Question about Honeywell Fan Timer Board St9120c 2010
The blower controlled by my Honeywell ST1920C controller will not start. I pulled the blower out and plugged it stright in and it works is it the board that is bad?
  • lrgraves Jan 30, 2010
    Thank you for your quick response. How do i jump the relay?
  • Honeywell Master
  • 43,501 Answers
Yes, the relay in that board does go bad. If the blower works then you know that it is good and if you have power going to the board and the blower does not kick on then replace the board.
I have already just jumpered the blower and left it run so people would have heat till I was able to get a new board.
This is a temporary fix that will not hurt anything, just use a bit more power...at least you can get warm...
Heatman101
Posted on Jan 30, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Jan 30, 2010
    To jump the relay you just need to find the wire that hooks to the "heat tap" on the board.
    Then run a tempoary wire from the line to that wire and it will run your blower continously.
    What you are doing is just what you did to check out your blower.
    Heatman101
I show voltage to the blower motor but it does not start when i press fan on the thermostat? Bad relays or bad blower motor?
Sounds like a bad motor. I don't know if your blower motor has an external starting capacitor and / or a running capacitor. If There is a starting capacitor and it's faulty , that would prevent the motor starting and turning.
Jun 01, 2014 | Honeywell R856B 1002 R856B1002 Fan Control
Blower on heat pump blowing with no demand
There is a contact in the blower control card that can stick on. There is also a possibility that the green wire which starts the blower motor could be shorting out with the red wire somewhere inside the thermostat wire. If that is the problem, either pull new thermostat wire, (the rest of the insulation is probably breaking down) or there is some new red link controllers from Honeywell that will completely eliminate wire because the controls are all wireless.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
BLOWER MOTOR NOT WORKING
check the fuse in the compartment.
Feb 07, 2013 | 2008 Jeep Wrangler Sahara
Have old Carrier standing pilot furnace. Furnace calls for heat, but blower does not come on for almost 1 minute. How can I make blower some on sooner??
If it has a honeywell fan control, the cover can be pulled off and the setting can be lowered by adjusting the small lever on the dial, if it is a timed control it probably has no adjustment unless it was replaced with an adjustable fan control.
Oct 30, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have 1999 jeep grand cherokee and the heater blower,climate control,a/c,and heated rear window switches.have all stoped working. also how do you remove the centre bezel witch houses said items its a 4ltr...
I have the same vehicle,  to remove the centre mounting use a small hook ended tool, metal or strong plastic and start at the bottom of the fascia and pull outwards.  There are three retaining clips at each side, once the bottom two are off the rest pull off easily.
The non working switches sounds like a harness problem, it is difficult to think that all the fuses for each item could have fused at the same time, nevertheless check the fuses in the control box.  If you need a wiring diagram email me for a free one alfabeta@fsmail.net
Tony
Aug 25, 2011 | Jeep Grand Cherokee Cars & Trucks
I have a 1996 chrysler t/c . the front blower motor
the blower motor is probably starting to seize,and caused other problems
Aug 10, 2009 | 2002 Chrysler Town & Country
New climate control unit but when on blower not working for heat or ac
I'm assuming the problem is the blower motor isn't coming on or working. 1st, check the fuse. 2nd, remove the glove box or pull the 2 tabs that act like stops when it's open ( the glove box will open out further) and you'll see the power plug connector for the blower unit. Turn on the blower through the climate control (heat, A/C, or whatever) and wiggle the connector to see if the blower turns on. If starts working, then an easy solution is pull the connector off and gently press the prongs together or inward. Then carefully reconnect with damaging the prongs. This worked for 96 Mark VIII due to the fact the prongs were not "seating" correctly in the female connector. It's been about 2 years since I did this and the connection is still good. If wiggling the plug doesn't work, pull the plug, turn on the climate control (heat, A/C), and check for voltage to the plug. That's about all I can help with.
Apr 20, 2009 | 1998 Lincoln Mark VIII
Blower fan runs to long
ther might be dip swiches on the circuit board you might have to change
Dec 17, 2008 | Honeywell Power Humidifier: Furnace...
Honeywell Fan Timer Board St9120c 2010 Logo
221 people viewed this question
Top Honeywell Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Honeywell Hardware and Accessory Expert? Answer questions, earn points and help others
