Question about Philips 42PF7320A 42 in. Plasma HDTV
When we turn it on, the menu automatically pops up and when we try to exit, it goes away for a brief second then pops back up. We can hear the TV show in the background, but the menu screen blocks you from seeing anything!
We have the same problem that just started about 2 weeks ago. Have you gotten your tv fixed yet?
Posted on Feb 12, 2010
    Problem Solver:
We just started having this problem yesterday. No solution yet!
Posted on Apr 03, 2010
I had this same problem. I completed the softwared upgrade and it fixed it! hope this helps
Posted on Apr 05, 2010
HHHMMM, we just started having the exact same problem, it started 5 days ago.
Posted on Mar 24, 2010
I have the same problem with my tv as well..has anyone found out the problem??
Posted on Mar 20, 2010
The TV menu options keep popping up aprox. 15 mins after turning the TV on.
Do a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 09, 2017 | Televison & Video
I have a new toshiba lcd tv 55s1417u and I have went through the basic setup that comes up when you first turn it on but now I'm trying to do the settings but when I hit the menu button on the remote...
Good day!!!!
I need some clarification...
If the settings is gone then go to the TV mode..or the settings is gone and no picture?..or the settings is gone then the back light is gone..
Please reply to this tread to give you a specific solution..
Thanks for using fixya...
Aug 27, 2011 | Televison & Video
Philips Tv always returns to menu screen
ssb board failing need to be replaced encompass.com
Sep 17, 2009 | Insignia 42" LCD Flat-Panel HDTV
Menu pops up while tv is on
Isolate the problem by removing the batteries from the remote. If the problem goes away replace the remote: "CHEAP" .
If the problem does not go away, the problem is in the TV, repair the TV "EXPENSIVE" !
Aug 28, 2009 | Televison & Video
Menu Screen keeps popping up, interrupting cable stream on tv
You have it in the demo mode go into menu and turn it off.
Aug 06, 2009 | Televison & Video
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 42PF7320A 42 in. Plasma HDTV Logo
499 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
