Question about Hotpoint WMA44 Front Load Washer
Wma44 hotpoint washer. Did a wash as normal and
Wma44 hotpoint washer. Did a wash as normal and the machine didnt complete full cycle. It got to the last 2 notches before 'off' marking on the dial. The door lock light was flashing new interlock switch fitted and door locked still flashing. Any suggestions. Are ther any relays?? which may be sticking any ideas where or is it all control through pcb. Thanks
  • maxmj Jan 30, 2010
    Hi, The door handle/spring is well tensioned. The machine now does the wash and goes to the 'ff' position on the dial but does not allow the door to be open afterwards. You know normally he hear the door interlock at the start and finish this dont seem to be happening - would you agree its the pcb as cannot see any relays/coils anywhere which control the interlock?? thanks
  • Hotpoint Master
  • 3,463 Answers
Sometimes a weak or broken spring in the door handle can be the cause of the problem, but you would have to take the door apart to check this.
If you have already fitted a new door lock, then chances are it is the control board, but I would check the door handle first.
Posted on Jan 30, 2010
Testimonial: "Though tride most of advice a very quick and helpful reply, many many thanks to you, regards max."
  • Barry Coates
    Barry Coates Jan 30, 2010
    Make sure there is no water left in washer, as this can sometimes prevent door from opening, if you are satisfied that everything else is o/k, then I would suspect faulty pcb.
    Good luck.
WMA44 Hotpoint machine - the door light continues to flash before starting... what could be the problem
Could be a broken spring in the door handle, you would need to take the door apart to check this.
Jan 16, 2010 | Hotpoint WMA44 Front Load Washer
Wma44 washing machine door lock light flashing
probably the solenoind/coil or ETA relay faulty
Sep 03, 2009 | Hotpoint WMA44 Front Load Washer
Drum bearing very noisy on my hotpoint wma44 wshing machine
Sounds like the seals have gone as did the ones on mine. It need a complete new spider frame and bearing set as the front bearing had collapsed and groved the bearing spindle. Open the door and try lifting the drum to see if there is any up/down movement.
Aug 31, 2009 | Hotpoint WMA44 Front Load Washer
My washing machine really smells, what can i do
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Aug 06, 2009 | Hotpoint WMA44 Front Load Washer
DRUM BEARING NOISY ON HOTPOINT WMA44
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites with your model number
Feb 27, 2009 | Hotpoint WMA44 Front Load Washer
Hotpoint aquarius plus WMA44
Will be blockage in sump hose .more info req. if this is not right
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wma44 - water not draining
I guess you or a friend will have to get out and get under to strip out the pump and take a looksee. Put your bathing suit on.
Sep 14, 2007 | Hotpoint WMA44 Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Door Lock
door lock blown this sometimes blows tracks off the main pcb behind the control panel. appliance doctor
Jan 29, 2007 | Hotpoint WMA44 Front Load Washer
Hotpoint WMA44 Front Load Washer Logo
338 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
