this kind a phenomena appears after voltage cut off when there
is a need to lift up again the handle on the voltage breakers . FYI.
Posted on Jan 31, 2010
Fmv157gm mictowave, Close the door and the microwave starts but no heat, won't shut off as long as the door is closed
system malfunction, cheap model.. get new one here for cheap fast free shipping at ..www.procellularservices.com
May 07, 2018 | Microwave Ovens
Microwave not heating up
If the microwave is not heating check magnetron connections, probably you will need to replace the magnetron.
Sep 06, 2008 | Microwave Ovens
Is it safe to use an epoxy grout in my Amana RSW458P microwave oven? About an inch of the grout in the bottom back corner, where the bottom meets the side wall, has peeled away.
this must be an oldie cus im not in the knowlege of any microwaves that are sealed with grout , most all today are heat sealed using an ultrasonic weld that i know of
but i caution you using non food grade materials inside any oven, heat generated by cooking may leak out chemicals in sealers and "grout" that are not designed for food and poision the food inside id contact Amana directly and inquire about them selling you a tube of this sealer ?
Sep 09, 2014 | Amana Microwave Ovens
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
Jan 06, 2014 | Panasonic Microwave Ovens
Our commercial amana microwave model number rcs 10 mpa 1000 watt is not heating/cooking food. The power, lights, fans , display and everything else works fine. I would like to fix this myself. What part...
can be many problems. a defetive magnetron. worn door switches and its bracket/levers. circuit board issues. oven cavity thermofuse. etc.. good luck.
Aug 03, 2011 | Amana RCS10MP Microwave Oven
MY LG microwave oven model no MH6344W does not heat the food .The oven is fine after 1 minute microwaving if i remove the food it is as cold as it was. What would be the reason please explain. I tried...
If the food is not being heated it means the magnetron is not working. The magnetron is the device which generates microwaves which heat the food. It could be the magnetron itself which is faulty or it could be one or 2 other components causing the magnetron not to work. You will have to take your microwave oven to a service center to determine the exact cause & get a repair quotation.
Let me know if you need further assistance.
Best wishes,
Graeme
Mar 17, 2011 | Microwave Ovens
Need a user manual for microwave model # GE JVM1640bb
Hi
Thanks for using FixYa. You can click on the link to download the user manual for your Microwave:
GE JVM1640bb User Manual
Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Stopped heating
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Jul 17, 2010 | Amana LD10 1000 Watts Microwave Oven
I don't have an instruction manual
Hi
Thanks for using FixYa. From what you have described it seems that you require a User Manual for a Microwave Oven however, it is not clear for which brand. Kindly revert back with the manufacturers name and model no# so that I can assist you further.
Thanks
Rylee
Jan 06, 2010 | Microwave Ovens
Microwave Ovens Logo
73 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
