Question about HP Pavilion 304w (DB282AR#ABA) PC Desktop
Funny behaviour possibly caused by a failing power supply
I'm trying to solve a problem with my hp pavilion 304w. It was working just fine, but then I put in an Nvidia GeForce 6200 pci card. Now sometimes I'll try to boot and it will act like it's booting but nothing will show up on the screen. Then when I get it to boot it will freeze in the middle of something and absolutely nothing but the power button will fix it. Also I rebooted a little while ago and it told be that my media audio controller driver needed reinstalling. It was acting Like I had just put in a sound card which I hadn't. Any ideas as to why all this stuff might be happening?
Thanks,
Calvin B.
  • 2 more comments
  • Claviner Jan 30, 2010
    I'm pretty sure it's up to date. I bought it new with the driver cd. I will look into the bios thing.
    Apparently none of these are my problem.
  • Claviner Jan 31, 2010
    Would a graphics card compatability stop sound drivers from working? I suppose it was multimedia controller which is not just sound.
    Ok. I checked the bios and it is fine. Everything is configured ok. I have a 200w "stock" power supply. I spoke with someone else about this. They said that graphics cards can take up a lot of power depending on how you use them. I think this is the problem. I will be testing it with a different supply soon. Thanks for your help.
  • 644 Answers
Does the board have onboard graphics? If it does you will have to dissable it in the bios. Try updating the the driver, goto my computer and right click, enter properties, goto device driver, click on the "+" next to video adapters and right click choose update driver and the the internet option, it takes a few minutes so be patient, also if you see any exclamation marks in the device manager tree do the same thing with them.
pls post back your findings.
Posted on Jan 30, 2010
  • 1 more comment
  • jimnuggats Jan 30, 2010
    It seems to be some sort of incompatibility issue with your graphics card, ive got a feeling it might be down to irq requests, if the pc has onboard graphics take the nvidia card back out and boot using the onboard graphics,or the original graphics card it cams with, the driver for that card may need to be uninstalled before you put the new graphics card in try it. pls post me back with the results
  • jimnuggats Jan 31, 2010
    The graphics and sound are all under multimedia so it possible that the two can conflict, if there driver is trying to use the same irq request then it would cancel the other out, i dont know for sure but i have seen this same type of problem with a Gateway computer i was upgrading, it just would not work properly with the nvidia graphics language for some reason, i dont know whether these factory built pcs are designed for upgrade unless you upgrade the bios, so that could be a possible sollution. If you have a look on the HP site to see if there is a program you can download to upgrade the bios you could give that a try, Make sure you understand how to do it before you attempt it because if it is not done properly you could corrupt the bios and the pc wont boot at all. post back and tell me what happens.
    If you only have a 200w power supply then it is advisible to upgrade it to update pcs, i'd say about a 350 to 450 w should be good enough, graphics cards do **** up some power. hope you do solve it by doing that and thanks for the post back. cheers.
Keyboard driver corrupt
HP has no record of either of these type numbers 304W or DB282AR.
Aug 03, 2012 | HP Pavilion 304w (DB282AR#ABA) PC Desktop
Power supply unit starts (fan running) but computer does not....
Try swapping out the ram 1 at a time, making sure there is one memory piece there while testing. If no! check hard drive for activity.
Mar 14, 2012 | HP Pavilion a1102n PC Desktop
Computer was updating and stopped working cannot get back into get it will not do anything the windows xp comes and then shuts off and comes back on i try everything but nothing works
Hello.
Sounds like an overheating problem. Could be memory, power supply or dust
If you are comfortable and knowledgeable, proceed ...
Disconnect all cables and remove the cover. Be certain to dispel static electricity by touching metal.
First, using compressed air, remove all dust in around the components.
If still a problem, remove all memory modules and install one module at a time to test.
If still a problem, most common problem would be the power supply needs replacing.
Hope this helps..
Jan 24, 2011 | HP Pavilion 304w (DB282AR#ABA) PC Desktop
Power supply has a continues blink instead of a solid led light.
HP skimps on power supplies, using a supply that has only a small margin of excess power. This causes the supplies to run under stress too often.
Make sure any replacement supply has the correct physical configuration for your system and replace it with one that is capable of 50% more power than the original rating; the cost difference is likely to be minimal and in any case lower than an 'original HP' unit of the same power rating that has now failed.
It is possible that a failed mother board or hard drive is causing your problem but you are risking well under $50 (for an ~400 watt supply) and will be getting a superior unit. eBay is a good source and you can seek a replacement using the Pavilion series name and then checking for your particular model number.
Oct 26, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
Werticle lines in pairs of four and long startup wait
your card is pulling too much power. check the wattage rating of the card and the wattage output of your power supply . good rule of thumb you want about 20% more that your card rating 450 watt card needs 650 watt power supply to run well. the extra is for your other stuff (dvd burner ,ect)
Feb 11, 2010 | Nvidia GeForce 6200 AGP Graphic Card
Hp pavilion 513n tries to start up then turns off
This is a case where something that is getting switched on during start-up is causing the power supply to fail... probably due to a short. How ever I believe the short is in the power supply
This is an older HP model ( I have a 530N) with teh same problem. I bought a new power supply and installed it.
Aug 14, 2009 | Computers & Internet
304w hp wont load
Try pulling the plug from the back of the machine or the wall and then plug it back in and see if it will come up. It may be stuck in what I call a voltage loop. You can also try re-seating the card and memory and making sure the cable from the monitor is connected firmly.
If it doesn't do anything it is possible that either the video card is going bad, the power supply is failing, memory is bad or possibly the motherboard is shot.
Let me know if I can help any further.
Cheers
Dec 29, 2008 | Computers & Internet
Hp pavilion a305w isnt working
sounds like it is in standby mode..........try pressing and holding the power button until it turns off fully. then remove the power cable to reset the power supply, wait for 5 mins then plug in and try again,
it is also possible that you have a fault , possibly a failed power supply, it might be best to investigate that if the power reset doesn't work
Sep 17, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
HP Pavilion 304w (DB282AR#ABA) PC Desktop Logo
119 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
