Question about iLO 3200 32 in. LCD Television
My tv is stuck in stand by mode. how do i reset it?
  • 201 Answers
Usually TVs that are stuck in standby have a part failure somewhere. You can try unplugging set for a few seconds and plug it back in. Sometimes the microprocessors can lock up. Otherwise, it can be a number of things power supply, main board inverter board or even the panel. Unfortunately having repair done to a 32" tv will probably come close to just replacing it unless you try it yourself.
Posted on Jan 30, 2010
Tv stuck on stand by will not go with the remote or manually
Do a reset to this TV; and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 09, 2015 | Televison & Video
My tv is stuck in stand by,and my remote does't switch on the tv
Television is not the main remote control from behind or the side
Feb 15, 2013 | LG MKJ42519615 Remote Control
Moved TV to a different room and the TV power button is blinking like it is in "standby" mode. How do I get it off "standby" mode??????
unplug it for about 30 mins it will reset it. if that doesnt work it will be stuck in standby mode until a video source is activated. if you are using hdmi both the tv and the hdmi device must be on. (hdcp compliant devices must be turned on at the same time otherwise it will say stuck in stand by mode they do this to prevent people from trying to rip content off hdmi and blu rays had the same issue with my tv and xbox.
Mar 14, 2011 | Televison & Video
My Sony KP-51WS500 is stuck in Stand by mode
Have you tried unplugging the TV for a few minutes? if it's some kind of computer error, unplugging it will allow the error to clear and possibly allow the TV to work again. Just an idea.
May 22, 2010 | Sony KP-51WS500 51" Rear Projection...
TV won't turn on or off. Stuck in stand by mode
its a power problem on the electronics board need an tec to open the tv and slve the problem
Aug 17, 2009 | Gateway LCD26TV 26 in. Television
Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Jul 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Channel stuck on TV
This may work;
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Feb 24, 2008 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Stand by mode
How many times does the standby light flash...b/4 pausing and repeating ?
Dec 20, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Stuck in Stand-by mode and will not turn on
try to soft reset the recievers by unplug for a while and replug and try power on , or hold up the rear reset butomn and press power at the szame time then release both
Apr 30, 2007 | Pioneer VSX-D912 Receiver
iLO 3200 32 in. LCD Television Logo
53 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
