Question about Sony BRAVIA KDL-40V3000 Television
Accessing External Inputs Settings
I don't understand how to access the Bravia's external inputs. Each number seems to be set to the cable box. I'd like to add my VR/DVD recorder, but the TV won't allow me. Where am I going wrong?
  • Doug Rogers Feb 18, 2008
    Coldcut: I've been using the remote that came with the Sony Bravia. I press the HOME button, go to "External Inputs", but every number is assigned to the cable box itself. I'm still a bit baffled.
  • Doug Rogers Feb 19, 2008
    Coldcut: I did it! Thank you so much!!!
    yorog
    Genius:
  • 1,554 Answers
You have to use the remote control for the tv not the dvr.
the dvr control likely cannot control the tv inputs programming unless you can program the correct code. and most new lcd panels don't have the correct codes for existing remotes
access using ext on the tv remote.
you may have to go into the menu and tell the tv what the ext is set to ie.. a channel or a input.
Posted on Feb 18, 2008
  • Karl Whisenand
    Karl Whisenand Feb 18, 2008
    see page 37 , you have to select and label the input
    http://www.preseps.com/download.php?id=8...
    it is a pdf of the manual
  • Karl Whisenand
    Karl Whisenand Feb 19, 2008
    thanks I really didn't want to say read the manual "rtm" ya know.
No sound on my Kogan 49" smart TV when connected to Foxtel or DVD through HDMI inputs
could you check on tv setting for hdmi that its in digital input and not external input. as sometimes the device settings are wrong, also its best to try a different hdmi cable as sometimes the cable can become damaged.
Jun 30, 2017 | Televison & Video
Hi I have a l32wd12 r a TV and it will not turn on
If the clock is on then the unit is receiving power; maybe the external input feature (which tells the TV which outside source to display on the screen, e.g. cable TV, DVD player, VCR player, etc.) is not set to display the TV channels. On my Sony TV there is a button that displays TV setting options (e.g., Favorites, TV List, External inputs and settings). The external inputs function displays the options as video 1, video 2, etc., right up to video 6. My video 3 is for the VCR, video 4 is for the DVD, and video 5 is for the cable TV channels. If the TV is set for say video 3 and nothing is playing on the VCR, the screen will be dark (almost as though the TV is off). Your solution might be as simple as choosing the right external (video) input for the TV to receive the channel signals.
Sep 19, 2014 | Televison & Video
Where do I change the input to HDMI input on my Sony Bravia KDL-52XBR2?
https://docs.sony.com/release/KDL52XBR2.pdf
Review the manual for this TV. Page 16 gives inputs for the HDMI. Page 43 gives instructions to label the inputs.Input 3 ,left side, is for HDMI.
Apr 21, 2014 | Sony Televison & Video
HDMI INPUTS DON'T WORK
It sounds like your set needs servicing. Are the other inputs working? HDMI port failures are indicative of a problem with the main board.
Sep 01, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
I am getting no sound
Check to see if speakers are switched off inside the set(menu)
If you have a DVD etc hooked to a rear input look to see if sound that way.
If you use a cable or sat box for signal it has audio settings that can cause this.
A few sets even have internal/external speaker settings
It could be a circuit problem but try the simple things first==a box can also cause this if hooked via the rear inputs of the set (unplug box and plug back to see if will reboot.)
Apr 11, 2012 | RCA L42FHD37 42 in. LCD HDTV
PICTURE NO SOUND
A short list of things to check:
Sound in set or a box muted OR turned low.
Speakers in the set (see menu) switched on or off.
Internal/external switch set external
Does set have sound when a DVD is connected to rear inputs.
If connected with cable or sat box to rear inputs of set try unplugging both box and set--wait a short time and plug back to allow both to reboot.
Clearly it could be an audio problem in the set (Got the model number?) but explore all this and also make sure if set has a audio mode on remote it is set to stereo.
Apr 10, 2012 | Televison & Video
I have a small elemet tv with a en21645e remote control. My grandson did something to the remote and now I only get the local channels not cable channels although I have cable hookup
The little tyke has most likely pressed the INPUT button on the remote control and switched the TV away from the external input setting required for watching cable TV.
You did not state the model number of the TV and some TVs function differently with regard to the selection of external inputs, but you should be able to return to watching cable by pressing the INPUT button slowly but repeatedly until you can see the picture from the cable channels again. The INPUT button is located in the top right corner of your Element remote.
If an input selection menu appears on screen when you first press the menu button, use the arrow keys to highlight another input, then press ENTER to select it. I can't tell you which will be the correct input as I don't know the model number of the TV and it depends on which type of cable you are using to connect the TV to the cable box. You should try each input in turn until you are able to see the cable channels again. Please make sure the cable box is switched on when doing this!
If you are still having difficulty, please reply to me from within this page with the model number of the TV and the type of cable you are using to connect the cable box to the TV. I will then be able to provide exact instructions for switching your TV back to the cable input.
Hope this helps.
Regards,
BElectric
Jan 28, 2011 | Element Televison & Video
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Hooking up external DVD player
if you tryed to hook up into another video input you also have to switch the inputs on the remote in the input menu from input 1 or 2 to the same.
May 27, 2006 | Toshiba MW20FM1 20 in. Combo
Sony BRAVIA KDL-40V3000 Television Logo
454 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
