Question about Air Tools & Compressors
To Whom it may concern, I got given a Porter Cable air Compressor Model C6110. The motor runs but the tank will not fill. The gauge on the Regulator just flickers. I have checked the valves and they seem to be intact. Do they wear out and not physicaly break? I was just looking for breaks in them. The piston moves freely but has no resistance, but because it is oil free that is probably how it's supposed to be. Their is a valve at the bottom of the tank that seemed to be leaking but when I tightened it and I think it stopped but I am unsure. their is also a leak where the regulator is but it has no body QC attached to it. can you assist me.
    President:
  • 2,030 Answers
The valves do both they wear out and they break alot on those models.
By the time you buy the repairs parts and put the time into it, you could have bought a new compressor.
Posted on Jan 30, 2010
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
Brand new, just bought it. Actually had to take it back and exchange; this one is doing the same thing. The gauges to do not go past zero. Would adjust regulator, but still nothing. What is going on?
Is the tank actually filling up with air? Have you checked the drain valve on the bottom of the tank and made sure it is tight. Porter Cable may ship these with the drain valve open because part of their break in procedure is to run the unit for 15 minutes with the drain valve open. This procedure can be found around page 12 of your owners manual. Weather or not the drain valve is open I would run though this break in procedure and see if the gauges start working. If still no luck with the gauges it can be other issues like The gauge supplier sent PC a batch of faulty gauges and because you bought your units back to back they both came off the same run. Before going back to the retailer and risking a 3rd set of bad gauges I would contact a local DeWalt/Porter-Cable Factory Service Center, they can be located at www.dewaltservicenet.com and see if they have a resolution or can ship you new gauges.
Oct 10, 2010 | Porter Cable C2002 150 Psi 6 Gal...
I SEEM TO BE HAVING A PROBLEM WITH MY TANK PRESSURE. MY TANK PRESSURE SITS AT ABOUT 80 PSI AND THE REGULATED PRESSURE SITS AT ABOUT 70 PSI,IT DOES NOT GO ANY HIGHER, IS THIS NORMAL AND IF NOT WHAT DO I...
The C6110 is an oil free air compressor and has a piston ring that needs to be replace as part of regular service.
When the piston ring is worn out it will just keep pumping but it will not go over 80 psi or so because to much ir is passing by the ring.
Here is a parts diagram:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/C6110/C6110_PL.pdf
It sounds like the piston ring DAC-308 needs to be replaced. You can also replace the complete top end.
This is a pretty easy repair and can be done in less that 1 hour.
Sep 27, 2010 | Porter Cable C6110 150 PSI 25 Gal OilFree...
My compressor sat idle for just over a year. Before it was idled, I bled it down completely and closed the drain valve. When I re-started it this year, the motor was very sluggish as if there were a heavy...
Down time is ******* motor capacitors , replace motor capacitors , start or run capacitors , usually on outside of motor . Under a cover with one or two screws . They will be marked with voltage and microfereds ratings .....
Jun 11, 2017 | Porter Cable C6110 150 PSI 25 Gal OilFree...
Porter cable stand-up air compressor starts but air won't fill up
Might be the unloader valve is stuck. if so there will be hissing noise from switch assembly and you may have to get a new one.
Jun 04, 2010 | Porter Cable C6110 150 PSI 25 Gal OilFree...
I have porter cable vertical c6110 compressor bought 16dec2009 two weeks later cover for motor housing broke off on its own tech at store told me he has had three similar reports ...is this a common defect...
If the tech at one location has already had three failures of this type, there must be a design or application concern. Get the consumer helpline for delta/porter cable from the store where you bought this and let them know it is a defective product, and you would like to have it updated to a more usable design. They will listen, and may give you another unit outright.
Jan 19, 2010 | Porter Cable - Cable C6110 Oil Free...
No air pressure thru quick connect to tools-bag regulator?
I dont know if it is like mine,but if you can let the air out of it and remove the regulator knob,and it`s components,you may can set it to just to be open all the time,in other words,by pass the control knob valve.Shout back at me if I can help.
Nov 06, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Extra fitting on my Porter Cable?
CANT FIGURE OUT WHAT YOU HAVE. IF ITS ON THE REGULATOR - THE REGULATOR USUALLY HAS AN INLET, OUTLET, GAUGE PORT AND A PLUG IN THE OTHER SIDE IN CASE YOU NEED TO MOVE THE GAUGE. SOME MANUFACTURERS PUT SAFETY VALVES IN THIS PLUG PORT. IF THIS DOESNT FIX IT GIVE A LITTLE MORE DETAIL. IS THERE ANYTHING WRITTEN ON IT. HOPE THIS HELPS, JODY
Apr 26, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
