Question about QDI Group QDI SynactiX 5EP-A (SYNACTIZ 5EP-A) Motherboard
It'2 second time that power supply 235 w is fault? possible need 300 W?
  • 644 Answers
You should look at getting a power supply at about 450 watts + it should give you all the power you need.
Posted on Jan 30, 2010
Computer shouts down in 15 to 20 seconds after starting
The specs say the PSU is ATX compatible. Whether that is for the connector only or for the whole power supply is something you will have to determine.
If you have an ATX power supply handy (like in an old computer) give it a try. This one is only 300 Watts so it won't likely be expensive to replace.
Have a look at: http://www.techspot.com/community/topics/dell-dimension-1100-shuts-down-after-20-seconds.135987/
Aug 28, 2012 | Dell POWER SUPPLY Power Supply
Code po560
You will find all Diagnostic Code details available at http://ww.bluejag.co.uk .
This code P0560
Fault Code:- P0560 Indicates a Power-train fault
The fault is generally due to a problem in the Vehicle Speed & Idle Control area
Fault Description: Battery power supply voltage malfunction Note: This DTC can be flagged due to fuel injection pressure sensor fault. If P0193 is also flagged, correct first.
Action of ECM:- none
After clearing the DTC, complete the Engine temperature cool (cooling fans not running) Remove ignition key for 20 seconds (cooling fans not running) Ignition key in, position II for 5 seconds (do not start) Repeat cycle two additional times
Check for a reoccurrence of fault DTC.
Possible Fault:- ECM battery power supply open circuit, high resistance
Jun 18, 2011 | 2002 Jaguar X-Type
4 second shutoff
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem. Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over.
Jan 21, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to rest h2 code on sharp ar-235 what is the simulation process now on sharps
Make sure the thermistor is clean and ok then press, P, Interrupt, C, Interrupt. It asks for a code, Enter 14 press print then press Execute on touch screen.
Sep 28, 2009 | Sharp AR-235 Copier
Powers on for a few seconds then goes off
Your machine is not booting to the bios... time for a new machine/mother board
Aug 13, 2009 | E-Machines REXUS SPE-300 ATX 300W P4 Power...
DVD on light comes on for a few seconds and then shuts off
HI, this will occur when there is a power supply circuit fault that is located on the power supply board. this could be a failed capacitor or resistor of some sort.you will need to replace this damaged power board if possible to restore normal function.
It is unable to hold a proper AC current at this time.
May 31, 2009 | Cyberhome Progressive Scan DVD Recorder...
Replaced dead power supply computer still dead
hi
most power supplys are protected against faults when they are connected to damaged equipment
so it possibly just protecting its self
disconnect everything from the PSU except your MB
try to turn on
if your pc boots ok
re connect everythng else one thing at a time attempting to boot each time
when it wont boot you have found your fault
Feb 07, 2009 | E-Machines D2046 PC Desktop
My AVR 235 stays on stand by
Hi...
That sounds like a amplifier module /section that has failed.
Do you ever get power surges at your place?
Oct 05, 2008 | Harman Kardon AVR 235 Receiver
Atx 300
Hello wazalac,
This may be the failure of the power supply itself. Did you take voltage readings of the outputs. I would venture to say that the problem is either with the switching power supply oscillator, or the high power MOSFET switch. Check for blown fuses, and if you have a ohmmeter check to see if the high power MOSFET is shorted. You will need a schematic, and a multimeter to do this.
Thank you,
Shuttle83
Jul 27, 2008 | RCA HD50LPW175 50" HDTV
QDI Group QDI SynactiX 5EP-A (SYNACTIZ 5EP-A) Motherboard Logo
29 people viewed this question
Top QDI Group Computers & Internet Experts
Tom Chichester
Bill Boyd
Are you a QDI Group Computer and Internet Expert? Answer questions, earn points and help others
