Question about Kenmore 67082 Electric Dryer
Kenmore HE5t washer and F70 error
My washer is one week old and has been used 4 times. Yesterday it stopped and displayed F70. I did the rinse and spin cycle and it worked fine the next time. This has since happened two more times. Any idea?
  • 2 more comments
  • Anonymous Oct 27, 2008
    I have an F70 error on my washing machine
  • alanccy Dec 26, 2008
    I have used this he5t kenmore washer for more than a year, I have an error F70 at first then display doesn't work the next day. The day after, F71 appears then the display doesn't again...any ideas?
  • jopa2295 Dec 31, 2008
    I have the same problem on a Kenmore HE3t washer (F70 error). I researched on many sites & concluded the CCU needed to be replaced. I have since replaced the ccu & still have the same problem. Ran self diagnostic tests, which continues to stop at F70 error. Anyone with suggeted next step? Unit is just out of warranty.
  • Anonymous Jan 14, 2009
    No warranty..just out of warranty. Now what? What does F71 mean
    President:
  • 1,314 Answers
Yes call for service anything you do may void your warrenty
Posted on Feb 18, 2008
There is NOT a fix to this issue. Sears should recall the machines but as you can see from all the posts, they won't. Do not buy and if you can, return it.
Posted on Sep 23, 2009
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
Kenmore he4t washer codes
The control for the washer likely detected a problem. The failure code will not be displayed on all models of washers. You can recall the error code by using this procedure:
  1. Select the "Drain/Spin" cycle.
  2. Select No Spin.
  3. Press the "Prewash" options and hold this button for 5 seconds.
  • Immediately after those 5 seconds the last stored failure code is displayed for 4 seconds.
  • After those 4 seconds the display switches automatically back to the selection mode
NOTE: If your washer does not have the Pre-Wash option. Then use the 2nd Rinse button (called Extra Rinse). The failure code should stay in the memory so that it can be recalled as often as necessary and as long as it is the youngest failure Code.
Nov 30, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I have Kenmore HE5T Error code F71 Pls advise handling. Thanks.
F71 points at a connection error between button pad and control board.
Please read the indications in this article: F70 and F71 are two logic board error codes...
Regards.
Nov 07, 2010 | Kenmore Elite HE5t Washer
I got an F70 code . After unplugging the machine and then plugging it back in, I now get an F71 code. What to do?
Hi.
Please read the tip below, explaining how to fix F70 and F71 problems. The comment applies to Whirlpool built kenmore washers like the one in question.
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards.
Ginko.
Oct 16, 2010 | Kenmore Elite HE5t Washer
I am repeatedly getting an F20 error on my Kenmore HE5t washer. It seams the the spin cylce before the final rinse is the sticking point. I have to unplug, restart and finish the cycle with final rinsie...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advises to eliminate the easy common sense items first.
Oct 12, 2009 | Kenmore Elite HE5t Washer
What is code f70? washer wont start.
According to the Whirlpool cabrio / oasis manual
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} (F70)
Overloaded
oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity.
• Open the door lid to clear display, remove excess laundry, then restart the cycle.
Sep 27, 2009 | Kenmore Elite HE5t Washer
My kenmore he5t washer will not turn on. The on
I have the same problem . If I power cycle mine enough times I eventually get a F70 or F71 code. My research online suggests that the user interface board has a problem and needs to be replaced.
The good news is the warranty covers these boards for two years. The bad news is they are $360 if you are out of warranty.
HTH
Jun 12, 2009 | Kenmore HE5
Kenmore Elite HE5t Washer Error Code F11
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancell, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Jan 03, 2009 | Washing Machines
Kenmore 67082 Electric Dryer Logo
1,760 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
