How do I jump the Honeywell ST1920C relay so the blower will start?
  • lrgraves Jan 31, 2010
    Great help. I should have know this, it's been 3 years since i had to do my own maintenance. Thank you,
  • 767 Answers
What you can do is pull the wire that is on the heat terminal of the board and put it on the humidifier terminal in order to enegize the fan ona call for heat Or if the board has a fan on terminal you could also energize the blower from the fan on terminal but if the board is burnt or bad and will not energize the fan then the fan on terminal may not work either so you can try the humidifier terminal. hope this helps have a wonderful day.
Posted on Jan 30, 2010
I show voltage to the blower motor but it does not start when i press fan on the thermostat? Bad relays or bad blower motor?
Sounds like a bad motor. I don't know if your blower motor has an external starting capacitor and / or a running capacitor. If There is a starting capacitor and it's faulty , that would prevent the motor starting and turning.
Jun 01, 2014 | Honeywell R856B 1002 R856B1002 Fan Control
1977. Why isn't blower working?
Start at the fuse box, next is the relay then check the blower itself. check for 12V at the blower & relay. could come down to the switch too . Jump the relay w a paper clip if all cks out OK.
Nov 29, 2013 | Ford Thunderbird Cars & Trucks
I have a good heatpump with goodman air handler. the air handler has a sequencer and a blower relay. the blower relay quit working and i replaced it with a supco 90340 relay. the problem now is in the...
Your green wire from the tstat and the low voltage common should land on the relay coil. Your high voltage for the blower lands on normally open. Sounds like you are using your red (constant 24v) to energize your relay. Therefore your relay is constantly energized and your blower runs constantly. Let me know!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 01, 2017 | Honeywell Programmable Thermostat Heater
Utica Boiler model # MGB100HD with a Honeywell Aquastat Relay model # Type L8148E will not operate the circular pump. THe damper works and I can hot wire the circulator pump but it won't turn on...
how did you hot wire it. did you jump the wires on the relay board or use another power source? Does the boiler burner start? Have 120 volts incoming to the relay board? You hear relay click when turning power on/off? If so bad relay, or loose wiring terminals on the board. This control has built in transformer that can burn out, that will stop the pump relay contacts from working.
Nov 07, 2011 | Honeywell Programmable Thermostat Heater
Gas valve opens and burner lights but the furnace blower does not start the blower will run in the on position. controlboard is a honeywell st9120c
Here is the specs for your board
http://customer.honeywell.com/techlit/pdf/PackedLit/69-0781.pdf
Check the wiring to be sure you're getting all the inputs and proper timer settings.
It could be bad. (sometimes the fan relay goes bad)
Oct 28, 2010 | Honeywell Fan Timer Board St9120c 2010
When I set tstat to call for a/c, compressor outside comes on. Blower on furnace does not. When I manually rotate fan limit switch on furnace wall, blower comes on, blows cold air, and then goes off when...
blower relay bad or no call from stat on green wire to run fan jump red on stat to green if fan comes on stat bad if no look for fan relay turning the well switch bypasses the relay hope this helps
May 24, 2009 | Heating & Cooling
Heater blower motor cycles on and off (frequently). I have a class 2 LR95329 Honeywell Thermostat
The clicking noise is a relay or switch of some sort. You are right about that. I have 2 questions. 1) does the thermostat have a mercury bulb in it? 2) when the fan shuts off and on, does the burner stay on?
Nov 05, 2007 | Honeywell Programmable Thermostat Heater
BLOWER FAN WONT SHUT OFF WHEN THERMOSTATE IS OFF
The compressor coming on when the contact is pushed is o.k. they all do that. As for the blower fan not shutting off, some brands (Payne for example) the heating fan relay is a n.c. (normally closed ) relay. so if the time delay relay or thermal link are bad or not connected, the fan will blow even when it is turned off.
Aug 19, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
