Question about GE Spacemaker JVM1740 Microwave Oven
Light bulb broke in oven it is a general electric over the stove type the bulb metal part is stuck in socket
  • GE Master
  • 9,098 Answers
This is pretty common and can be a pain. It's tacked in place with contact cement or hot glue, and sometimes there may have been enough moisture to corrode and seize up.
First of all, always unplug the oven before removing or installing light bulbs.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
Before I install a new bulb, I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Once you get the lights replaced, if you find that they still won;t come on (or if they're stuck on or stuck on bright or dim) then oyu will need to have your circuit board repaired.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Posted on Jan 31, 2010
The bulb broke in my Roper oven and I can't get the rest of it out.
* Call for service! High voltage(s) present!
*** The following is for information only. ***
* Remove oven and unplug. (Yes, you could trip out the breaker. But do you know enough to turn off the right one? Remember, you will be sticking something is a live socket.)
* Following is very dangerous! Use the back end of a rubber handled screw driver. Wear a glove and don't touch the metal parts of the oven with your other hand. Use dry towels if needed, to place around the oven door if you have to lean in. Remove all metal shelves. A small wooden handle (from a plumber's helper) can also substitute as well (if it's dry!)
* I'm guessing the bulb cracked or broke off the metal screw In base. With power OFF (you will be smashing the wires to the bulb that will probably short out.) Insert the blunt end (Handle side) into the light socket. Use a smaller handle if it does not fit. A broom handle should fit perfect. Press hard enough to get a grip and twist counter-clockwise to loosen the base. You may need to twist slowly back and forth to get the handle to 'bite' into the base. Be careful as the base comes out that you use a gloved hand to unscrew the base the rest of the way.
* This method works most of the time. Though it will not work on shorted/melted bulbs. This is caused by a bulb that was not seated properly and 'arced' welded the base to the contacts of the socket. This requires a complete replacement of socket and bulb.
* Final; Check your warranty as working on the oven may void it. Warranty periods may last years, so check first. Be safe and call your vendor for service.
Aloha, ukeboy57
PS; Though I don't think they use LEDs lamps INSIDE the oven as the heat will destroy them. But if it is an LED lamp then this method will not work. Call for service and replacement.
Feb 21, 2018 | Roper Microwave Ovens
The bulb broke in the oven and I can't get the rest of it out
* Though I don't think they use LEDs lamps INSIDE the oven as the heat will destroy them. But if it is an LED lamp then this method will not work. Call for service and replacement.
Aloha, ukeboy57
Feb 21, 2018 | In Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Removing a broken light bulb
With the power disconnected, use a pair of needle nose pliers to grab the metal shell of the bulb to remove.
Jul 14, 2014 | Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Light bracket in over the stove ge microwave XL
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 06, 2008 | GE JVM1630 Microwave Oven
MH1150XMQ Lower Light Stopped Working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 17, 2008 | Whirlpool MH1150XMQ Microwave Oven
Broken bulb
From what others have said, it will come out, but you have to use some strong good needle nose pliers to turn the base in the socket.
Jan 12, 2008 | Whirlpool MH2155XP Microwave Oven
Broken light bulb
First of all, always disconnect the oven from the line before you remove or install bulbs, otherwise, you can damage the control board. We repair them all the time because of this. You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383 We have critical safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Apr 21, 2007 | GE JVM1430 Microwave Oven
Surface lights
I also have had a problem with the glass part of the surface light bulb separating from the metal base when trying to change the bulbs under my G.E. Spacemaker Microwave.. I see someone used a carrot or potato but I had not seen this suggestion before I whittled one end of a wine cork small enough to insert into the metal part of the old bulb stuck in the socket. It also worked great and in no time I was able to get the old base out and replace the bulb. I'll save the cork for next time because it seems to happen to at least one of the bulbs everytime they need to be changed. DON'T FORGET TO UNPLUG THE MICROWAVE FIRST!
Sep 05, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1740 Microwave Oven Logo
234 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
