Question about Zanussi ZDQ495 Electric Double Oven
Cooling fan is very noisy - Zanussi ZDQ495 Electric Double Oven
  • Zanussi Master
  • 3,463 Answers
It is probably a worn fan bearing, or loose or broken fan blade.
You could try spraying the bearings with WD40,
which may quiten it down, but normally the only solution is to replace the fan motor complete.
[Please rate my solution.
Thankyou.
Posted on Jan 30, 2010
Top oven (Grill) makes a noise when turned on
It will not be the grill that is noisy, but more than likely the top oven cooling fan located under the top cover of oven
Mar 27, 2015 | Ovens
What would happen if fan is disconnected noisy and not wanted?
NO NEVER EVER DISCONNECT FANS OR ANYTHING ELSE ON YOUR COOKER.
Your cooker may have at least two fans, one for heating the oven cavity and one for cooling the electrics etc inside the oven. If the fan is noisy, check to see the fan has not come loose on the motor (maybe left had thread) if the fan is ok, then the fan motor may need replacing!
Oct 20, 2014 | Ovens
Very noisy cooling fan.
The only way to fix it properly is to replace the cooling fan I have tried every other way possible at some point
Apr 21, 2012 | Electrolux EOG6330 Gas Single Oven
The cooling fan on model CPS 127 is making a noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Plz rate my solution.
Thanks.
Oct 25, 2010 | Dacor Ovens
Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Dec 02, 2009 | DeLonghi Ovens
Very noisy fan
Hi
you need to replace the fan as this will be the cooling fan which cools the oven down. and can not be disconneted .
regards
Mar 21, 2009 | Kenmore Ovens
Noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Zanuisi top oven making noise
Thanks.
Dec 31, 2008 | Zanussi ZDF490 Electric Double Oven
Noisy fan
it has to be replaced the bearings are shot on it I'm afraid well knowen problem in are trade.
Apr 12, 2008 | Belling XOU492 Electric Double Oven
Jenn Air SVD48600
One of the relay boards is a downdraft relay board....I would be suspecting the main clock assembly as it is the one that shuts down and controls everything. This might also increase the fan speed randomly, turn it on at random temperatures etc., You have to get a new board. You can find it here
http://www.affordableappliance.com
Feb 27, 2008 | Ovens
Open Questions:
Zanussi ZDQ495 Electric Double Oven Logo
333 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
