Question about Lexmark X4270 All-In-One InkJet Printer
Fax answer machine
I have tried putting my answer machine on 2 rings, no fax,
then i tried 4 rings and i get no answer machine.
the line in is in the proper connection and the answer machine lead comes off the the fax line ext.
What am I doing wrong?
    Genius:
  • 2,035 Answers
FAX RECEPTION THROUGH AN ANSWERING MACHINE:
This mode is recommended for a shared fax and telephone line.
To receive a fax if your All-In-One is connected to an answering machine:
On the control panel, press Fax.
Set the answering machine to answer incoming calls before the All-In-One does. For example, if you have set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
To change this setting on the All-In-One:
Press Options until Number of rings appears.
Press the right arrow (+) until After 5 rings appears.
Press Select.
Make sure the Auto Answer light on the All-In-One is on. When a ring is detected, the answering machine picks up the call.
If a fax is detected, the All-In-One receives the fax, and disconnects the answering machine.
If a fax is not detected, the answering machine completes the call.
Posted on Mar 13, 2008
I have an officejet 6500 all in one printer and I am setting up the fax section. It sends and recieve OK but my answering machine is picking up before the fax machine. How can I change that around so the...
You need to check the setup ..
The telephone line which is coming from out should be connected to the line 1 of the printer and Telephone answering machine should be connected to Line 2 .
2. You also need to check that after how many rings the Telephone answering machine answers the call you have to keep the "Rings to answer" 2 less than that of Telephone answering machine.
Lets assume that your Telephone Answering Machine answers the call after 4 rings then keep the rings to answer in All in One to 2
How to set Rings to Answer
1. Press the Setup button on the Front panel of the printer
2. Scroll Down and go to Basic Fax Setup - Select it
3. Scroll down and got to - Rings to Answer - Select it
4. Set the Rings here and then try Fax
it will fix the problem :)
Feb 26, 2011 | HP Officejet 6500 Wireless All-in-One...
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
How to set hp1040 fax to work with aout answering
If you are using the same phone line as your fax, you can start by connecting the answering machine on Line2 or 2-Ext at the back of the fax. Set the fax to answer on two rings higher than the Answering Machine. (for example: if answering maching is 4 rings, fax is 6 rings)
And then, turn on the auto answer.
Mar 22, 2009 | HP 1040 Plain Paper Inkjet Fax
Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Feb 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How can i change the ringer on my fax machine?
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Dec 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
How do you set the number of rings on a brother 560 fax machine
Setting Ring Delay:
Chris (ziraffa)
Nov 26, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Fax pick up
Greetings Nana,
I believe that you can specify how many rings should occur before your Kodak 5500 Ai Printer automatically answers an incoming call (default = 4).
If you have a dedicated fax line, set the Rings to Answer to 1 or 2.  If you have a shared line for voice/modem and fax, set the Rings to answer to 3, 4, or 5. This setting only applies if Answering Machine Mode is set to OFF.
When the Answering Machine mode is disabled, Rings to Answer applies and your AiO printer answers the call. When your AiO printer detects a fax tone, it receives the fax. When a voice call is received (no fax tone), the call is ignored.
1 Press Menu to display the main menu. 2 Press scroll down until Fax Settings is displayed. 3 Press OK to display the Adjust Fax Settings menu. 4 Press scroll down until Rings to Answer is selected. 5 Press right or left arrow to change the number of rings.
Give it a try, Nana, but let Kodak know if you need additional help. They will be there for you.
Ron Baird the friendly Kodak guy
Sep 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Brother Multi function centre with fax, MFC 885CW we have the setting on F/T, it answers a fax after 2 rings, if a call coming in it keeps ringing, but on callers end it keeps beeping fax noises, callers...
I had the same problem using my Brother MFC 8460N fax on the same line as my regular telephone, which has an answering machine.
There was nothing wrong with my equipment. It was a set-up issue. I solved it as follows, and maybe this will be helpful to you:
Here's what I did, step by step:
1. Put your MFC and your telephone near each other, and within reach of a phone wall jack.
2. Go to the fax machine. Take the telephone line with the clip on the end of it that comes out of the fax machine. Put that into the telephone wall jack.
3. Go to the answering machine. Take its telephone line with the clip on the end of it and put that into the BACK OF THE FAX MACHINE. The port on the back of my fax machine says something like EXT TAD which means external telephone answering device.
4. Go back to the fax machine. You'll now need to play around with the menu options for the fax. My Brother MFC shows this stuff in a little screen on the front. Try and find the Fax Setup options. Next, try and find the Fax Receive options. If you do, select something like External TAD fax receive mode. Do not give up, you're almost done.
5. Next, set ring numbers on both devices, the fax machine and the answering machine. I set both devices' ring numbers to 4. I don't know if these are the optimal settings, or what happens if you set them at different ring numbers. I only know that a "4 and 4" setting works for me, and am not inclined to mess with it.
6. Final detail: the setup should be transparent to a voice caller. Someone who is sending a fax, though, might be a little confused IF, like me, they lean over to listen to their fax machine dial and screech, just to be sure it's working. Such a person may faintly hear my outgoing answering machine message before they heard my fax machine's screech kick in. They might think that they had a wrong number, cancel the fax, try again, call me with questions, etc., etc. So I changed my outgoing message to something like: 'You have reached xxx xxx xxxx. To leave a voice msg, please wait for the tone. To send a fax, please continue the transmission and it will be printed. Thank you!'
That's it. Hope this was helpful.
Best,
Wilbere
Check out my listings on http://stores.ebay.com/WILBERE
Aug 07, 2008 | Brother Office Equipment & Supplies
Lexmark X4270 All-In-One InkJet Printer Logo
477 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
