Lexmark X7170 won't print
I have a Lexmark X7170 all in one that will not put ink on the paper. Head cleaning and three new black ink cartridges (#34) have not helped. Right ink cartridge has not been changed but the maessage is ''right ink cartridge incorrect'' Any thoughts?
4 Suggested Answers
Roop1980
  • 228 Answers
SOURCE: error:2200
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Posted on May 14, 2009
  • 16 Answers
SOURCE: installed a refilled black 34 cartridge on a X7170
Try one of these things it fixes it some of the time.
I don't know where you got yours refilled, I use PrintPal. (www.printpal.com/card15) I have yet to have one go bad on me. Look for whats called a jet pack mailer. You send them empties and they send you refills. You have to buy the shipping containers then process them. Its worth it!!!
Whenever you get refilled cartridges, set them upright (like they were installed in the printer) for about 15 minutes. It helps the in to level off where it should be.
Run the cartridge surface where the ink come out under a small trickle of warm water. It helps to open clogged ink openings.
Have you removed the shipping sealing blue tape? I know its a stupid question but its easy to forget to do that.
Are they in and locked securely in place? Some machines are picky.
Have you run the usual alignment and cleaning functions?
Im not a 100% sure of this, but I think it has to be a 33 to be a black.
Use a lint free cloth to brush rubbing alcohol on the place where the circuits are on the cartridge. Let it air dry then try it again.
Posted on May 31, 2009
frankgilbert
  • 613 Answers
SOURCE: I have a Lexmark x7170.
Some older print cartridges are not compatible even if your model is listed on label. I'm talking a few years difference. The printer knows this and that is what the error is telling you. Make sure you have the right number in the right slot.
Posted on Jan 06, 2011
Hey, I have the X7170 printer and haven't used it for about a year. Now, the fax, and scan works fine, but when I print a paper, it comes out blank even if the ink catridge is full. Seems that there is...
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
Jun 24, 2011 | Lexmark X7170 All-In-One InkJet Printer
Replaced new ink keeps saying right cartrige is incorrect wont let me print. the cartrige is correct i paid $50.00 for a two pack of black and color ink!!!
Wiping the nozzles with a moistened soft cloth or removing and reinserting the cartridges usually helps. The cartridges for the Lexmark X7170 are black: 32/34 and color: 33/35. If these are the cartridges that you purchased and even tried your old and new cartridges yet the problem persists, please don't hesitate to contact Lexmark technical support.
Mar 23, 2011 | Lexmark X7170 All-In-One InkJet Printer
Ink cartrige problem i replaced both cartriges keeps saying right cartrige is incorrect wont let me print
Mar 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Put black ink cartridge in and the printer does not realize it is in the black ink port (this question is for my son that is away at college) get an error message
Black printer ink in Lexmark Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Oct 26, 2010 | Lexmark Z2300 InkJet Printer
My ink levels are fine but print is very faint and lines are missing, it is illegible
Your print head is clogged or damaged. Press the print head into a paper towel. You should get a nice block of black or three stripes of color. If not, try placing print head on paper towels soaked with warm water to get the ink flowing (ink may soak through paper towels, so beware of where you do this). Then try pressing the print head onto dry paper towels as before. If you can't get the ink flowing, you need a new cartridge because the print head is clogged with dried up ink.
Dec 19, 2009 | Lexmark Office Equipment & Supplies
Error:2200
May 13, 2009 | Lexmark X7170 All-In-One InkJet Printer
Mono color
These models use a "3 colour" printing process. In other words, these printers do not contain black ink when the BC-05 colour cartridge is installed. To produce black print, a 3 colour printer mixes an equal amount of the three primary colours. This process is known as "composite" black.
As the ink in the cartridge runs out, one of the three primary colours will run out first, depending on the material that has been printed. After one of the three colours has depleted, this colour will be missing from the mixture required to print black, and the print will change colour. This is the indication that the cartridge needs to be replaced. Usually the remaining colours in the cartridge will run out soon afterwards.
Rate the solution as appropriate !
Feb 07, 2009 | Lexmark X7170 All-In-One InkJet Printer
Message wrong cartridge on lexmark 7170 printer
for Lexmark x7170 ink cartridge is #32 and #33.
double check the number on the ink cartridge. and make sure to take the tape off the bottom of th eink cartridge before insert it in the cradle.
as far as the cleaning. there are contact pins in the ink cradle and on the bottom of the ink cartridge.
clean them using a coffee filter with little alcohol.
Dec 03, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printer doesn't print even with new ink cartridges.
Take out the Cartridge & get a new one if the problem persists then get the printer software reinstalled & if still it is not printing then clean up the cartridge head with cotton swabs dipped in hot water!
This should clean the head & black will be on paper
DO THIS AS FINAL REFUGE
If still its not working then there's some problem in the copper contact surface in the printer on the cradle so get a new Printer.
Mar 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
108 people viewed this question
jasbo
jasbo
