Question about LG LSC091PMA Split System Air Conditioner
Had a Fujita Split System installed by a professional but it keeps on losing the refrigerated gas. He checked the lines for leaks with a gas detector but nothing showed up. We have re-gased it 3 times but the system keeps on losing the gas..any solutions?
  • 1 more comment
  • sk35 Jan 30, 2010
    Wouldnt the leak detector pick up the leak in the system as well? He also did vacumn out the lines on instillation.
  • sk35 Jan 30, 2010
    Hi, the unit is a Fujita KF-70GW (cooling only) and it was purchased new. I had it in garage for 2 years before i installed it though. The Outdoor unit is directly behind the Indoor unit at approx 2-3 metres away. It seems to work when we re-gas but next time when i use it it just blows out air and not refrigerated.
  • sk35 Jan 31, 2010
    Thanks for the advice, is there a way of checking if the compressor is the cause? Would a gas leak check detect leaks from the compressor? Also it is only a small bedroom and it was stored where the temp would not venture over say 40 at the most, Is it worth getting someone else in to check the compressor or should i save my time and buy another one?
    regards
  • LG Master
  • 3,247 Answers
Looks like your problem has landed in the wrong category under LG aircons with an LG model name.
Are you able to post the model no. of your FUJITSU split system.
What is the approx distance between the outdoor unit and the indoor unit (pipe length).
Is this a second hand unit? If so, do you have confirmation that it was working in the previous place.
Posted on Jan 30, 2010
  • Sam Jan 31, 2010
    Sorry to hear that you are having this problem with a new unit. Unfortunately, being out of warranty may not be much help for you either.
    If it is running out of gas immediately after you turn it on then it is likely a faulty compressor (could be manufacturing defect or dried out seals during storage). Vacuum test that the installer did would only check for leaks in coils and tubes. But if compressor is not working correctly then you have no chance of recovering the refrigerant during cooling operation.
    However, if the unit starts cooling and after some time blows hot air then you need to find out whether the size of the unit is adequate for your room, ie, is the compressor getting overworked causing it to loose the refrigerant.
    I cannot find much information on the internet on your make and model of the aircon so cannot tell you much further. If you have the receipts etc you could approach the selling dealer with the problem and ask for replacement under warranty - if you can prove installation was done recently by a qualified technician. You also have to be careful not to break the storage specifications provided by manufacturers. In other words if you left the unit for 2 years in a location where temperatures were higher than recommended (eg in a shed with 50deg + temperature through summer) or too humid.
    Good luck.
  • Sam Jan 31, 2010
    If the compressor is the problem then it is not usually a leak but the inability of the hot refrigerant in gas form to cool down back into liquid so that it can be recirculated through the system. It is not a static test. The compressor has to run.
    The following website will give you some idea of how these systems operate. You need to scroll down and also click on links within.
    http://www.inspectapedia.com/aircond/air...
    If the installer is not knowledgeable about these things then one option is to find a local aircon repair person (not installation company) and ask their advise. Even an auto aircon repairer might be able to help.
    At some stage you will need to check, depending on cost of repairing the existing unit, whether to buy a new unit (a more common brand) which might set you back about $600 for a small unit plus installation. At least the pipes are already there.
    good luck.
  • 770 Answers
Sometimes you have to do what I call "Overkill" to cure this problem..The leak detector should find it, unless it is in the unit itself. Typically, the leak will be at a connection. Many of the new systems come precharged, and the linesets are installed with fittings. You could vacuum the system then change the linesets to copper and sweat the joints, eliminating a fitting issue with the linesets. If that doesn't cure, then the leak is withing the system and possibly a warranty issue. Good Luck! I hope you find this to be very helpful!
  • Hal Hallman Jan 30, 2010
    The only need at this point to vacuum the system would be to capture the coolant until the linesets are changed and the fittings removed, the refridgerant would then be replaced and charged to the proper levels. This would eliminate leaks at the most obvious, and the most typical places, the fittings, also, if you happened to have a damaged lineset that a leak was coming from, it would cure that as well.
How do you use fluorescent gas leak detector fluid? I got a small tube with the gas line installation kit for my new range.
Adjust desired spray pattern. Spray to coat the suspected leak. Look for bubbles or foam. Microscopic leaks are indicated by foam, larger leaks produce larger bubbles.
Feb 02, 2013 | Nu Calgon 4184-53 Gas Leak Detector,...
Ac problem loosin gas
Hi there:
What can happen is the vehicles Freon will leak out and reduce the total pressure in the system. Then the low-pressure cut out switch will disengage the compressor when the low side is detected below 25 psi.
This safety feature is to protect the compressor itself. I have seen mechanics bypass the low cut out switch for testing. This should never be done and is not recommended.
The visual presence of oil around a fitting or pressurized line is a strong indication of a refrigerant leak. So my first step in air-conditioning leak diagnosis is to perform a very careful visual inspection of the entire system.
Although this is always my first step for diagnosing Freon leaks it is not always effective in finding the exact problem. In fact, this visual inspection will only uncover large to extremely large leaks. A more common air-conditioning problem would be small leaks that allow Freon to escape over long periods of time. So to follow will be some methods to detect these small leaks.
- The Robinair leak detector is a hand held battery operated electronic leak sniffer. The test probe on the end of the leak detector is moved about 1 inch per second in the areas of suspected leaks. The Robin air leak detector has an alarm that will go off when it detects the presence of a Freon leak. Note on some other models they may have flashing lights or a buzzer. Also some leak detectors are specialized to detect only certain freons (example: 134a) but they all are designed to alert you when they sniff the refrigerant.
- To find refrigerant leaks using the fluorescent tracer system, you first have to install the fluorescent dye into the cars air-conditioning system. Always follow the instructions and do not install too much dye! Too much can reduce the cooling efficiency of the system. Different refrigerant dye leak detectors will accomplish this in different ways. The system we use at work has a device that looks like a caulking gun, and a hose that connects to the low side fitting. Then you actually push the dye into the low side with the engine running and the compressor engaged. Next you run the air-conditioning system for several minutes to distribute the dye evenly. Then you put on your yellow glasses and examine the system with a fluorescent light.
The fluorescent dye shows up easily wearing the yellow glasses.
A very popular selling item is Refrigerant with leak sealer. This item will only seal very small leaks. I have used the stuff pictured to the right "super seal pro" and it does work in some situations.
The Freon leak sealer works best when you have low side system leaks. And if you happen to have a small leak from an O-ring on the low side this stuff works well. If you have a leak on the high-pressure side chances are this sealer will not work for you.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Feb 15, 2012 | Cars & Trucks
How should I disconnect outside unit pipes from inside unit "IAQT32C2bedhac" air conditioner without losing liquide/gas?
Hello, if this is a split system AC then you can pump down the refrigerant into the condenser. You would need a set of gauges to do this. It would involve checking the pressures and closing off the liquid line and suction line, this will keep the refrigerant in the condenser and allow you to disconnect the line set.
Oct 06, 2011 | Heating & Cooling
Hi, I need to relocate the split air conditioner, but I don't know the first step and next steps. Thank you,
If you are not a service technician you probably won't have the tools you will need to accomplish the move. Here is what it takes, step bye step. 1. Pull the fuses or turn off the electrical breaker in the house. 2. Hook up a gauge manifold to the Condensing unit ports for the liquid and suction lines. 3. Hook up a Refrigerant recovery machine to the manifold. 4. Recover the refrigerant into recovery tanks down to a trace, no vacuum. 5. Disconnect the electrical whip and control wiring from the condenser. 6. Close off the service valves on the liquid and suction lines at the condenser. 7. Slowly unscrew the copper line connections to the condensing unit to relieve any pressure that may exist from Refrigerant boiling out of the oil in the compressor and quickly cap them. 8. Move the unit to your new, firm and level location. 9. Remove the old electrical disconnect and whip and move it to the condenser. 10. Buy a new line set of the proper length or extend the old one with Refrigeration copper and couplings preserving the condenser couplings. 11. Replace the liquid line drier and reconnect the copper lines to the condensing unit. Replace the "O" Rings if needed to insure a good seal. 12. Hook up a vacuum pump to your gauge manifold. 13. Open the isolation valves on the condenser. Depending on the oil type in the system, evacuate to 250 Microns. 13. Charge system with 50 pounds of Nitrogen and a little Refrigerant for a trace test. 14. Watch your gauges for a drop in pressure indicating a leak. 15. Check all fittings and any splices with a good Halogen gas detector. 16. Evacuate the system again to the point of vaporization of the oil in the compressor being careful not to boil it off. 17. Close off all ports on your manifold and install a small drier to your Refrigerant line. 18. Re-install the recovered Refrigerant, running it through the small drier on your manifold. 19. Re-check for leaks. 20. Install the electrical whip on the contacter and the control wires on the contacter coil. 21.Start the AC and check the running amps against the name plate Full Load Amps (FLA) or Regular Load Amps (RLA) and check the Refrigerant charge against the units chart. Either in your owners manual or glued to the electrical access cover.
Method 2 = Instead of recovering the refrigerant, you can pump it into the condensing unit. With your gauge manifold tied in, close the liquid line isolation valve. Run the compressor till the compound gauge reads 1 pound and close the suction line isolation valve. Doing it this way will eliminate the need for the recovery machine and heavy tanks. All else remains the same.
Special tools needed = Compound gauge (meaning it reads both pressure and vacuum). High pressure gauge, gauge manifold and at least 3 hoses, a vacuum pump, leak detector (or soap bubbles) and an amp probe. Please rate this response. Thanks for asking!
Apr 01, 2011 | Heating & Cooling
My freezer is not working
Check compressor working. If not try with replacing relay. If compressor working, check warm in condenser coil by keeping your hand. If warm, check whistling sound in freezer. If no warm gas leak. If warm and no whistling sound in freezer, chocked system.
For gas leak find leak and arrest. Then vacuum and do gas charging.
For chock, release all gas, flush out system, replace filter drier, vacuum and do gas charging. Call professional repairman to do it. Thanks.
Jan 28, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I HAVE SPLIT UNIT AND THE COILS ON THE OUTSIDE ARE FREEZING UP I'VE HAD THE FREON CHECKED IT ONLY DOES THIS WHEN IT AROUND 35 OR BELOW
Gas leak in your system. Don't run the unit further as it will pump the oil from compressor. Find leak by pressuring nitrogen up to 300 psi.And with soap solution you can find leak. Even with leak detector you can find.
After finding out the leak arrest with brazing and then recheck for pressure hold up. Vacumise and then do gas charging. Please call repairman to do professional job.
Dec 27, 2010 | Heating & Cooling
E4 Error in Hunday Split Ac
Your technicians are not properly locating the source of leak and repairing it before adding more refrigerant. Have them use a leak detector(sniffer) or colored dye that will reveal the leak. Then repair and fill to specs.
A refill of a slow leak will work until refrigerant it leaks out again.
Sep 02, 2017 | Heating & Cooling
Anyone have a Fujita Installation manual
it should be all coded on the head and compreser for the sparky
Dec 17, 2009 | Heating & Cooling
LG LSC091PMA Split System Air Conditioner Logo
85 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
