Question about Gaggia Classic Espresso Machine
Where do i purchase a new water tank - Gaggia Classic Espresso Machine
  • Gaggia Expert
  • 109 Answers
Where are you located?
Posted on Feb 04, 2010
I need to purchase a new water tank where can i buy from?
You would need to say where you are, and the brand and model of the appliance before anyone can assist you.
Mar 17, 2014 | Refrigerators
Vax co uk support
There are a number of possibilities. I have this appliance and I'm not a fan of it!
  1. Check the water filter isn't void, which is behind the main water tank at the front. It should have a sandy colour to it and if it is low or discoloured, then it requires to be replaced.
  2. Fill the water tank with water and the back tank (if fitted) with clear "white" vinegar and switch on. If there is only one tank fill half with water and vinegar. Then press the trigger on the handle. If nothing comes out, You will need to buy a new water limescale filter which can be purchased from Vax UK.
Oct 31, 2013 | Vacuums
WATER INSIDE THE REFRIGERATOR
Blocked drain trough or if its an ice and water machine, there could be a leak in the water tank which is usually situated behind the crisper drawers. Clear the blocked drain with warm water or remove spilt food which may have blocked the water outlet. If its the water tank leaking, you will need to purchase a new one.
Oct 20, 2013 | Refrigerators
Can't locate fresh water tank drain valve on 29X
Should be at base of tank. Crawl under and look for small 1/2 hose pointing straight down. This should be the drain line. Follow it back to the tank. Valve will be there somewhere.
Apr 20, 2013 | Thor Motor Coach 2013 Hurricane 29X
Leaking hot water heater
If it is older than 15 - 20 years and leaking on the floor under the tank, purchase and install a new appliance, If the T&P valve is leaking, change the valve. If it still leaks, replace the expansion tank which should on the supply water line. Try not to install an expansion tank "on its side". BEFORE YOU DO ANYTHING, make certain your incoming water pressure does not exceed 65 -70 psi. This could be the real problem. If so, install a new water pressure regulator. It is usually located inside the basement wall. In a Garden Home, it may be outside at the curb in the ground by the water meter. It may be in the ground buried near the entry through the foundation. It may be near the water heater.
Feb 02, 2013 | Water Heaters
Water leaks out of the clean water tank valve
This was a very common problem with the earlier tanks on this model. The newer tanks can be identified as a single clear plastic molding, and the older, defective tanks had a separate soap container glued to them, usually blue or green in color. If you look carefully, I think you will find the leak is due to cracks in the plastic beneath the valve. Purchasing a new tank should solve the problem. ( Part # 42272104 ). It is probably worth a call to Hoover, to try to get a new tank at no charge.
Apr 19, 2011 | Hoover F7431-900 SteamVac Vacuum
Seal between tank and toilet are leaking
Purchase a new flush valve at hardware store.
You'll need cresent wrench, locking pliers, small pipe wrench, small pail, towels, putty knife.
turn off water supply, flush toilet to remove water from tank, soak up remaining water with towel in tank, remove supply line from valve on botton of tank (you may have to hold valve with pliers inside the tank to keep from turning.) Clean area inside tank with putty knife where new valve will seat. Install new valve, attach supply line, connect overflow tube. turn on water.
Check for leaks.
Repeat if necessary. :-)
Oct 27, 2009 | Jacuzzi Home
Flush valve is broken how do I fix it ?
Check for leaks.
Sep 14, 2009 | Home
Gaggia Classic Espresso Machine Logo
18 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
