Question about Estate TAWS850PQ
Final spin cycle not working properly, clothes still wet
    Genius:
  • 1,122 Answers
Bad clutch
Posted on Jan 30, 2010
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Will not spin
The final cycle of any washing machine, including Whirlpool units, is the spin cycle. During this cycle, water is sucked out of the load, preparing the clothes for the dryer. If your spin cycle isn't working properly, your clothes will be extremely wet, which increases the length of the drying process. Troubleshoot, and repair this problem yourself to save money
Jul 29, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
When its on the final spin and completed clothes are still wet
The pump is mounted on the motor so the water is removed and that means the lid switch is working. I think you might have a broken drive coupling. Almost certainly it could be the coupling. This is a common failure of these machines. It can be triggered by washing a heavy load. themobilian_1495.jpgthemobilian_1496.jpgthemobilian_1497.jpgthemobilian_1498.jpgthemobilian_22.pngthemobilian_1499.jpg
That is the simple answer and should fix the problem but what IF the coupling is ok?
Then you gotta dig deeper into this machine. Let me know.
Feb 15, 2011 | Kenmore 22642 Top Load Washer
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Cloths still very wet after final spin cycle
Use spin ccyle again for proper operation and to help remove water.
Apr 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
My wash machine wash the clothes but not doing the final spin, all the clothes all soak and wet
Handyman here -
Its possible that the door is not locking properly. If the door doesn't lock the machine will wash, but not spin the clothes dry. If you wait 15mins or so after machine is done, then set cycle to spin, it will pump any water that has dripped off your clothes out, but again it will not spin. Helps a little.
Good Luck!
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Clothes still wet after final spin cycle
It sounds like you might have a broken belt or the belt just slipped off the pulley!
Jan 22, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Estate TAWS850PQ Logo
126 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
