Question about Weber S-620 Stainless Steel
Convert from lp to natural gas - Weber S-620 Stainless Steel
    Scholar:
  • 127 Answers
You need to change the burner orifices. These screw on the back side of the gas valves, under the grill, where they feed into the burner tubes. There are conversion kits available. Just call customer service at 1-800-446-1071
Posted on Feb 12, 2010
Convert LP Lincoln oven Impinger II series 1700 to natural gas series 1600
Yes. You need a set of natural gas orifices to replace the LP ones on the oven and all the burners too.
Jan 28, 2014 | Ovens
Tip
Changing your gas appliance from natural gas to LP or vice versa.
You have an LP gas stove which you really like and would like to take to a new home but the new home has a natural gas hookup. Since natural gas is already available it would be convenient to be able to use it. Can you convert your unit over to work on natural gas?
Yes it is possible to convert any LP gas appliance to natural gas or from natural gas to LP. The only difference is the size of the orifice used in the burner.
LP gas is composed of a much larger molecule than natural gas and requires a larger orifice to output the same amount of gas as a natural gas unit at the same setting. Therefore if you used an LP stove on natural gas it would produce too much heat and burn rather intensely. If you used a natural gas stove on LP it would not have much flame at all. You can see the problem. The solution is also obvious. You need the correct orifice.
Changing the orifice is easy. It is located in the middle of the burner and unscrews out of the unit. Install the new one the opposite way. Do not overtighten it.Usually the burners are made of soft metal and can strip easily.
The parts you would need are available at most good appliance stores but I would recommend the following site http://www.repairclinic.com . The parts will be cheaper at repairclinic. They have parts for almost any brand and a great search engine. They also have excellent videos showing how to make the repair.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
How do I convert from liquid propane to natural gas
You need parts from the manufacturer. The gas orifices are different sizes between natural gas and LP gas. If you try natural gas with an LP gas orifice, you will not get much flame. If you use LP gas with a natural gas orifice, you will burn off your eyebrows and possibly other things.
Dec 19, 2013 | Capital Cooking Titanium X CCE26XRBI (NG)...
Convert from natural gas to lp
You can purchase an LP kit and install it on your burner
Nov 25, 2013 | Magic Chef CYG3004AWW Gas Dryer
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Convert natural gas stove to LP
Nothing is imposible but this stove was not made to be converted. It is a not a classic crank down and flip model. Your best bet would be to get your LP gas supplier to do it.
Dec 15, 2008 | Kitchen Ranges
Converting a range from LP to Natural gas
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
Jul 31, 2008 | Jenn-Air ® 48" Professional Over The...
Conversion
call the dealer and get a converter.
Apr 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
How to convert from LP back to Natural Gas?
I have an old Kenmore dryer that I need to convert from LP to gas. I have the parts but no instructions. Can you please help?
Thank you, Roxanne
Mar 06, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Weber S-620 Stainless Steel Logo
101 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
