Game problem Tech Buddy lB4G20... You suggest I look for my answer to the little stove that needs a support which I cannot find in the game called "Scratches" in that arena...where is that "arena"??
  • 3,587 Answers
Ahhh..the arena means this Fixya crowd..
Posted on Feb 18, 2008
Why surface control knobs become hot when oven is on
If its an older model gas stove, then its normal. I have an older gas stove and the knobs get a little hot when the oven is on. Nothing that prevents me from using it, but enough to notice they are warm.
If its a newer stove, you should contact the manufacturer. Without knowing more info, I can only give a general answer.
If you're renting in an apartment then talk to the management or maintenance. If you're leasing the stove, call the company its being leased from.
Sep 30, 2015 | Kitchen Ranges
I have a new Buck STove Hybrid (coal and wood). The brick liners in the ceiling are loose and frequently are dislodged when feeding wood. Why is it designed this way.
I would suggest contacting the manufacturer at this link in order to get an answer to your question. Each stove manufacturer has their own way lining the stoves. Make sure you have your model number and serial number of your specific stove prior to calling the manufacturer so they can give you an informed answer. Good luck.
Do you have questions or comments
Jan 09, 2014 | Buck Stove Home
Looking for the operating manual for a WFS43W-1 stove / oven from white westinghouse. Anyone can help me?
First, I'm Not a westinghouse tech.
* call vendor for service. Gas leaks are hazardous and require a qualified tech to service.
*** The following is for information only.***
* I've always had problems servicing gas stove, heaters, boilers, etc. Lots of unique components that require special tools to service.
* I was surprised to find out that it's better to call on your local Gas Supplier for service. The not only check the supply line but also have a very good working experience with all types of gas fired equipment.
* Slow pilot lighting or burner fire usually means a clogged gas vent or valve. If other burners are working fine, then it's just that particular burner.
* If all burners have the same symptom then it could be a number of things.
* Check gas mains for pressure and flow (you need a gas meter for this but if you have another stove on the same line then it's probable that the mains are okay. Unless the connector or shutoff valve is not working properly (partial open).
* Check gas hose to stove for kinks. Replace if bent (re bending will crack a metal hose.)
* Check the gas regulator (again, need a gas meter)
* Check the feed and branches for gas. If pilot lights are not on then there is a good indication that your not getting gas to that section. (or the pilot is clogged) Clean, clear, or replace pipes/parts.
* Check valve on each burner. This is the most used item on the stove. Expect it to wear out. Replace as needed.
* Final, Be safe; Call your Gas company or MFR tech for service.
Aloha, ukeboy57
Jul 12, 2010 | Kitchen Ranges
I have a over the stove microwave. It is a GE JVM 1631ch003. It turns on but it does not heat the food. Can you help me figure out what it is.
If it over 5 years old may need to replace. Tranformer, magntron, or diaode may be problem.. Call tech,,diagnose if easy problem you can do it yourself. Transformer, diode..Magnatron takes two people to assist. Suggest tech..
Jun 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
OKI B2540 MFP .... Just in the process of setting it up. I have one problem: I have one telepone line that rings once for most incoming calls but for faxing purposes I have a second number on the same line...
You need to get an auto switch box such as the Command Communications Comswitch 5500 it was what is called distinctive ring and that if the function you need. You can plug in your phone, fax machine, answering machine, etc. You can get them from Office Depot, Office Max, Staples and such.
I hope this helps, If so please rate our solution.
Corporate Computer
Nov 29, 2009 | OKI B2540 MFP Printer
Mfc9880 machine error 71
error 71 is a problem with the polygon motor which is in the laser unit. This error usually means that you would need the laser unit replaced.
I'd suggest calling out an engineer.
Dec 12, 2008 | Brother MFC 9880 All-In-One Laser Printer
Kenmore model stove 790.95912 door is locked flashes code f1 Please help
Called a tech over out of the phone book.Its the hollidays need my stove.Cost $249.42 for the part and $50 for the service call and labor. f-1 code is a bad touch pad.
Nov 24, 2008 | Kitchen Ranges
GE profile gas range
Hi threeamigoma,
ngafm at your service,
Your stove top and broiler works well. But the temperature won't go past 100. There is a little sign below the 100 saying ON. First time I have ever seen this.
More than likely the thermostat is faulty. But you can not tell exactly with out hands on diagnoses.
Since I am unable to be there, you will more than likely need to call a tech to service this.
There are a few things that need to b tested to narrow down the precise parts needed.
Bless You ngafm.
Please rate me before you sign off the site.
Thank You
Sep 11, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Computer game/Scratches
that's what I thought, and that's what my notes suggest. I'm not a game person, and most of the folks here are hardware/software/etoys types. You might get lucky and find one that knows the game you are referring to, but that would be a bonus.
Feb 17, 2008 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
