Question about Samsung Televison & Video
Message on my tv reads check fan 1..
Message stays on the screen but tv switches off after a couple of mins
my tv is a samsung sq01 plasma
  • 438 Answers
Check fan 1 means the fan is not cooling, check to variety the fan is indeed working, the unit is shutting down due to over temp. if there is a filter, clean it
Posted on Jan 31, 2010
Samsung tv series sq01 has check fan 2 on screen then will shut off where is fan 2 located and what does this mean
you will need the complete model/serial number for proper part#. To locate which fan is problem try watching to see which one is not coming on at start-up.
Dec 09, 2014 | Samsung Televison & Video
Samsung le40a766r no.1 fan fault. I removed the back of the tv and the fan was stuck so i cleaned it and it was functioning. so i replaced the back and the tv worked fine for about 30 mins. then the fault...
Replace the fan. Check the fan speed regulator circuit too. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
If the fan has gone to its efficiency, this kind of fault can occur.
Mar 17, 2014 | Samsung HP-P3761 37 in. HD-Ready Plasma...
Rad fan on always ofter engine shut off. no hot engine message temperture guage at normal range fan stays on @2-3min after engine turned of regardless of running 1 min or 1 hr.
The ECM gets it messages for heat from the engine coolant temperature sensor. The sensor is probably bad. Since the fans come on right away the ECM is in a safe mode for the engine. Meaning it turns the fans on because it can't read the coolant sensor. As far as the fans staying on for a couple of minutes this is normal when the engine is hot. The ECM does this.
Sep 25, 2011 | 1998 Volvo S70
My samsung plasma becames black with sound but no screen after 1 min after turned on. we turn off the tv and turn on again and do it again.
Black screen on the PLasma TV can be caused by failed sustain boards and or power supply. I would inspect the caps on the sustain boards and the power supply boards first.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Dec 08, 2010 | Samsung SP-R4232 42 in. Plasma HDTV
Short circuit on the "Y" sustain board
The problem is heat!!! If the tv has fans they should be checked for normal operation,although on the early samsung models there were none, and the problem is that the panel drive buffers are getting to hot due to inadequate cooling. This is most apperent when tv is mounted to close to the wall, also external fan blowing on the rear left side will dissapate the heat. It is a problem on early Samsung and Electrograph 42 " plasma models. Hope this helps.
Jul 28, 2010 | Samsung Televison & Video
A couple of days ago I turned on my brand new (about 6 weeks old) Samsung 50'' plasma pn50b650 I noticed an imperfect picture at the top of the screen. Upon closer inspection, there were about 4-5...
U freeze video games 10-20 mins in video game alot of time.Never pause or freeze any kinds of video image in Plasma tv.It very easy cause to burn in Plasma tv problems alots.
Feb 25, 2010 | Samsung PN50B650 50 in. HDTV Plasma TV
Samsung 50'' Plasma TV won't turn on anymore
If your tv is within the one year warranty period then call 1-800-Samsung for warranty repair. Look at your tv purchase receipt for the Purchase Date. You have one year from the date of purchase to get warranty repair.
Jul 08, 2009 | Televison & Video
Televison & Video Logo
357 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
