Question about HP Vs17 17" LCD Flat Panel Monitor
I came back to the computer and the screen was blue with nothing on it. I finally turned the monitor off and then back on. A quick box appeaers saying imput:analog, disappears, and then the monitor remains blue and blank.
  • HP Master
  • 2,517 Answers
OS system corrupted & display driver lost. 1st try to install display driver hope you see the good result. if not then you need to format the OS and installed it again.
Posted on Jan 30, 2010
Need a hp part number for a lcd display for a HP Pavilion dm4t-1200 laptop.
I would like you to try using HP's Part Surfer.
1) Put your Product Number, or Serial Number in the Quick Search box,
(P/N = Product Number.
S/N = Serial Number.
{DO NOT give out the serial number on a public forum such as this. Only on the HP website}
2) Then click the blue down arrow on the right side of the - Select a country or region - box, and click on your country.
3) Finally go back to the Quick Search box, and click on the side arrow to the right.
Post back in a Comment as to your findings.
We'll go from there.
On the back of the LCD screen is the HP part number.
http://www.screentekinc.com/HP_Pavilion_DM4T--14-inch--1366x768-wxga_hd-laptop-lcd-screen.shtml
{Scroll the page down, and see if any of the 36 part numbers may be a match}
Display LCD screen replacement instructions,
http://www.insidemylaptop.com/disassemble-hp-pavilion-dm4-laptop/
http://www.insidemylaptop.com/replace-lcd-screen-hp-pavilion-dm4-laptop/
Awaiting additional questions. Please post in a Comment.
Regards,
joecoolvette
[ P.S.
You can disconnect the LCD display, and use an external VGA monitor, while you wait for the replacement LCD screen.
1) Laptop off, VGA monitor off.
2) Connect the VGA monitor to the Left side of the laptop.
( External monitor port. The VGA connector resembles this one,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
3) Turn the VGA monitor on. Wait for it to 'warm up'.
Turn the laptop on.
If the display does not automatically go to the external monitor;
Press, and hold down on the Fn key.
Tap the F4 key.
(The VGA monitor can be a CRT monitor, {Looks like a small TV}, or a flat LCD screen monitor that has a VGA connector, and a VGA cable ]
Sep 04, 2011 | Computers & Internet
My screen is green i was going to change monters didn't work so i put it back and it turn green.help please.
Red, Green, and Blue are the colors sent from your computer to the monitor. Sounds like red and blue are not working. If you've tried a new monitor, I'd try a new video cable next. Then clean the connector on the back of the computer (compressed air). Finally, replace either the video card or the computer.
Oct 04, 2010 | Computers & Internet
Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
Feb 06, 2010 | ViewSonic VG2230WM LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Samsung 22'' lcd screen turns on see something for half a second then turns off tried to hook up different computer same problem had two hooked up tot the same computer and same problem on both screens two...
I have had 3 Samsung monitors do the same thing. Before you call Samsung, completely disconnect the monitor from all computers, then power it on. If the monitor is okay you will get a screen that will say something along the lines of "video source not found" in what I believe will be a blue box on the screen.
If you get nothing the internal boards are bad and it is time to send it back to Samsung. Go to Samsung's website, if you have not registered the warranty then do so, you will need the cash register receipt or the invoice from where you purchased the monitor -- you have to send an electronic copy to Samsung to register the warranty. Once registered begin the RMA process. If the monitor is within the warranty period Samsung will actually UPS a replacement montor to you. The process is simple, you go to the UPS Store unpack the replacement, put the sick monitor in the box from Samsung, UPS puts on the prepaid preprinted label, you go home with good monitor and the sick one goes back to Samsung.
May 09, 2009 | Computers & Internet
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
