Question about Samsung Comeback Cell Phone
I dropped my phone and the battery fell out. When I put the battery back in and turned on the phone the pin lock came up. I now have three attempts at a password in order to unlock my phone. As of write now all I can do with my phone is call 911. How am I suppose to fix this problem if the phone won't even let me call customer care?
    President:
  • 563 Answers
If you have attempt to set the password 3 times, the phone will ask you for a 'puk' code.
This 'puk' code can be obtained from you Sim-card box. You can view the box and see if there's any pin or 'puk' code.
Normally, the 'puk' code should work, but you can also call the customer care center by using someone else phone, who's using the same server.
Posted on Jan 30, 2010
I have locked my phone on accident and we unlocked it but it wont let me text. What do I do?
Zachary: According to VerizonWireless.com: "
  1. There are several reasons you may not be able to send a text, picture or video message.
  2. Try to power cycle your phone:
  3. Remove the battery while the phone is on.
  4. Leave the battery off for about three seconds.
  5. Put the battery back in and turn the phone on.
  6. Attempt to send your message again.
If you're still having problems, please call us at (800) 922-0204 so we may assist you.
I hope that helps! :)
20. Why can't I unlock my phone?
May 21, 2015 | Cell Phones
Tip
Dropped the cell phone or mobile in water
Dropped the cell phone in water
If you would have accidently dropped your cell phone in water or it fell in water you can try fixing it be these below tips
1. Remove the battery of the mobile and try drying it with a hair dryer
2. Put the cell phone in a raw rice container for a day, the rice will soak the moisture and the mobile will become dry from inside
3. After that put the battery back on and try switching, there are more chances now that it will work
4. Never try to instantly switch on the cell phone after taking it out from water you should follow the above steps, switching it on instantly can lead to short circuit in mobile and the cell software can get damaged
5. You can also put the phone in light sunlight (not in very hot direct sunlight) after removing the battery do not put the battery in sunlight though
6. Also make sure you keep the SIM card out of the mobile
By taking these steps you can make a fair attempt to save your mobile from dying.
Regards
Vikram
on Dec 02, 2009 | Cell Phones
On my Kitchenaid Artisan mixer the 3" silver rod fell out the back. How do I slide back in?
I an sorry but the only Rod in the back of a K45SS is the pivot hinge pin that holds the motor head onto the base. if it fell out then the answer is simple. Turn the mixer upside down and wiggle the base while sliding the pin back in. Once the pin is back in place, there is a set screw in the middle of the shaft that you can see while you are replacing the pin, turn this back down with a flat head screwdriver untill it is firmly against the hinge pin. The culprit of the problem is this set screw. It came loose and allowed your hinge pin to vibrate out and then fall down or fall out as you said. once the set screw is back in place you will be fine. To avoid this problem in the future you might remove the screw entirely and put a drop of "Lock-Tight" on it that will help hold the setscrew in place for a very long time.
Dec 11, 2012 | KitchenAid K45SS Classic Stand Mixer
I FORGOT MY PHONE PASSWORD I WANT TO UNLOCK IT
Hello
Enter the last four digits of your phone number on your cell phone PIN screen.
Enter 9999, and if that doesn't work try 1111, and if that doesn't work try other four-digit numbers you may have entered.
Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number which is under the battery. Re-insert the battery and power on the phone. Enter the last four digits of the IMEI number on the PIN entry screen.
Call your service provider and request the unlock PIN if none of your attempts so far have worked. You will have to prove you are a customer by stating your cell phone number, address and Social Security number.
Turn off your phone. Hold the keys "3," "*" and "Call" and switch the phone on. Hold the three buttons down until the word "Formatting..." appears on the screen. This should reset the phone lock code.
Go the links in the Resources section and have your IMEI number ready. These websites will ask for your phone model and IMEI number and then charge you a set fee for the unlock code.
THANK YOU FOR VISITING FIXYA
Mar 03, 2011 | LG Cell Phones
I have locked my Huawei Ascend with the pattern touch code and I forgot my pattern is there anyway I can unlock it?
Tounlock cell phone Password:Instructions
Things You'llNeed:
  1. 1
Enter the last fourdigits of your phone number on your cell phone PIN screen.
  1. 2
Enter 9999, and if thatdoesn't work try 1111, and if that doesn't work try other 4 digit numbers youmay have entered.
  1. 3
Shut off your cell phone,take off the back of your phone and pull out the battery. Record the IMEInumber which is under the battery. Re-insert the battery and power on thephone. Enter the last 4 digits of the IMEI number on the PIN entry screen.
  1. 4
Call your serviceprovider and request the unlock PIN. You will have to prove you are a customerby stating your cell phone number, address and social security number.
  1. 5
Turn off your phone. Holdthe keys "3," "*" and "Call" and switch the phoneon. Hold the three buttons down until the word "Formatting..."appears on the screen. This should reset the phone lock code.
Dec 30, 2010 | Cell Phones
Phone keeps saying invalid sim
Messages When You Turn on the Phone
  • When turning on your phone you may find a message requiring you to take a certain action before you can use the phone. If the message says "INSERT SIM," make sure the SIM card is installed in the phone or that it hasn't become loose. The SIM card is located in the battery compartment. Remove the battery cover and the battery. The SIM card should be located near the bottom of the phone under the metal hinge. Insert or secure the SIM card with the contacts facing down, reinsert the battery and batter cover, and turn your phone on again.
    If the message reads "PHONE LOCK," the SGH U600's automatic locking function is enabled. Enter the phone's password to unlock the phone.
    When using the phone for the first time, you will be prompted to enter a PIN. The PIN is given with the SIM card for your phone. Enter the PIN number exactly as given. You may also have the "PIN Check" feature enabled on your phone, which will require you to enter the PIN every time the phone is powered on. You can turn off "PIN Check" in the "Settings" menu.
    A message asking you to enter a PUK means you attempted to enter the PIN number three times and failed. You must contact your service provider to get a PUK.
  • Read more: Samsung SGH U600 Troubleshooting ' eHow.com http://www.ehow.com/way_5408527_samsung-sgh-u600-troubleshooting.html#ixzz11rVbifG3
    Oct 09, 2010 | Samsung SGH-U600 Cellular Phone
    I dropped it in a toilet for no more than three seconds. I immediately removed the battery and sim card and soaked the phone and battery in rice for a few hours. The water damage sticker is white but the...
    the first step is to take the battery of the phone and place both the the phone and the battery in a zip lock bag with rice and leave it for three day and then put it back together and the phone should turn on
    May 18, 2010 | Cell Phones
    I dropped my phone in water but icked it up right
    Remove the battery and immerse both the phone and the battery in dry uncooked rice for three days. This is the only cheap way to dry everything out. After the three days put the battery back in the phone and it should be OK
    Nov 18, 2009 | LG CU400 Cellular Phone
    Samsung Comeback  Cell Phone Logo
    54 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Fotis Papastamatiou
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
