Question about Poulan Garden
Poulan chainsaw repair manual or routing new fuel lines, deterriorated from E10 use.
How to replace fuel system tune-up kit for. A poulan 1950 chainsaw need picture sample
Posted on Jul 24, 2013
    President:
  • 2,220 Answers
What you request to the best of my knowledge does not exist. You may find this helpful. Had you provided a model and serial number it would have been more helpful.
Typical fuel system and couple of suggestions:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
The IPL for you saw can be found here:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If I can be of further assistance you can reply below. I hope you found this most helpful.
Lou
Posted on Jan 30, 2010
Polan 3400 fuel line route?
I haven't seen a manual yet that shows you the fuel line route on a piece of equipment.. Generally its the most direct route from tank to carb to primer (if it has one)
May 19, 2016 | Poulan Garden
Need fuel lines diagram for poulan pro ppb1838 chain saw
How to ... Poulan Chainsaw - replace fuel lines - YouTube
? 5:05
www.youtube.com/watch?v=jZqCNiYgF3g
Mar 27, 2012 - Uploaded by minthillbilly ... and demonstrates how to diagnosis and repair a Poulan 2700Chainsaw. ... I have a brand new Poulan Pro, the hose went bad
Jul 31, 2015 | Poulan Garden
How to rout fuel lines to primer bulb on poulan 14" chainsaw
Short line on primer bulb goes to the left side of the carb. The long side on the primer bulb goes to in the fuel tank as the return line.
Jul 23, 2014 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
Jul 13, 2010 | Poulan 14" Chainsaw
Will not run new fuel lines but does not crank, poulan micro xxv
I suspect hose routing may be in error. Is it like this?
If it is, please reply below and we will continue with an attempted repair. I hope you found this most helpful.
Lou
Jan 30, 2010 | Poulan Garden
I need the fuel line routing or diagram for a Poulan Predator 2150 LE. I have parts list but it does not depict the fuel detail I need.
Jimmy there are no Poulan drawings with fuel system detail worth the ink it takes to print them, but that is all there is.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb (once compressed bulb draws fuel as it returns to normal) , bulb (as it is compressed) returns displaced to fuel tank. HTH
Lou
Oct 22, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Fuel line crack dry out, in pieces
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Find your saw here:
Poulan.com
SmallEng.com
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
I think the second line on the carburetor is an impulse line and connects to the crank case. HTH
Lou
Oct 08, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Sep 14, 2009 | Poulan Garden
Poulan 2150 type3 / a show me diagran of fuel line hook up from primer bulb to carburator
I have a McCulloch 3200 chainsaw with a cracked primer bulb and all the fuel lines were gone. I cannot locate any information on routing these lines to the carb. I have a new primer bulb and 3/32x3/16" fuel line. Please help me solve this problem.
Aug 16, 2009 | Poulan Garden
Routing of fuel lines from tank to primer bulb to carb
Line with filter goes to carb inlet,
Line from carb goes to inlet side of bulb.
Line from bulb goes to tank
Mar 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
1,170 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
