Question about Maytag MSD2756G Side by Side Refrigerator
Having trouble getting to adaptive defrost control module. how do get plastic cover off (control box)
Ihave a 10" protek mider saw I have a problem when I make a45 cut. the cut is not straight how do I adjust it?
Posted on Jan 30, 2010
I want to replace faulty freezer thermostat in whirlpool side by side fridge mod ed22dqxew01 --am having trouble removing cover for freezer-refridgerator control dials. I removed two screws in rear of
First question why are you replacing the freezer thermostat? Do you have an ice build up on the rear wall of the freezer? This build up if you do have it is not due to the thermostat control for the freezer. It is termed as a defrost issue due to a fault condition being present in the defrost thermostat, the defrost heater, or the defrost timer or adaptive control depending on which type of refrigerator you have. I will await your reply as to why you are replacing the control thermostat and if you do have any ice up condition before posting further how to solve this situation. I await your reply
Thank you
Rick
Jan 01, 2012 | Refrigerators
Where is the defrost module for a maytag refrigerator (model msd2756dew) located?
Hi, welcome to fixya.
If it is the actual component which control's the defrost cycle ( what was once referred to as a "defrost timer" ) it is located in the fridge section up under the plastic light and control covers.
For many modern fridges including yours, It is known as an "adaptive defrost control" and looks like this...ad5c9b2.jpg
If you are referring to the actual defrost heater and bi-metal/DTS, they are located in the freezer section behind the evaporator cover.
Hope that answer's your question. Let me know either way.
Thank's for visiting "fixya" today. Please take a moment and rate the info provided for you here.
macmarkus :)
Jun 14, 2010 | Maytag MSD2756G Side by Side Refrigerator
Where is defrost timer in maytag MSD2756GEQ SxS
Inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control
Jun 13, 2010 | Maytag MSD2758G Side by Side Refrigerator
Model # MSD2758GEQ - The freezer side is OK the refrifg side is n
Check to see if you have frost build up on the back of the freezer wall toward the lower section. If so you are have an auto defrost problem. Deice the coils and Check heater to see if broken. Most of the time the adaptive defrost control is the problem which is located in the fresh food section at the top area under all the nice looking plastic covering the cold control and freezer controls. The part is a 61005988 and cost approx. 80.00. I have to 2 of these today myself. Good luck. If you defrost all the ice out of the coils this will buy you few days of cooling before having to do it again. Hope this helps.
Feb 03, 2010 | Maytag Refrigerators
My samsung fridge will not go below 46 degrees any ideas
Model is? It is most likely a defrost problem. Look inside the door frame. Inside the fresh food section an there also may be a hole there that has plastic plug to hide opening. May need to drop the cover to fresh food sections contol panel for a defrost time or Adaptive Defrost Control and behind the plastic cover on control panel. This also may be an auto damper that has frozen the damper shut. Look at the rear panel in freezer. Is there frost building up. If yes the send me the model number. Auto damper regulates the fresh food section and has thermostat probe filled with freon. If you still need my help please let me know, Sea Breeze
Jan 17, 2010 | Samsung Refrigerators
I have a Estate bran fridge and it keeps defrosting every two days it's a new fridge what could be the problem
HI. This will occur if your defrost module is malfunctioning. There are two types of defrost controllers. The first will be an adaptive control board. This will be located in the control housing, just above the heat shield, in the upper right had side. Older models will have a standard defrost timer mechanism. When these devices are malfunctioning, You will notice erratic defrosting cycles. I recommend to inspect the module, to confirm that it is set correctly, and is operating.
If equipped,The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor. It will have an adjustable dial. make sure it is set to a proper defrost interval.
NOTE_ If your unit is equipped with an adaptive defrost control board, and the defrost cycle is erratic, this will require you to replace the board. this type of defrost control module is not repairable.
Nov 10, 2009 | Refrigerators
No heat in front..only in back
PROBABLY THE BLEVIN DOOR MODULE LOCATED BEHIND THE HEATER CONTROL AND RADIO. FIRST REMOVE THE RADIO WITH DIN TOOLS AND THEN THE COVER FOR THE HEATER CONTROL MODULE WITH 7, OR 8 MM IT'S A WHITE PLASTIC BOX IF THE MODULE GOES BAD YOU MAY HEAR A CLICKING TRY TURNING THE LITTLE SHAFT IN THE BOTTOM RIGHT CORNER OF THE MODULE COUNTER CLOCK WISE SEE IF IT HELPS.
Dec 14, 2008 | 1999 Ford Windstar
Frigidaire glhs269zcb2 ice forming in freezer. defrost timer suspected to be faulty. can't locate, help . thank you
your refrigerator does not have a conventional defrost timer. it has an adaptive defrost control board. it looks like a white plastic box with a wire harness plugged into it. it may be inside the refrigerator with the control knobs. the problem could also be caused by the defrost heater or thermostat, both in the freezer behind the block of ice. b94e12c.jpg
Aug 01, 2008 | Electrolux Refrigerators
Trouble shooting defrost system
you can not manually start a defrost cycle
go to the freezer and check the heater and bimetal they are in the evaperator coil if these parts check good then replace the adaptive defrost control
Apr 25, 2008 | Maytag MSD2656G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
102 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
