Question about Hotpoint Aquarius WMA42 Front Load Washer
How do I remove the drawer from my Hotpoint aquarius WMF 540 to clean it??? x
  • Hotpoint Master
  • 3,463 Answers
Open the drawer, lift or push it upwards, and pull it out towards you.
You should now be able to clean it.
Please rate my solution.
Thankyou.
Posted on Jan 30, 2010
Testimonial: "thanks"
Leak on rinse cycle aotpoint aquarius wmf 540
Check the door seal.could have small rip/ tear around Hinge or door lock position....
Nov 06, 2013 | Hotpoint Washing Machines
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
How do i clean the soap powder dispenser drawer? Can it be removed?
There should be a clip in the middle of the top of drawer you press this down quite hard to see it ,this then allows tray to be removed easy for cleaning
Jan 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Aquarius WM32. Will no longer use the conditioner from the dispenser drawer. dapchiles@talktalk.net
There is probably a blockage in the drawer.
Remove drawer and thoroughly clean all parts, making sure there is no residue of powder or conditioner in any of the compartments.
Nov 20, 2010 | Hotpoint Washing Machines
Can I remove the detergent drawer in a hotpoint hvl241?
There should be a release tab in the dispenser, push down, pull out
if NOT
Remove the screws along the rear top of the washer,lift the top, remove.
Nov 08, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius leaking
If this is leaking as its filling check its clean and nothing in it you can also remove drawer, check dispeser hose...good luck
Oct 01, 2009 | Washing Machines
At 20 minutes the drawer leaks
have you removed the drawer and cleaned the soap drawer holder ? as these can be blocked and cause this fault
Sep 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Water is leaking from soap dispenser only at beginning of cycle
Remove dispenser drawer, and check for soap blockage.
Locate and clean filter, check to see if there is one located behind bottom kick strip, if no filter there, then you will have to remove lower rear cover of washer, and locate and remove the large black hose on bottom of tub.
Remove filter and plastic ball,clean and replace.
Refit filter, ball and hose ,ensuring it is fitted correctly.
Test for leaks.
Plz ratev my solution.
Thanks.
Jan 14, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
615 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
